What have you done to your 2nd gen Tundra today?
Discussion in '2nd Gen Tundras (2007-2013)' started by T-Rex266, Jan 7, 2014.
  1. Aug 29, 2019 at 4:09 PM
    #5161
    Stewartac
    Stewartac New Member
    Castle Rock Colorado
    2013 White Tundra
    Just take some starting fluid to it. Will wipe right off
    Mountun Goat likes this.
  2. Aug 29, 2019 at 5:01 PM
    #5162
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Use a lower rpm. Ideal to do it in the shade on a cooler day. Once the eraser gets too hot it just smears the glue instead of balling it up and coming off. Take lots of breaks to let it cool off too. These tips made the world of difference for me after doing it too fast a couple times in the past.
  3. Aug 30, 2019 at 6:41 AM
    #5163
    mbn225
    mbn225 New Member
    Louisiana
    2008 Tundra Crewmax TRD
    Rock Warrior Bits Flowmaster exhaust 3/1 Lift
    This ^^^
    Mountun Goat[QUOTED] likes this.
  4. Aug 30, 2019 at 12:41 PM
    #5164
    kgb4187
    kgb4187 New Member
    Good to know, thanks! Most of the spots will have new badges on except where the Tundra door badges and the Toyota on the tailgate were.
  5. Aug 30, 2019 at 12:52 PM
    #5165
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Nice looking forward to seeing the results.
  6. Aug 30, 2019 at 1:20 PM
    #5166
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Got my Tyger Blade steps bolted up. They look SWEET!!!!
    291C299E-0788-476A-8BD8-69962293FEBA.jpg 70FD2F52-5CD8-4B0B-8636-7EEDAC69048B.jpg A4EC2E54-F055-4028-8880-CD983CDCF0F5.jpg
  7. Aug 30, 2019 at 5:35 PM
    #5167
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    I'm replacing my flexible brake lines with extended length stainless steel reinforced pieces from Low Range Off-road (over the rear differential and in the front) and heavy duty reinforced pieces from SDHQ (rear axle to rear caliper).
    While I'm in there I'm changing the front brake pads, flushing the DOT 3 fluid and switching to DOT 4.
    DOT 4 is compatible with DOT 3 systems and has a higher boiling point to help prevent brake fade.
  8. Aug 30, 2019 at 5:59 PM
    #5168
    careyrob
    Carey
    Massachusetts
    If anyone is curious, DOT 5 and 5.1 have even higher boiling points, but DOT 5 is not compatible with our brake system at all.
    DOT 5.1 is in the same family as 3 & 4 (glycol-based), but it's about 14 times more expensive than DOT 3 and may cause problems with the ABS system.
    DOT 4 is completely compatible and only costs about 2 times as much as DOT 3 which Toyota puts in the Tundra.
  9. Aug 30, 2019 at 6:37 PM
    #5169
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Nice to know, thanks.
  10. Aug 30, 2019 at 7:05 PM
    #5170
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I slide my airbox lid over a bolt hole. I’m curious to see if it makes a power difference or not.:crapstorm:
    NE_WARRIOR likes this.
  11. Aug 30, 2019 at 7:16 PM
    #5171
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    I found that everything I tried doing other than leaving the stock airbox alone caused truck to lose low end torque:(
  12. Aug 30, 2019 at 7:18 PM
    #5172
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    That’s what I was waiting for haha. I’ll try it out for fun!
    TruckyTruck[QUOTED] likes this.
  13. Aug 30, 2019 at 7:19 PM
    #5173
    TruckyTruck
    Gary
    I know, I couldn't help myself.
  14. Aug 30, 2019 at 7:20 PM
    #5174
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Haha :fistbump:
  15. Aug 30, 2019 at 7:21 PM
    #5175
    NE_WARRIOR
    NE_WARRIOR [HOONIGAN] Wannabe
    Nick
    Union, ME
    08 DC SR5
    should make the truck sound more throaty though :thumbsup:
  16. Aug 30, 2019 at 9:14 PM
    #5176
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I’m sure your right :D
  17. Aug 30, 2019 at 9:18 PM
    #5177
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Worked on the rear bumper some more this afternoon.
  18. Aug 31, 2019 at 4:48 AM
    #5178
    chphilo
    chphilo Tundra addict
    Western PA
    After limping along on Nitto tires that were beginning to crack, I replaced them with Cooper Discover MTP, same size (295/70/18). I would like to see a longer lifespan than Nitto (3 & 1/2 years).
    Twinky, parker44, Billy I and 7 others like this.
  19. Aug 31, 2019 at 8:42 AM
    #5179
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Aggressive! Looks good
  20. Aug 31, 2019 at 8:47 AM
    #5180
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I did this.
    Sequoia lights are in. 100% plug & play thanks to xrunnerdude67. They look great even missing the fill panels. (picking up Tuesday from being painted)
    I ended up with Black SR5 & silver Platinum lights (eBay seller said it was black) It's hard to find a reasonable deal on these so I'll suck it up.
    This is the difference between silver & black.
    ecm209, Prostar 190, kgb4187 and 4 others like this.
  21. Aug 31, 2019 at 8:49 AM
    #5181
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Greatest 2nd gen mod available! :bowdown::bowdown:
  22. Aug 31, 2019 at 9:41 AM
    #5182
    Pbear1454
    Pbear1454 New Member
    NorCal and SoCal
    2010 Tundra TRD
    Bilsteins SPC RCI Steel Bumpers
    How much did it set you back with new harness and all ?
  23. Aug 31, 2019 at 9:53 AM
    #5183
    e30cabrio
    1135 for the lights (535 & 600) both from eBay. It's hard to find them without damage/missing mounting points & 110 for the harness.
    If you are willing to get the lights missing mounts/scratched they are less. I wasn't.
    Mountun Goat and Pbear1454 like this.
  24. Aug 31, 2019 at 9:54 AM
    #5184
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    King 2.5s custom gold rock warrior wheels 2020 sequoia LED headlights
    I was right under $1700 for mine
    Harness $110
    Filler panels $80
    Lights brand new $1500
  25. Aug 31, 2019 at 9:59 AM
    #5185
    e30cabrio
    I forgot the fillers. Thay were 80 I think and I'm paying 70 to paint them so another 150 = 1395.
  26. Aug 31, 2019 at 10:01 AM
    #5186
    Pbear1454
    NorCal and SoCal
    2010 Tundra TRD
    Now I kinda remember the costs involved from prior threads.
    Thanks
  27. Aug 31, 2019 at 10:03 AM
    #5187
    Pbear1454
    NorCal and SoCal
    2010 Tundra TRD
    Dang that's like a parts upgrade for a bimmer :)
  28. Aug 31, 2019 at 10:10 AM
    #5188
    e30cabrio
    44.43 each & I needed the little plastic thing that goes between the truck & panel that was 6.80 each plus 11 shipping so 104.66 actually.
  29. Aug 31, 2019 at 11:14 AM
    #5189
    vhstejskal
    vhstejskal New Member
    Vic
    2010 Silver SR5 Crewmax
    Just replaced my front brakes. Factory rotors and pads all the way. :)
    kgb4187 and Mountun Goat like this.
  30. Aug 31, 2019 at 11:43 AM
    #5190
    TheBeast The Beach
    looks great. can't tell the difference between L and R imo
