What have you done to your 2nd gen Tundra today?
Discussion in '2nd Gen Tundras (2007-2013)' started by T-Rex266, Jan 7, 2014.
  1. Dec 18, 2020 at 3:15 PM
    #8491
    cygan1008
    cygan1008 New Member
    “RIP” 2013 Tundra TRD Rock Warrior, 2018 TRD SPORT CM 4x4 SUPER WHITE Eibach Pro 2.0 275/65/20 Recon Grapplers
    The quest for all white light continues
    next up, morimoto tag lights
    WVI, ecm209, PhysicZ and 5 others like this.
  2. Dec 18, 2020 at 6:25 PM
    #8492
    PhysicZ
    PhysicZ 1g3
    Robert
    2013 MGM Tundra crewmax
    Hit 82k miles and finally changed out the oem rotors and pads, went with powerstop and drilled slotted rotors
  3. Dec 19, 2020 at 3:36 PM
    #8493
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    Finally got around to installing the Limited gauge cluster I got to replace my SR5 cluster. I love it, it looks great. :D
    Took me awhile to find the little clips holding the fabric around the steering column onto the cluster bezel. That piece didnt make it back on when I reinstalled. I couldn't get my booger hooks back in there.
    I also disabled the TPMS light that has been on for almost 6 months now. :yes:
  4. Dec 19, 2020 at 4:09 PM
    #8494
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The only thing that I don't like about mine is that I can't turn down the brightness enough, I like it dim. One neat thing now though is that if you also have the info buttons on the right side of the dash, you can change some other lighting settings that would normally require Techstream to change. I'm sure that you can figure them out once you get to poking around a little.
    Mountun Goat likes this.
  5. Dec 19, 2020 at 4:24 PM
    #8495
    Half Assed
    Heartland Florida
    Which settings?
    I dont have those buttons. I read a while back about it. Sounded like they give you mpg and range data. Wasnt worth the $125 to me.
  6. Dec 19, 2020 at 4:28 PM
    #8496
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I don't have a complete recollection, but settings like how long the map lights remain on after unlock, how long they stay on after you turn the engine off. I'll try to refresh my memory the next time I need to go somewhere.
  7. Dec 19, 2020 at 4:35 PM
    #8497
    Half Assed
    Heartland Florida
    Hmm, sounds similar to the info buttons on a GM.
  8. Dec 19, 2020 at 6:07 PM
    #8498
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Where did you get that grill? I am Digging it man!
    toyofan87 and Mountun Goat like this.
  9. Dec 19, 2020 at 6:29 PM
    #8499
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    TheBeast likes this.
  10. Dec 19, 2020 at 6:42 PM
    #8500
    airosey
    airosey 2009 CrewMax Limited 4x4
    East TN
    Slightly modified 2009 CrewMax Limited 4x4
    09 Tundra CrewMax Limited TRD Supercharger with URD pulley Tuned by OrangeVirus tuning (OV Tune) TRD Big Brake Kit with SS lines and titanium backing plates StopTech rear sport axle pack (rotors, pads, and SS lines) 7” Pro Comp lift 3” Performance Products Body Lift Coachbuilder 1” coilover shims Coachbuilder +3 shackles Coachbuilder Tie-rod ends 22x14 -70 Fuel Lethal’s - 2 piece 38x15.5 Mickey Thompson Baja Boss M/T’s King Shocks with remote reservoirs front and rear Nitro 5.29 gears front and rear Auburn LSD SPC adjustable UCA’s BAM 8” exhaust Pro Comp Traction Bars Enve Grille Smittybilt M1 front bumper Rough Country 12k lbs winch Demon Hook shackles front and rear Baja Designs Squadron Sport Amber and clear fog lights ADD HoneyBadger Rear Bumper with Rigid SR-Q reverse lights Sequoia Headlight conversion Switch-Pros SP-9100 mounted in overhead console SD Off-road MT under-hood tray AEM boost and afr gauges Hypertech Speedometer calibrator Bed and rear bumper are Bulletlined American Flag Headliner Mammoth Guards patriot edition Alpha and Omega Fabrication Patriot Hood shield 3rd gen door panels and steering wheel ProSpeed Catchcan Hornblasters Outlaw train horns Tufskinz real carbon fiber overlays Tufskinz carbon fiber B panels vLEDs footwell lighting front and rear vLED puddle lamps Lighting Trendz flow series wheel rings 16 RGB rock lights Toyota Bedmat Bestop Power folding steps Undercover bed cover Undercover SwingCase 4 gallon Rotopax fuel can Here’s a rundown of the audio setup. -Active front stage using a JL Audio TwK88 DSP, Focal 165KRX2 component speakers, powered by a JL Audio HD900/5 -Passive rear setup with Focal 165KRX2 component speakers -2 JL Audio Stealthboxes (13TW5’s) powered by a JL Audio HD1200/1 -Sony XAV-9500ES float mount display with a PAC Radio Pro 4 -Odyssey battery -JL 0 gauge power and ground cables -AudioQuest X-2 speaker cables and Golden Gate RCA interconnects -Entire cab has been lined with Dynamat Extreme and 1/4 CCF Amps and dsp are mounted under the passenger seat with a SoundsGoodStereo mounting plate.
    In the shop getting Nitro 5.29 gears and Auburn Pro lsd. Should be done on Tuesday. 9AC12127-7322-46CC-821E-8418455B4CE8.jpg
    ecm209, Rica25, mtndds98 and 9 others like this.
  11. Dec 20, 2020 at 11:13 AM
    #8501
    Stainlesst
    Stainlesst everybody loves an Inky. Inky Inky. go Inky go!
    going to the big D and don't mean Denver...
    09 trd crewmax, 13 TWReX stage III
    In the "Zone"...
    going under the knife next week at work...
  12. Dec 20, 2020 at 11:17 AM
    #8502
    TheBeast The Beach
    nice overland truck !
    Rica25 and TunaDr[QUOTED] like this.
  13. Dec 20, 2020 at 2:34 PM
    #8503
    Punisher17
    Punisher17 New Member
    Settled in to the new house. Baby due on January 2nd. Snuck in a little work on the yumdra lol. Took off the Aries bull bar, switched over some bulbs back to halogen from the LEDs I got from Amazon. From this YouTube video https://youtu.be/1ruTyuD68fc cheaper LEDs don’t penetrate like halogen. I live in the California foothills. Back to halogen is way better! Ordered yellow film tint that I’m going to put on the ditch light lenses next.
    WVI, Rica25, Red Sonja and 5 others like this.
  14. Dec 21, 2020 at 12:06 AM
    #8504
    MTRock
    MTRock 1889
    Montana
    Looking good..Congratulations on the new house and most importantly the new baby!
  15. Dec 21, 2020 at 8:16 AM
    #8505
    Stainlesst
    In the "Zone"...
    What's your setup? looks nice hope mine looks some what like that when i am done...
  16. Dec 21, 2020 at 8:27 AM
    #8506
    Punisher17
    Thank you. We are really excited!
  17. Dec 21, 2020 at 8:31 AM
    #8507
    MTRock
    MTRock 1889
    Montana
    I know you’ve probably been told this...enjoy ever moment! Time flies!! Them little buggars grow up fast!
  18. Dec 21, 2020 at 8:31 AM
    #8508
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I added a steering wheel spinner... the goat is a tractor now after all.
    But honestly, the next best upgrade since the plow. If you have a plow, you need a wheel spinner too.
    Rica25, chugs, Prostar 190 and 4 others like this.
  19. Dec 21, 2020 at 8:37 AM
    #8509
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Oh, the goat also shedded its rack. Need to make some mods to the rack. I also plan on building a rear spare tire mount. I will fab a frame-to-bed mount bracket that runs to each bed/frame bolt at the rear of the bed floor. I’ll weld a nut to receive the spare wheel retainer key in the center on the bracket and call it a day.
    Overall, I hope to gain some rear weight ballast for plowing and winter driving.
  20. Dec 21, 2020 at 12:12 PM
    #8510
    kanger328
    kanger328 New Member
    Anchorage, Alaska
    2012 DC 4x4
    Whaaaaaatttttt. Found a new project...
  21. Dec 21, 2020 at 5:09 PM
    #8511
    RJVA
    RJVA Former Lurker
    Richard
    Idaho
    2008 Tundra Silver DC 4.7 4x4
    OEM 18" wheels off a 2.5 gen 275/70/18 Falken Rubitrek A/T FabFour Redsteel front bumper with HF winch. Dobinsons IMS with 2.25" coils (610) JBA UCA's Iron Man +300lb rear leaf packs with Dobinsons IMS shocks ECGS bushing in front diff Black Oak Led Flood Pods. 40watt (x2) Black Oak 20" light bar. 100 watt OEM style rear bumper, black powder coat, added aux reverse leds. Stubby AM/FM antenna Century Camper Shell with Roof rack and bed mat
    Red Steel bumper by FabFour is now bolted up.
  22. Dec 22, 2020 at 7:41 AM
    #8512
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I drilled some holes in my roof yesterday.. Installed m4 nutserts for a factoryish install of these amber leds. Started wiring, I got 12 wires pulled from under dash (enough tail to clear firewall and make the relay box) up to the newly added overhead console switch panel. More to come as the wiring continues.
    Ps: I used the right stuff again in this job, I ran a bead around the bottom edges and also the screw heads.
    BigSkyTaco, kparrow, Rica25 and 15 others like this.
  23. Dec 22, 2020 at 7:45 AM
    #8513
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    They look kinda like a computer mouse...:p
    TheBeast, Half Assed and Mountun Goat like this.
  24. Dec 22, 2020 at 7:51 AM
    #8514
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Oh that’s what they are. Amber underlit mice.
    TheBeast and Wynnded[QUOTED] like this.
  25. Dec 23, 2020 at 12:17 PM
    #8515
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Since I have time off starting tomorrow, I think I'll bring the Tundra into the garage tonight for the long awaited, much needed ECGS bushing install. :fingerscrossed:
    Mountun Goat and Prostar 190 like this.
  26. Dec 23, 2020 at 1:05 PM
    #8516
    gipsyfetus
    gipsyfetus Royale with Cheese
    KY
    2013 Radiant Red Tundra 4x4 Double Cab 4.6L
    Tinted windows, Roof Rack, Rage Cage, Slim Toolbox, LED Ditch Lights, Bug Deflector, Tube Side Steps
    Got the 3 inch leveling kit and Nitto Terra Grapplers 295/70/18 installed. Stock wheels.
    Re-paint the grille in the Spring and I will add fender flares too.
  27. Dec 23, 2020 at 1:31 PM
    #8517
    ToyAddict802
    ToyAddict802 #ShallowPockets w/BigDreams
    GreenMt. State
    2023 SR5 DC,2023 Tacoma Sr5
    3.5 TRD Lift, TRD 20” wheels with 295/60/20 Falken Wildpeaks
    Wife said she needed to drop the truck off at the local shop:confused:. When we went to pick it up the next day she had new airlift suspension in the rear. Merry Christmas too me:santa::santa2:9570082B-C15C-466F-B89F-F2F126C583F7.jpg
    So put on the Winter tires and gave her a well deserved bath to clean off the road grime. Wife says one more add on coming so will post pics after it is installed .
    ecm209, tnbndr, SkipperPete and 12 others like this.
  28. Dec 23, 2020 at 1:38 PM
    #8518
    MTRock
    MTRock 1889
    Montana
    She’s a keeper!!
    ecm209, Rockgate, kparrow and 6 others like this.
  29. Dec 23, 2020 at 1:42 PM
    #8519
    ToyAddict802
    GreenMt. State
    Most definitely :101010:
  30. Dec 23, 2020 at 2:35 PM
    #8520
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Weight reduction mod.
    Was pulling the trailer when all of a sudden I hear a nasty grinding noise. Finally found this completely loose heat shield sitting on top of the driveshaft.
