What have you done to your 2nd gen Tundra today?
Discussion in '2nd Gen Tundras (2007-2013)' started by T-Rex266, Jan 7, 2014.
  1. Jul 1, 2020 at 8:11 AM
    #7591
    CrunchTimeHD
    CrunchTimeHD New Member
    Louis
    Easton Pa
    2011 tundra limited CrewMax
    Did that solve your problem? I just had 3 go out all at once.
  2. Jul 1, 2020 at 8:46 AM
    #7592
    ckkone
    ckkone New Member
    SLC, UT
    Good day for the local classifieds, found a Softopper (almost new w/ removable rear screen window), Decked drawers and latest model Pioneer DMH-W4600NEX with backup camera (already have a backup cam so this will go out front). Still want a mid-rise hard shell for the back but this will do for now till one comes up used in super white.
    SprinterAE86, chugs, rons23 and 10 others like this.
  3. Jul 1, 2020 at 8:50 AM
    #7593
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Nice scores! I want a soft topper and decked so bad! Truck looks great :)
    edit. I want all of those things so bad haha
    TheBeast and ckkone[QUOTED] like this.
  4. Jul 1, 2020 at 12:17 PM
    #7594
    worktruckwhite
    worktruckwhite bryceCtravels.com
    Charleston, SC
    2010 White Crewmax
    Nope. I replaced all 3, took it to the mechanic because it still wasn’t working and he said I need to replace the actuators. I don’t know. I think it might be electrical somewhere else.
    Mountun Goat likes this.
  5. Jul 1, 2020 at 1:10 PM
    #7595
    chrisicool
    chrisicool New Member
    2012 Toyota Tundra TRD Rock Warrrior
    Snugtop
    Got the snugtop back on today with fresh seals and clamp hardware. Scruffed up the topper a little bit getting it back on. I'll have to use some bondo or something to repair it. 20200701_130626_HDR.jpg 20200701_130645_HDR.jpg
  6. Jul 1, 2020 at 1:42 PM
    #7596
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    You have pics at night?
  7. Jul 1, 2020 at 1:49 PM
    #7597
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Sorry, no I don't.
  8. Jul 1, 2020 at 5:06 PM
    #7598
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    If you have a little multimeter or test light, test the plug and see if you get voltage when you hit the lock/unlock. If you don't there is probably an issue with electrical somewhere else, otherwise, if you get voltage, test the actuator itself and see if you have continuity. I don't really see how that could be that 3 would fail like that but they could have an internal circuit break I suppose.
  9. Jul 3, 2020 at 8:24 PM
    #7599
    iNKBOi
    iNKBOi Colorado Boi
    Ben
    Vail, CO
    2008 Radiant Red Double Cab SR5 TRD Off-road and now 2020 TRD Pro Army Green Crew
    Just installed some ambers, hopefully they hold up.
    nb_nielsen, Rengawt, D4x4TRD and 13 others like this.
  10. Jul 3, 2020 at 11:48 PM
    #7600
    Dylan7194x4
    Dylan7194x4 New Member
    Dylan
    2013 red cm rw
    Who makes those front and rear bumpers of yours.
    iNKBOi[QUOTED] likes this.
  11. Jul 4, 2020 at 6:26 AM
    #7601
    worktruckwhite
    Charleston, SC
    2010 White Crewmax
    I tested with the light. Lock, it’s good, unlock, it’s like barely flickering. How do you mean test the actuator?
  12. Jul 4, 2020 at 7:18 AM
    #7602
    iNKBOi
    iNKBOi Colorado Boi
    Ben
    Vail, CO
    I did, welder in Vail,CO
    rons23, tnbndr, TigOlTundra and 4 others like this.
  13. Jul 4, 2020 at 7:22 AM
    #7603
    Ericsopa
    Ericsopa Old man and the sea
    New Vision Fury wheels, new tires, and just installed Ride-Rite wireless airbag kit. The airbags seem to smooth the ride a little even @ the minimum 5 PSI without a load.
    TheBeast and Mountun Goat like this.
  14. Jul 4, 2020 at 7:40 AM
    #7604
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Yaaaassssssss:headbang::cheers::fistbump::bowdown:
    iNKBOi[QUOTED] and Stainlesst like this.
  15. Jul 4, 2020 at 7:41 AM
    #7605
    APalmTree
    Brandon
    SW Washington
    With a multimeter, there is a continuity test where you put the two probes on either side of a circuit and it will tell you if the circuit is complete or not. If you don't have a multimeter the most you can do is hook up wires and give it power and see what happens. If you do much wiring at all I would definitely suggest a multimeter though, you can find them for like $15 at most auto parts stores. With that, you can test the two connectors on the actuator and see if the circuit is good. And you can get more information, you can test the motors to see if they are bad, test each connector outside the actuator to make sure that it connects to one of the prongs on the inside of the actuator, etc. It's just a process to narrow down where your problem actually is. As for the light flickering that sounds weird and a multimeter would give you more information like maybe the unlock circuit is not providing 12v for some reason.
  16. Jul 4, 2020 at 7:46 AM
    #7606
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Hey team. @Bob hooked me up with a new decal since my rack covers the og one. I’m thinking of putting it here- has anyone put decals on they’re slider glass? Will it get all scratched when my kids slide the window around for fun? Tia
  17. Jul 4, 2020 at 8:01 AM
    #7607
    APalmTree
    Brandon
    SW Washington
    Not sure about yours with the small window, but my full back window on the crew max has had stickers on it for a year and a half now with no issues through washing or rolling the window up and down.
  18. Jul 4, 2020 at 8:12 AM
    #7608
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks, that’s a start with good results. Sounds good enough for me haha
    Kiddnapped Tundra likes this.
  19. Jul 4, 2020 at 12:04 PM
    #7609
    APalmTree
    Brandon
    SW Washington
    I don't think you disbelieve me but just incase...
    And what is the wisdom on sticker math here? I've heard 10hp sometimes and 5hp other times. IMG_1823.jpg
    Also does sticker math apply to my laptop?
  20. Jul 4, 2020 at 12:13 PM
    #7610
    TigOlTundra
    TigOlTundra New Member
    Tig
    New Hampshire
    2010 SR5 TRD Off-Road, DC 4.6L Slate Metalic
    Hypertech Interceptor, Old Man Emu 612 Front Coilovers and Rear Sport Nitrocharger Shocks, Mamba M19 Wheels, Falken Wildpeak AT3W Tires, Tyger Auto Blades, EAG Grill with lights, DNA Motoring LED/DRL Smoked Headlights, Tubro SII LED Highs and Lows, DTMoto LED Tube Smoked Tail/Brakelights, Alla Lighting Rear Signal LEDs and Reverse LEDs, Note Smoked Third Brake/Cargo light, Plasti-dipped badges, Back-rack, Husky X-Act Contour Floor Liners, OEM Rear Underseat Storage, Colormatched Land Cruiser "Toyota" Grill Badge
    That is next level, always wanted to learn how to weld
    iNKBOi[QUOTED] and Mountun Goat like this.
  21. Jul 5, 2020 at 11:03 AM
    #7611
    Rex Kramer
    Georgia
    Do dealers offer brochures anymore?
    Filthyphil, omgboost and Mountun Goat like this.
  22. Jul 5, 2020 at 5:17 PM
    #7612
    ckkone
    ckkone New Member
    SLC, UT
    Started the audio upgrade, got the Pioneer DMH-W4600NEX and dash speakers done. Couldn’t figure out the wiring for the factory backup camera .
  23. Jul 5, 2020 at 5:55 PM
    #7613
    TheBeast The Beach
    are you able to fit the factory covers back on for the dash speakers ? I ran into same issue and i have since left them off.
  24. Jul 5, 2020 at 7:21 PM
    #7614
    ckkone
    ckkone New Member
    SLC, UT
    Yes, I had some kydex laying around and made the mounts out of that just traced the size of the factory speakers. Took about 20 min to install including the mounts.
  25. Jul 6, 2020 at 9:50 AM
    #7615
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Installed my new Tundras decal! Thanks @Bob for the new hookup!
    I like how it’s more visible than the last setup. From more angles too :)
    Ya Tundras.com!!!
    edit: it giving up covering my plate going forward. FTW!
    rons23, Chrslefty, Trooper2 and 5 others like this.
  26. Jul 6, 2020 at 9:57 AM
    #7616
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Forgot to mention, the coolest part of the new decal spot, is it’s in the rear view mirror now. And the right way even haha
  27. Jul 6, 2020 at 10:58 AM
    #7617
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    My oh my, that's a long, hard thing hanging out like that!
    Mountun Goat[QUOTED] likes this.
  28. Jul 6, 2020 at 11:40 AM
    #7618
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Yes it is a long hard thing poking out like that haha. I removed it right after the shot. Just had unloaded the trailer off it haha. I actually have a spot that I store it underneath the bumper because hitches in receivers are a pet peeve of mine too haha (Old pic during install)
    WVI, JC303, MTRock and 2 others like this.
  29. Jul 6, 2020 at 10:33 PM
    #7619
    dragon_coma
    dragon_coma New Member
    Sky
    2008 CrewMax 4x2 5.7L
    Sad face...
    Sold it
    I wish Toyota made a 3/4 ton truck. I wish they stopped flirting with a Diesel for the US market. I have had Toyotas in the family all my life. My first new car, a 2000 Tacoma, is still in cherry condition in HI (thanks pop!). Sadly (?) I must join the HD Ram forums and start mod’ing a 2019 2500 CTD... at least I still have a 2018 4Runner to keep me grounded!60973E51-87D4-422F-A917-71F2ABD864BF.jpg
  30. Jul 6, 2020 at 10:48 PM
    #7620
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    The wires are in the drivers side A pillar. The signal wires as well as a reverse trigger wire. Just posi-tap off that and run over to your head unit. Should be red and grey for signal and green for reverse trigger
