What have you done to your 2nd gen Tundra today?
Discussion in '2nd Gen Tundras (2007-2013)' started by T-Rex266, Jan 7, 2014.
  1. Dec 27, 2020 at 12:51 PM
    #8551
    Stainlesst
    Stainlesst everybody loves an Inky. Inky Inky. go Inky go!
    going to the big D and don't mean Denver...
    09 trd crewmax, 13 TWReX stage III
    In the "Zone"...
    Rica25 likes this.
  2. Dec 27, 2020 at 2:12 PM
    #8552
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    ECGS bushing install complete, with a new CV axle. Something was wrong with the original CVs c-clip. I didn't have any trouble getting the new axle in. I beat the old one like a rented mule with no luck. The familiar growl of the old needle bearing is gone.
    For anyone interested, the axle nut and lower ball joint bolts along with the brake caliper & brake line bracket is the only bolts I removed to accomplish the install.
    Edited: Oh yeah, I broke the ABS sensor retainer bolt and cracked the thin plastic around it. I attempted to remove the sensor before I realized you didn't have to. I couldnt get it out without fear of breaking it in half. I left it....& crossed my fingers that the dash didn't light up. It didn't. I'd rather be lucky than good any day :p
    Rica25, RJVA and huntertn like this.
  3. Dec 28, 2020 at 8:32 AM
    #8553
    airosey
    airosey 2009 CrewMax Limited 4x4
    East TN
    Slightly modified 2009 CrewMax Limited 4x4
    09 Tundra CrewMax Limited TRD Supercharger with URD pulley Tuned by OrangeVirus tuning (OV Tune) TRD Big Brake Kit with SS lines and titanium backing plates StopTech rear sport axle pack (rotors, pads, and SS lines) 7” Pro Comp lift 3” Performance Products Body Lift Coachbuilder 1” coilover shims Coachbuilder +3 shackles Coachbuilder Tie-rod ends 22x14 -70 Fuel Lethal’s - 2 piece 38x15.5 Mickey Thompson Baja Boss M/T’s King Shocks with remote reservoirs front and rear Nitro 5.29 gears front and rear Auburn LSD SPC adjustable UCA’s BAM 8” exhaust Pro Comp Traction Bars Enve Grille Smittybilt M1 front bumper Rough Country 12k lbs winch Demon Hook shackles front and rear Baja Designs Squadron Sport Amber and clear fog lights ADD HoneyBadger Rear Bumper with Rigid SR-Q reverse lights Sequoia Headlight conversion Switch-Pros SP-9100 mounted in overhead console SD Off-road MT under-hood tray AEM boost and afr gauges Hypertech Speedometer calibrator Bed and rear bumper are Bulletlined American Flag Headliner Mammoth Guards patriot edition Alpha and Omega Fabrication Patriot Hood shield 3rd gen door panels and steering wheel ProSpeed Catchcan Hornblasters Outlaw train horns Tufskinz real carbon fiber overlays Tufskinz carbon fiber B panels vLEDs footwell lighting front and rear vLED puddle lamps Lighting Trendz flow series wheel rings 16 RGB rock lights Toyota Bedmat Bestop Power folding steps Undercover bed cover Undercover SwingCase 4 gallon Rotopax fuel can Here’s a rundown of the audio setup. -Active front stage using a JL Audio TwK88 DSP, Focal 165KRX2 component speakers, powered by a JL Audio HD900/5 -Passive rear setup with Focal 165KRX2 component speakers -2 JL Audio Stealthboxes (13TW5’s) powered by a JL Audio HD1200/1 -Sony XAV-9500ES float mount display with a PAC Radio Pro 4 -Odyssey battery -JL 0 gauge power and ground cables -AudioQuest X-2 speaker cables and Golden Gate RCA interconnects -Entire cab has been lined with Dynamat Extreme and 1/4 CCF Amps and dsp are mounted under the passenger seat with a SoundsGoodStereo mounting plate.
    Thank you! It’s a ProComp 7” with a 3” body lift. 22x14 -70 Fuel Lethals and 37x13.5 Toyo Open Country R/T’s
    Rica25 likes this.
  4. Dec 28, 2020 at 8:37 AM
    #8554
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Its raining this morning, so I took it to work, also known as washing it with an air dry ending...
    Mountun Goat and Rica25 like this.
  5. Dec 28, 2020 at 8:38 AM
    #8555
    Barnstormer
    Barnstormer New Member
    FWIW, my 07 SR5 also has the info / MPG buttons and display.
    Rica25 likes this.
  6. Dec 28, 2020 at 8:40 AM
    #8556
    airosey
    East TN
    check out the Bestop power folding steps. Just installed mine yesterday. Very nice and much more affordable than the amp steps.
    Rica25 and blackdemon_tt like this.
  7. Dec 28, 2020 at 10:26 AM
    #8557
    mihallo
    mihallo New Member
    Dubai, UAE
    2012 Silver Tundra SR5
    Made an in-car garage opener. Kinda ghetto, but i managed to do it without making the original remote useless :)
    Bonus factor - apparently wires i soldered in work as antena as the range has improved quite a bit :)20201228_221739.jpg
  8. Dec 28, 2020 at 1:15 PM
    #8558
    Dg191
    Dg191 New Member
    2007 2 who drive limited tundra
    None
    Just looked at the Bestop folding running boards, unfortunately, they don’t make them for my 07 Tundra. Thank you for the help. I was wrong they do make them and I’m getting them, thank you for the help
    worktruckwhite and Rica25 like this.
  9. Dec 28, 2020 at 2:51 PM
    #8559
    Rozr1
    Rozr1 New Member
    2008 SR5 DC
    My 2008 sr5 came with the info button, I'm assuming it came stock with it.
    Rica25 likes this.
  10. Dec 28, 2020 at 4:10 PM
    #8560
    airosey
    East TN
    strange, I just installed them on my 09 crewmax.
    Rica25 likes this.
  11. Dec 28, 2020 at 7:08 PM
    #8561
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
  12. Dec 28, 2020 at 7:18 PM
    #8562
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Paracord it with blue or black. Could use a carbon fiber tape, that would look good. Just a suggestion :thumbsup:
  13. Dec 28, 2020 at 7:35 PM
    #8563
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    @kparrow I put black wire loom over mine.
    Rica25, kparrow, rons23 and 1 other person like this.
  14. Dec 28, 2020 at 7:46 PM
    #8564
    rons23
    Ron
    Kill Devil Hills
    That's a cool idea :thumbsup: :monocle:
    Mountun Goat[QUOTED] and Rica25 like this.
  15. Dec 28, 2020 at 9:21 PM
    #8565
    ACDC2ZZTop
    ACDC2ZZTop Rock n Roll!
    Travis
    Oregon
    2012 MGM Tundra double cab 5.7L V8
    All cosmetic so far see my posts in 2nd gen Black out chrome in progress….
    I like that blue. Haven’t seen that color in my area at all
    Half Assed and Rica25 like this.
  16. Dec 29, 2020 at 2:51 PM
    #8566
    Barnstormer
    Nautical Blue, 8S6
  17. Dec 29, 2020 at 4:14 PM
    #8567
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    I finished up this seat today. I did the 60% bench yesterday. I'm hurting in ways I've never experienced before.
  18. Dec 30, 2020 at 11:10 AM
    #8568
    mihallo
    mihallo New Member
    Dubai, UAE
    Done with headlights. Alpharex pros, 5K HIDs, grille "can-i-be-a-raptor" ambers. 20201230_225907.jpg
  19. Dec 30, 2020 at 12:15 PM
    #8569
    Rozr1
    Rozr1 New Member
    2008 SR5 DC
    Looks good man, I eventually want to do the headlights upgrade myself.
  20. Dec 30, 2020 at 1:13 PM
    #8570
    mtndds98
    mtndds98 New Member
    2013 Silver Tundra CrewMax
    6" ProComp Stage 1 lift
    Looks awesome!!
    mihallo[QUOTED] and Mountun Goat like this.
  21. Dec 30, 2020 at 6:14 PM
    #8571
    hhenry_
    hhenry_ New Member
    Bay Area Ca
    08 tundra crewmax
    I did 2020 sequoia Trd pro grill conversion
    erandmckay, The Dude, ecm209 and 21 others like this.
  22. Dec 30, 2020 at 6:37 PM
    #8572
    GNTundra
    Gino
    2013 White
    I pulled mine out after a few months:D
    mihallo, Prostar 190 and Rica25 like this.
  23. Dec 30, 2020 at 7:16 PM
    #8573
    Looks good!
    mihallo and hhenry_[QUOTED] like this.
  24. Dec 30, 2020 at 7:40 PM
    #8574
    hhenry_
    hhenry_ New Member
    Bay Area Ca
    08 tundra crewmax
    Thanks!
    Prostar 190[QUOTED] and Rica25 like this.
  25. Dec 30, 2020 at 7:54 PM
    #8575
    Mulligan1305
    Mulligan1305 New Member
    NC
    2011 Tundra SR5 DC, 4WD
    You may wanna check with your local P.D. and make sure you aren't a suspect in a theft case...
    Rica25 likes this.
  26. Dec 30, 2020 at 8:15 PM
    #8576
    ACDC2ZZTop
    Travis
    Oregon
    Waiting patiently until I have a few things moved out of garage to put in JVC stereo, backup camera, black climate control knobs, new shifter and considering making dash piece above steering wheel black. Will post before and after pics soon
  27. Dec 31, 2020 at 9:26 AM
    #8577
    shannon
    shannon New Member
    shannon
    Asheville, NC
    2010 DC
    Climate control knobs in back? Tell me more about this. It looks like you have a double cab, I've been wondering if you could add the climate control from a crew max to a DC.
  28. Dec 31, 2020 at 9:37 AM
    #8578
    ckkone
    ckkone New Member
    SLC, UT
    Does your fuel gauge work correctly?
  29. Dec 31, 2020 at 10:31 AM
    #8579
    SkipperPete
    SkipperPete New Member
    Pete
    Nicholasville, KY
    2012 Silver Tundra Crewmax
    Shannon,
    Looks like ACDC2ZZTop said he's replacing the climate control knobs with black colored ones, not putting climate control into the back of the truck.
    ACDC2ZZTop likes this.
  30. Dec 31, 2020 at 12:01 PM
    #8580
    SilverSkySurfer
    SilverSkySurfer DIY till ya die
    Augusta, Georgia
    2012 Silver Sky DC SR5 4.6L 2WD
    Method Con6 Wheels, LED Swap, LED taillights, BAM 8” exhaust, Eibach Spro sport leveling front shocks, AJT Shift knob and AC controls, Cover king seat covers, husky floor liners, color matched mirror caps and door handles, retrax bed cover, shorty antenna, D ring tow Shackles, rear TRD sway bar, JVC KW-Z1000w head unit, Morimoto Fogs, Alpharex Headlights
    Added some new D-Ring shackles and color matched the grille surround with plasti dip
