  1. Oct 8, 2018 at 5:02 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Added the color matched front bumper caps over the weekend. It was a bit of a process but totally worth it. Grille, Surround and Bulge are next.
    Thanks to @Vizsla for hooking it up with the caps!
  2. Oct 8, 2018 at 5:32 PM
    2018Tundra
    2018Tundra New Member
    VA
    2021 Tundra Platinum
    Looks good! I’m about to have mine wrapped.
  3. Oct 8, 2018 at 6:21 PM
    TexasTJ
    TexasTJ New Member
    Toyota
    Before and after:
    Color matched Pro grill/bulge, SSO slimline bumper with bar, Baja LED bar, Baja fog lights, Smittybilt X20 with synthetic line and Factor 55 flatlink-E with fairlead.
  4. Oct 8, 2018 at 6:25 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    So, this is a bit much, but I am getting new AT tires and 6112 front and 5160 rears tomorrow. Today, I removed the TRD wheels, washed and waxed them front and back. Treated the wheel and hub with anti seize-changing a flat on these things would be impossible without a mallet to knock off the wheel! LOL, pretty over-the-top! Did the same with the spare
  5. Oct 8, 2018 at 6:31 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Wash, dry, and detailed the interior. Used my foam cannon for the first time today on the truck. Worked great!
  6. Oct 8, 2018 at 8:34 PM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    mine are on the way, do you know offhand what size Torx the bed bolts are?
  7. Oct 8, 2018 at 8:49 PM
    Cthulhu
    T55
    TomC843[QUOTED] likes this.
  8. Oct 8, 2018 at 10:01 PM
    solidsnake
    solidsnake New Member
    Colorado Springs
    2017 Lexus RX 350
    Finally got around to taking some pics of my mods.
    Lowmax tonneau cover was an amazing purchase prior to my cross country move.893AA2D2-1C51-4CA7-B67F-DECBA40CACD5.jpg
    Black stealth running boards to help the wife and daughter into the truck.
    Go figure I found this in a gas station in New Mexico. Should I put it in the bottom right corner of the rear window or in that blank spot on the right next to the license plate?
    I also have cheap rubber floor mats and a Rubbermaid storage caddy the wife bought to help keep the truck tidy.
    mgm16trdpro likes this.
  9. Oct 8, 2018 at 10:33 PM
    Paulskie
    Paulskie New Member
    Paul
    2014 Attitude Black 1794
    SABM, TRD sway bar, interior LED swap, Husky's in front and WeatherTech in the back, TRD Pro Grill, Rigid Fod lights, Rigid 40" E-series, Rigid 32" hood light, BLHM with RX350/STI projectors, 4% tint, 50% windshield.
    Thanks, much appreciated. Had a inverter for couple years now and with new S-pod, and upcoming road trip, this would be a best time. Thanks again.
    Hondoman[QUOTED] likes this.
  10. Oct 9, 2018 at 8:38 AM
    SAL45
    SAL45 New Member
    Sal
    2017 SR5 Tundra
    Took off those 'old man' style running boards and removed the front little mud flap!
  11. Oct 9, 2018 at 10:10 AM
    fatalkhaos
    fatalkhaos New Member
    2019 Tundra TRD PRO CM
    Sway Bar 20x10 Fuel Assault 295/55r20 Toyo AT
    Yeah i had them on my last Tundra. Nice board I just didnt have much luck with them
    maxcala[QUOTED] likes this.
  12. Oct 9, 2018 at 2:03 PM
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    Got these in today :bananadance:
  13. Oct 9, 2018 at 2:50 PM
    sbbrown333
    sbbrown333 MGM Wrecking Crew
    Blake
    2018 MGM Limited CM 4x4
    Installed Husky liners in the front and back (full coverage) today. 539A7571-9ADD-46C4-87FC-63368C7AC414.jpg
  14. Oct 9, 2018 at 3:22 PM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    The trash would be the best bet for that sticker. :thumbsup::thumbsup::thumbsup:
  15. Oct 9, 2018 at 5:53 PM
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    Finally chrome delete completed. Got the last of the chrome gone. Linexed bumper end caps.
    WFD473, aperezsh, WCM2014 and 14 others like this.
  16. Oct 9, 2018 at 6:19 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Looks good Tin,
    Also digging the bronze matched toyota lettering on the grill, great idea to pull those wheels to the truck somehow.
    What kinda fogs are those? I like the pod look, and the trim is perfect
  17. Oct 9, 2018 at 10:38 PM
    tinman10101
    Tinman
    2016 MGM Crewmax
    Thanks Sean! Those fogs are the Cali--raised 18W Amber with their tundra fog bracket. It was hard as hell to put the brackets on because of alignment issues. I had to bend the bracket several times and the lower mounting bolt was extremely hard to reach around and under to tighten from behind the end caps (maybe i got a bunk set). I tell you the only way I could attach the bolts for the bracket properly was to remove the end caps which I had to do anyways to get them linexed. In any case, the 18W amber are not as bright as I was hoping and if I had to do it again, I would probably get much higher output .That was my fault for not researching light output properly which I should have. In any case, they do blow away my oem fogs so I'm happy.
    Pudge[QUOTED] likes this.
  18. Oct 10, 2018 at 5:29 AM
    pizzabud
    pizzabud New Member
    USA
    18' 5.7 CM White
    It only took me 5k miles to figure this out....
    Tiamat, mrburns05, Larmand and 5 others like this.
  19. Oct 10, 2018 at 7:01 AM
    pizzabud
    pizzabud New Member
    USA
    18' 5.7 CM White
    . I accidentally discovered it lol
    NewImprovedRon likes this.
  20. Oct 10, 2018 at 9:16 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Mine still manages to fall off that little holder, though, especially if it’s windy.
  21. Oct 10, 2018 at 9:43 AM
    G2G
    G2G New Member
    Chicago
    2018 White Platinum Tundra
  22. Oct 10, 2018 at 11:03 AM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2025 sequoia MGM TRD PRO
    Stock horse
    Predator steps and bed cover all oem toyota
  23. Oct 10, 2018 at 11:51 AM
    sbbrown333
    Blake
    How do you like the bed cover? I'm in the market for one and considered going with Toyota's.
    KnuckleHD likes this.
  24. Oct 10, 2018 at 12:03 PM
    War_Wagon312
    Rich
    Stock horse
    I literally just had to put on but so far the fit finish feel great. And I had it installed at the stealership so now if anything goes wrong with it they're holding the bag. It's pretty low profile it's sticks up a little bit but I'm okay with the amount. I don't know how it will hold up as far as water and things like that but I'll definitely update you after the first rain storm
    aperezsh and sbbrown333[QUOTED] like this.
  25. Oct 10, 2018 at 12:23 PM
    womprat57
    womprat57 BABE the Big Blue Ox
    NH
    2014 SR5 DC 4x4
    Washed and vacuumed it after the auto starter was finished up.
  26. Oct 10, 2018 at 1:02 PM
    Pudge
    CT
    Looks great, best color out there!
    dandailey likes this.
  27. Oct 10, 2018 at 1:27 PM
    womprat57
    NH
    2014 SR5 DC 4x4
    I agree Pudge, thanks folks! I do like the metallic brown alot too, don't see many around.
  28. Oct 10, 2018 at 1:43 PM
    X2 :thumbsup:
    tinman10101 likes this.
  29. Oct 10, 2018 at 2:09 PM
    War_Wagon312
    Rich
    Stock horse
    I just bought a 5 gallon jug of this stuff. Is it OK to spray it on after i just sealed and waxed it? I did that a couple days ago. My jug should be here in a couple days I was gonna use this as maintenance to get through the winter. Then clay seal wax again in April.
    War Machine[QUOTED] likes this.
  30. Oct 10, 2018 at 3:19 PM
    War Machine
    War Machine SSEM # 5 3MW
    I don’t see why not. Shouldn’t cause any issues, I used it in top of another sealant. (Hydro2)
    I don’t use wax, so I don’t know how that might affect it. Might shorten the longevity maybe? I know wax doesn’t stay as long as sealer.
    Pudge and War_Wagon312[QUOTED] like this.
