  1. Oct 7, 2016 at 6:39 PM
    #1981
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    How are they turned on and off?
  2. Oct 7, 2016 at 6:42 PM
    #1982
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    Ah gotcha. .40 sits toon tall
  3. Oct 7, 2016 at 6:58 PM
    #1983
    Cfincke
    San Antonio
    Lights are connected to the cargo light switch.
  4. Oct 7, 2016 at 6:58 PM
    #1984
    PMG
    PMG New Member
    Lol
    PMG
  5. Oct 7, 2016 at 6:59 PM
    #1985
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    What was the sight you got then from?
  6. Oct 7, 2016 at 7:01 PM
    #1986
    Cfincke
    San Antonio
  7. Oct 7, 2016 at 7:06 PM
    #1987
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Hmm. Luckily my .45 XDS fits!
  8. Oct 7, 2016 at 7:15 PM
    #1988
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
  9. Oct 7, 2016 at 7:56 PM
    #1989
    Cfincke
    San Antonio
    They do a good a good job, I changed out the upper cargo lights to LEDs also - mostly to have the same light color. The kit is the same kit dealers add onto trucks and charge $259 for.
    ChucklesToy likes this.
  10. Oct 7, 2016 at 8:23 PM
    #1990
    Muleycrazy13
    Muleycrazy13 New Member
    Buckeye, AZ
    2024 Chevy Silverado 2500HD Duramax
    If you dont mind, would you please measure how tall your tire is from the ground to the top of the tread?.... i have the 275/70 bfg ko2's and when i measure mine they are only 31.5" tall
  11. Oct 7, 2016 at 8:42 PM
    #1991
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    Type in your tire size and select the tire it'll give you all specs
    NewImprovedRon likes this.
  12. Oct 8, 2016 at 2:19 AM
    #1992
    TRDFaux
    TRDFaux Irresponsible Adult
    2014 Tundra SR5 Crewmax 4X4
    Toytec level and diff drop, Cooper STT Pro Tires, TRD Pro Grill, blacked out, debadged.
    I guess I just don't get the whole not wearing a seatbelt thing. I lost 2 friends in the past 6 month just because they didn't buckle up. One was in a relatively minor collision around 45mph and was partially ejected, the two occupants of the other car walked away and refused transport to the hospital. All of her injuries were due to the partial ejection and return to vehicle. The other was ejected while rolling down the embankment and the truck rolled on top of him. Both would be here today if they had put their belt on.
    anyone that says "well I only do it at slow speeds" has obviously never seen what an airbag deployment with out a restraint can do to someone.
    I guess it takes seeing it first hand and working a patient that isn't going to make it because they couldn't be inconvenienced.
  13. Oct 8, 2016 at 4:07 AM
    #1993
    Bigmoo
    Bigmoo New Member
    07 Tundra SR5 TRD
    I wanted to say the buzzer shuts off when you wear it... But to each his own, I'm on the road all day (Fedex) so I just always wear it and have been in two head on collisions, both were around 30mph glad I had it when the airbag went off. I also live in the city so lots more obstacles and bad drivers to deal with.
  14. Oct 8, 2016 at 5:49 AM
    #1994
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    I totally agree that over the road you should absolutely be wearing a searbelt. I too have lost friends and loved ones because of not wearing seatbelt. However some of us use vehicles for hunting/working or have dogs that ride up front with us. There's a time and place to wear belts and a time and place not to. That's why we bought these. For the times when seatbelt aren't necessary and don't want the annoying buzzing going off
  15. Oct 8, 2016 at 6:39 AM
    #1995
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    Muleycrazy13[QUOTED] likes this.
  16. Oct 8, 2016 at 8:33 AM
    #1996
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    My laptop bag is heavy enough to set off the buzzer. That is my main reason. I will always wear my seatbelt on the road.
    Actually it's just decoration as the description says.
  17. Oct 8, 2016 at 9:05 AM
    #1997
    Muleycrazy13
    Buckeye, AZ
    Thank you sir!
  18. Oct 8, 2016 at 9:11 AM
    #1998
    McLovin
    McLovin New Member
    Harry
    Maryland
    17' QS CM Limited, 14' MGM T4R SR5 Premium,
    Does anyone know if I can get this piece in black? It's the cupholder trim ring. If not, I'll just paint the bitch!20161008_120402.jpg Thanks.
  19. Oct 8, 2016 at 9:12 AM
    #1999
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    How was that to pry off and what areas on it did you lift up?
  20. Oct 8, 2016 at 9:14 AM
    #2000
    McLovin
    McLovin New Member
    Harry
    Maryland
    I just got my fingernails up under it in two spots opposite each other. Not a ton of pressure, popped right up without breaking any clips. Yay me!!
    NewImprovedRon and Wrongside like this.
  21. Oct 8, 2016 at 9:15 AM
    #2001
    Lol. Guess I should let my fingernails grow.
    Which spots? I think I'll try this. Need to paint it black I think
  22. Oct 8, 2016 at 11:58 AM
    #2002
    McLovin
    McLovin New Member
    Harry
    Maryland
    My nails aren't long. I used my thumb nails cause they are the strongest. I guess you could wrap a small screwdriver tip with tape and accomplish the same thing. I came from the direction of inside the cup holder. One finger on each side and just popped it up.
  23. Oct 8, 2016 at 12:00 PM
    #2003
    McLovin
    McLovin New Member
    Harry
    Maryland
    Thanks Ron, I think I'll give it a shot.
  24. Oct 8, 2016 at 12:13 PM
    #2004
    @Roman can u get these black?
  25. Oct 8, 2016 at 3:42 PM
    #2005
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    Finally got some time and weather in my favor and dressed up the truck a little more. I'll be doing that chrome center cup tray piece soon as well, now that I've seen it removed. Will probably plasti dip it vs paint, so the rubberized will soften the cans and such when they rattle inside there.
    For now though, here are some decals I had made from TacomaWorld member ruggedT.
    I also swapped out the head lights to just white lights to make it look cleaner and it was a quick and cheap resolve for now until I probably go LED.
    Lastly, I did some hood work. I find it softens sun glare and I like the continued look of my black on blue.
    ps. Yes I'm a Warcraft nerd, if you already don't know.
    Sixpack, geno0506, CaptTyler and 6 others like this.
  26. Oct 8, 2016 at 4:10 PM
    #2006
    Tacogeuse
    Tacogeuse New Member
    CO
  27. Oct 8, 2016 at 5:11 PM
    #2007
    Added security screws to the LP'S
  28. Oct 8, 2016 at 5:41 PM
    #2008
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    Installed TRD rear sway bar.
    AKJ78, scurdyness, 15whtrd and 7 others like this.
  29. Oct 9, 2016 at 12:06 PM
    #2009
    McLovin
    McLovin New Member
    Harry
    Maryland
    Ok, thanks.
  30. Oct 9, 2016 at 12:37 PM
    #2010
    Bigmoo
    Bigmoo New Member
    07 Tundra SR5 TRD
    Installed the Magnum RT steps
    419d65b9586f18f50fae772c95008a8e_fb253ffdb12fc6046890742ad3963168f30d23f6.jpgf3ab2c4feb7dc660caa4fd4406bbc402_1b692b160f3b0814d1c9aa6223d92ebec8ff2c5c.jpg
    zcarpenter92 and BB Stacker like this.
