  1. Aug 3, 2018 at 7:13 PM
    geno0506
    geno0506 New Member
    Michael
    Thanks Brudda! :cheers:
  2. Aug 3, 2018 at 7:16 PM
    geno0506
    geno0506 New Member
    Michael
    Thanks, so is there a little hole on that you run the zip tie through on the right of the pic, any picture of that part! Thanks brother!
  3. Aug 3, 2018 at 7:17 PM
    geno0506
    geno0506 New Member
    Michael
    Me so :jellydance::jellydance::jellydance::jellydance::jellydance::jellydance: :yes:
  4. Aug 3, 2018 at 7:31 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    There are 2 slots that 2 brackets slide into, the brackets look like they'd get screws or bolts but they just slide into 2 slots. I put the zip tie through the slot after I put the lights in. It may have gone through the hole in the light bracket but I couldn't see for sure. You'll see where I'm talking about when you get in there and look.
    geno0506[QUOTED] and Sas like this.
  5. Aug 3, 2018 at 7:34 PM
    Pudge
    CT
    I like those. Is this the kit from VLED?
    The OEM light is so tiny and dim, when do those lights come on? I thought about running some flexible LED strips to the interior lights somehow but the kit looks so easy
    geno0506 and reaper3030[QUOTED] like this.
  6. Aug 3, 2018 at 7:39 PM
    reaper3030
    reaper3030 New Member
    Charles
    Tundra 2018 SR5 4X4 Concrete Crewcab
    Rock star wheels, off road tires, LED interior lights, LED fog lights, and .50 cal antenna.
    Yep vled and you unscrew the little light from under dash and plug in adapter where the bulb comes out then stick it on. Super easy and looks so much better.
    geno0506 and Pudge[QUOTED] like this.
  7. Aug 3, 2018 at 7:42 PM
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    Can you link us, please?
    geno0506 likes this.
  8. Aug 3, 2018 at 7:45 PM
    Pudge
    CT
  9. Aug 3, 2018 at 7:46 PM
  10. Aug 3, 2018 at 7:46 PM
    Pudge
    CT
    When do the lights come on? And is there a switch somewhere that turns them on if needed? Thanks man
  11. Aug 3, 2018 at 7:48 PM
  12. Aug 3, 2018 at 7:50 PM
    Pudge
    CT
    I'd assume the light with some blue hue to it travels faster that just plain old white. :p
    Cfincke and NewImprovedRon like this.
  13. Aug 3, 2018 at 7:50 PM
    Think 5500 the the brightest white light and 6000 has a blue tint to it.
  14. Aug 3, 2018 at 7:50 PM
    White one turns on faster
    Wait
    Wut
  15. Aug 3, 2018 at 7:50 PM
    reaper3030
    Charles
    When you open door until you start engine. Here you go:
    http://www.vleds.com/tundra-fwk-front.html
    Pudge[QUOTED] likes this.
  16. Aug 3, 2018 at 7:51 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
  17. Aug 3, 2018 at 7:51 PM
    reaper3030
    Charles
    Yep I got 5500 pure white
  18. Aug 3, 2018 at 7:53 PM
    geno0506, Pudge and Jim LE 1301 like this.
  19. Aug 3, 2018 at 7:54 PM
    :thumbsup:
    T-Rex266[QUOTED][OP] likes this.
  20. Aug 3, 2018 at 7:55 PM
    Albertaundra
    Albertaundra aka...IgnorantlyAlberta
    David
    '16 SR5 crewmax TRD, '06 Taco walletbreaker
    Bone stock tundra...
    Looks good! Now lets see the entire truck:thumbsup:
    Welcome to the forum!
  21. Aug 3, 2018 at 8:09 PM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    What u use for the red lettering in the iforce badge, rest looks great. Love the sill in red, might have to do same. Any reason u did not do the 5.7 L on the badge too?
  22. Aug 3, 2018 at 8:38 PM
    mgm16trdpro
    Northern NJ
    For u guys asking bout vled footwell. I did it long time ago but pretty sure I explained it all in build with pics of product, package and install. I did it June 24th of last year if u want to skim to that part. To sum, pull tiny out under wheel. If u do this way the lights will come on when door is opened or unlocked, then shut off after time with doors shut or starting engine. All u have to do is look at the tiny barely noticeable factory bulb in there now. U will see when it comes on n goes off, since they run in line off that they will all come on n go off the same times and in unison when that one does. Insert their strip to there, fix under dash, then they supply u with a connector wire off their led strip.
    All u got to do is keep connecting strip to length, strip to length. I found mine was easiest to go around middle console hiding wires under the sides of it right around. The order I went driver to rear driver across to rear passenger then back upfront to passenger. Little gorilla tape under front dash and front seats does the trick. Just make sure u adjust wire length so that seats can move forward and back without pinching wire. It hides nicely up inside the bottom sides and back of the middle console. U can also run along sill but I took the easiest way.
    They have all different white bulbs like mentioned above. Around 5k is purest white, below is yellow, and above around 6k blue tint. Very quality product still no issues and had over a year.
    Hope this helps. Everyone who's asked me about and I pointed in direction was thrilled to do the same. Good luck, happy modding.
    jmdaniel, JoshuaA, GAknight and 5 others like this.
  23. Aug 3, 2018 at 8:45 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    The HYBRID badge really pisses me off. I'm pissed because I didn't think of it first.
    Kudos sir. I tip my hat.
  24. Aug 3, 2018 at 8:47 PM
    reaper3030
    Charles
    Yea I like that as well.
  25. Aug 3, 2018 at 9:35 PM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    My kids wanted to decorate cars for their championship swim meet this weekend so I directed them to my wife's car (leaving the Tundra window-paint free :thumbsup:).
    GAknight, Baja Mike, geno0506 and 3 others like this.
  26. Aug 3, 2018 at 9:55 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    My daughter and I installed these racks today. I'm going to take off the colorful brand logo on each of the posts...
  27. Aug 3, 2018 at 9:57 PM
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    I just smiled at all the dirtbikes.
  28. Aug 3, 2018 at 10:58 PM
    geno0506
    geno0506 New Member
    Michael
  29. Aug 4, 2018 at 5:05 AM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Installed blackout vent rings.
  30. Aug 4, 2018 at 5:36 AM
    neoflex
    neoflex New Member
    Charlotte. NC
    I bought all the vinyl from TVD. The badge kit doesn’t come with vinyl for the 5.7 but I’m liking that a good bit of the badge is still very much blacked out. Who knows maybe I’ll eventually create that portion myself to have vinyl cut.
    mgm16trdpro[QUOTED] likes this.
