  1. Oct 14, 2018 at 3:52 PM
    Guhner123
    Guhner123 New Member
    Gunner
    2017 Tundra SR5 MGM
    Toytec/Eibach 3/1 lift kit 295/70/18 TOYO AT 18 Inch Method NVs
    My methods are +25 offset. There’s a few threads on here where there’s a front liner mod where you can push the front fender liner forward. I’ll post some pics in a bit where the rubbing was occurring.
    Degausser[QUOTED] likes this.
  2. Oct 14, 2018 at 4:31 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    What size tire? To get more room, you remove the little mudflap in front of the wheel (and the one behind it if necessary).
    Then there's a liner most don't remove permanently because you'll get dirt and debris on the inside of the bumper where the fog lights are. However, that liner is being held by bolts coming from underneath, remove the bolts, push the liner forward, you can use a heat gun and roll it in with a bat. Make new bolt holes to hold it down and now you have extra clearance. The previous OEM holes don't matter, nobody can see them unless you're looking up as an ant.
    Watt maker and Guhner123 like this.
  3. Oct 14, 2018 at 4:35 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    It's a bad influence on all our wallets
  4. Oct 14, 2018 at 4:37 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    Step 1 of the Switch Pros install. This is all I’m gonna get done for a week or so. I need a “Complete idiots guide to wiring a Switch Pros Sp-9100”.
  5. Oct 14, 2018 at 4:41 PM
    Degausser
    Degausser New Member
    Kevin
    GA
    2024 LR SR5
    The tire size part is what I'm trying to figure out. I was thinking 295s, but I'm trying to avoid having to do a whole lot to make them fit.
    4x4_Angel likes this.
  6. Oct 14, 2018 at 4:46 PM
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    Don’t settle for anything less then 295s. The cutting isn’t major. And you’ll regret going smaller.
    Watt maker and Degausser[QUOTED] like this.
  7. Oct 14, 2018 at 5:10 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Are you lifted or levelled? I'm on 295/70R18, Method 18x9 offset +18 sticking out more than your +25. I removed all mudflaps and the fender mod I described, no rubbing at full steering lock either direction. I'm 2.5" higher than stock in the front.
    You may already know bigger tires on heavier rims take a mpg loss.
  8. Oct 14, 2018 at 5:37 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Very true!
  9. Oct 14, 2018 at 5:47 PM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    Sux I don't live in TX, good luck with them. Curious how they hold up, keep me posted after while.
    4x4_Angel and Cfincke[QUOTED] like this.
  10. Oct 14, 2018 at 5:54 PM
    Degausser
    Kevin
    GA
    2024 LR SR5
    Going to do the Toytec/Eibach 3" coilovers with 1.5" shackles in the back
  11. Oct 14, 2018 at 5:54 PM
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    That’s exactly what I’m running your gunna love it.
    MotoTundra and Degausser[QUOTED] like this.
  12. Oct 14, 2018 at 5:56 PM
    Degausser
    Kevin
    GA
    2024 LR SR5
    I've done lots of research on this site, and it seems like one of the best quality/cost combos you can get.
  13. Oct 14, 2018 at 6:22 PM
    mgm16trdpro
    Northern NJ
    Well, back at it again. Finally finished up cutting my log delivery into rounds to be split for firewood. Tundra related because I used the convenience of my bedslide to get gas, tools, saws, ect out the bed without having to climb up there to get the stuff toward the front. I also used my winch to get a couple of the bigger log lengths off the pile so they didn't roll on me and gave me more room to cut. Love the free heat but it's a year round job keeping up with it. This gigantic pile is probably half of what I'll burn next year.
    20181013_172830.jpg 20181013_172806.jpg 20181013_172817.jpg 20180608_181447.jpg 20180712_184000.jpg
  14. Oct 14, 2018 at 6:53 PM
    Craig.50
    Craig.50 New Member
    Craig
    2016 Tundra
    Finally got around to installing my...
    TRD PRO grille and headlights
    Installed led bulbs in headlights and fogs
    32" light bar behind bumper
    And my powder coated bumper end caps front and rear
  15. Oct 14, 2018 at 7:27 PM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    Thinking of buying that cover , is it as bad ass as they say?
    mgm16trdpro[QUOTED] likes this.
  16. Oct 14, 2018 at 7:31 PM
    Part_time
    Oregon
    Detailed the paint on the truck today. Removed tar,washed and polished. Took about 6 hours20181014_121703.jpg 20181014_175334.jpg 20181014_121703.jpg 20181014_175334.jpg 4
    Used nufinish
  17. Oct 14, 2018 at 7:31 PM
    Cfincke
    San Antonio
    Will do! Got the passanger side on this morning, took about an hour and a half from the time I walked out to the garage. Did it solo again in drizzle rain.
  18. Oct 14, 2018 at 9:01 PM
    chadh1972
    chadh1972 New Member
    Put my ProZ tri-fold tonneau cover on. Thank AutoAnything for the hook up on the tonneau and bed rug.
    Put my bed rug in.
    0B17076E-33C0-44AD-953F-61EA7975F083.jpg Got rid of the brown wood grain. Wrapped it in black textured wood that matches my Benz
  19. Oct 14, 2018 at 9:10 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    Sorry:(
  20. Oct 15, 2018 at 5:13 AM
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    Swapped my limited 2018 led headlights for the 2019 trd pro blacked out led lights
    Patch999, Pudge, MotoTundra and 3 others like this.
  21. Oct 15, 2018 at 6:06 AM
    mgm16trdpro
    Northern NJ
    I love mine. It's bulletproof.
    NewImprovedRon likes this.
  22. Oct 15, 2018 at 7:26 AM
    TunderStorm
    TunderStorm New Member
    Michael
    2018 TRD SR5 CM MGM +
    - Toytec/Eibach 3/1.5 + TC UCAs - Fuel Vapor 18x9+20 w/BFG KO2 35’s - TRD sway bar - Go Rhino nerf bars - badge delete - Bakflip MX4 - ESP storage - Rockford Fosgate 10’s +++ - TRD shift knob - Weathertech front mats - Escort 360 hardwired - Window tint Future mods: N-Fab M-RDS front bumper w/40” Black Series RC Lightbar
    You’re a sick man I’m almost considering doing this. They make a big aesthetic difference? Any pics before/after?
  23. Oct 15, 2018 at 7:27 AM
    ejd049
    ejd049 New Member
    2018 Tundra Crew Max TRD Off Road 4X4
    How do you like the Diamondback?
  24. Oct 15, 2018 at 7:51 AM
    Just stop this madness! :spending:
    I was thinking about this also. :rofl::rofl:
    I need to get banned so I stop spending money. :rofl:
  25. Oct 15, 2018 at 8:40 AM
    Austicus
    Austicus New Member
    Austin
    2014 White Tundra TSS
    3" Lift
    New running boards. First of many changes to come.
    Slowly I'll get rid of all this chrome! Not sure what the market is for TSS chrome running boards but as soon as I have 60 posts I'll be selling them!
    TomC843 and MotoTundra like this.
  26. Oct 15, 2018 at 8:54 AM
    mgm16trdpro
    Northern NJ
    What's the difference? Maybe I swap out my trd pro 16 non led lights for ur old ones?
  27. Oct 15, 2018 at 8:58 AM
    mgm16trdpro
    Northern NJ
    Love it. Depending upon your needs, it might just be the best cover out there.
  28. Oct 15, 2018 at 12:32 PM
    OkcthunderGuy
    OkcthunderGuy New Member
    Dustin
    OKC
    14 Tundra TSS
    the fun is just beginning
    LOVE this. Going to have to add it to the list of needs on my truck. and now youve also got me reevaluating my current lid setup. Ive currently got a ARE tonneau cover but yours look mean!
    philly[QUOTED] likes this.
  29. Oct 15, 2018 at 1:03 PM
    KMG
    KMG New Member
    Kevin
    Yacolt, WA
    2018 White Tundra Limited DC 4x4 TRD
    BFG KO2s, TRD Rear Sway Bar, Firestone RideRite Air Bags, B&W Gooseneck Hitch, Trail Ridge Extendable Towing Mirrors
    I replaced my factory Michelins with E rated BF Goodrich KO2s. I've had the KO2s on two other vehicles and loved them. The Michelins are a fine tire but not for a 4x4 truck.
  30. Oct 15, 2018 at 1:11 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    It's easy to get banned.....:)
    T-Rex266[OP] and philly like this.
