  1. May 24, 2018 at 8:16 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    LKSR5-14[QUOTED] likes this.
  2. May 24, 2018 at 8:25 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    No, it does not. I AutoDipped the whole thing:
    There's also a black TRD shift knob, which I don't have dammit.
  3. May 24, 2018 at 8:35 PM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    No good for just using the top of the cover as the base? If not, what about laying a couple temporary cross bars across my existing bed cover rails when using the tent? Would the cross bars need to bolted down or could I get away with just laying across or finding a way to tie them down to my existing rails?
  4. May 24, 2018 at 8:44 PM
    Vizsla
    Vizsla 2 = 2.5
    You need a rail/bar with space underneath for the RTT mount hardware. This pic should give you the idea.
  5. May 24, 2018 at 8:45 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Depends how many lbs your rails can hold. Safe route would to bolt on cross bars that have quick releases if you are not running them. Either way a rtt is heavy and you want to properly secure it.
    Sunnier and mgm16trdpro[QUOTED] like this.
  6. May 24, 2018 at 8:59 PM
    Vizsla
    Vizsla 2 = 2.5
    Very nice! What secondary mount is that?
  7. May 24, 2018 at 9:09 PM
    On-the-Bayou
    On-the-Bayou New Member
    James
    NW Louisiana
    2015 Silver Tundra SR5 DC
    BAMuffler, Bilstein 5100s
  8. May 24, 2018 at 9:35 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    YES.....
    I like what you did there sir....
    Sunnier and Baja Mike[QUOTED] like this.
  9. May 24, 2018 at 9:37 PM
    finn
    finn New Member
    Ryan
    Did you make that shovel mount?
  10. May 24, 2018 at 10:12 PM
    mgm16trdpro
    Northern NJ
    Tnx and @BlueBottle the info and especially the pic helps answer my questions. I appreciate the info.
    Sunnier likes this.
  11. May 24, 2018 at 10:13 PM
    joshoward
    joshoward New Member
    2016 Metallic Gray Tundra TSS
    New 3" BOSS @Toytec Lifts coil overs and SPC UCAs. This has been a pricey month with extang tonneau, try pro grill, husky floor liners and lift. What should I do next? I need bigger tires for sure - currently KO2s at 285x55x20
  12. May 24, 2018 at 10:38 PM
    ZPMAN
    Minnesota
    Supercharger???:burnrubber:
    Sunnier and joshoward[QUOTED] like this.
  13. May 24, 2018 at 10:58 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    I put some gas in it.. and I still had 20 more gallons to fill..
  14. May 25, 2018 at 3:28 AM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    :eek:
  15. May 25, 2018 at 5:13 AM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Mines rides better with tires and level too.
    Everyone asks me about my mileage and my response is: who cares, didnt buy the truck as a commuter.
    What size tires do you have?
    4x4_Angel[QUOTED] likes this.
  16. May 25, 2018 at 5:46 AM
    matt kruckenberg
    matt kruckenberg New Member
    slc ut
    2015 Trd Pro Inferno
    Scratched the F out of my rim
    Anyone in utah want to sell me one
  17. May 25, 2018 at 7:54 AM
    Vizsla
    Vizsla 2 = 2.5
    Yes sir.
    4x4_Angel likes this.
  18. May 25, 2018 at 7:54 AM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    Installed ultragauge, still unsure where I want to mount it. One thing is for sure these trucks run hot on the trans fluid side, it's between 185-196 without me pulling my trailer today. 20180525_105307.jpg
  19. May 25, 2018 at 8:06 AM
    MakMurph
    MakMurph I'm here
    Great communist state of New York
    2019 Super White TRD PRO
    Window tint,RB20 running boards,Falken wildpeaks 295/70/18, CB +2 shackles, CB bumper shim kit, TRD rear sway bar, spidertraxx 1.25” wheel spacers,
    Put my rb20’s on now I can clean my roof
  20. May 25, 2018 at 8:09 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    295/70/18
  21. May 25, 2018 at 8:52 AM
    Nike21
    Nike21 New Member
    2018 SR5 CrewMax TSS 4X4 Black Beast
    Sweet!! You're gonna enjoy riding him!! Congrats. :cheers:
  22. May 25, 2018 at 8:54 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    Thanks!
    Erichudgins and Nike21[QUOTED] like this.
  23. May 25, 2018 at 11:55 AM
    bowhun2r
    bowhun2r New Member
    Scott
    Steeler Nation
    FedEx just dropped off my painted mirror caps and handles :) from Sparks.
    Handles were very easy. If anyone is concerned with the screw falling into the door...it is attached to the plastic insert thing. You can confidently unscrew w/o worrying if it will fall out.
    The mirror caps... They were a bit more challenging both coming off and putting on. It felt like the tabs would break, but they didn't. The bottom part of the cap is where to start (I found it easier to start on the bottom corner closer to the window) and get a pry tool to push up. After some pressure you will hear the tabs disengage. Then pull straight off. Putting caps on, set the bottom tabes first as then slide down, then the middle and tops push in. Had to again put more pressure than I initially thought I would.
    I will put my chrome handles and mirror caps for sale in the marketplace forum.
  24. May 25, 2018 at 2:33 PM
    Stroke250
    Stroke250 New Member
    Todd
    Idaho
    2023 Ford F-350
    Got the tonneau installed. Tonno Pro from AutoAnything. 4200 reviews with a 4.5/5 rating and a price that can’t be beat. Time will tell how it does. Quality seems very good!
  25. May 25, 2018 at 2:41 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    I have the same one. Love it. Zero leaks in the time I've had it. Just keep an eye on the front latches.
    Stroke250[QUOTED] likes this.
  26. May 25, 2018 at 2:45 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Very nice!
  27. May 25, 2018 at 2:51 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Gotta love Cali. Gas is over a dollar less per gallon here..lol
  28. May 25, 2018 at 3:08 PM
    Stroke250
    Todd
    Idaho
    2023 Ford F-350
    They come loose? I have rubber in there between the clamp and bed and they are cranked down good as can be with them being a plastic “nut”.
  29. May 25, 2018 at 3:17 PM
    Baja Mike
    South Bay, Ca.
    Not loose, but they shift around around over time/driving/vibration. They haven't come off completely, but they can turn. Opener an closing the tailgate will move the cover around.
  30. May 25, 2018 at 3:38 PM
    jaredmillerdvm
    jaredmillerdvm Mods will never end!!
    Anderson, SC
    2018 MGM CM SR5 TRD Off Road 4x4
    Rough Country 3in leveling kit, SCS Ray 10s, 295/70/18 Toyo Open Country AT2 Extremes. TRD Shift Knob, Console Safe, Driver Side Grab Handle, WeatherTech Laser Measured Floor Liners, Katzkin Heated Leather Seats, Remote Start, TundraTex Frac Harness, Radio Vinyl Inlays, LED Interior Lightening. MGM Color Matched Hood Bulge and Surround, 18% Tinted Front Windows, 90% Ceramic Windshield Tint, 5% Banner, AntennaMast Stubby Antenna, Predator Step Bars, Skid Plate with Integrated Step, Line-X Spray in Bed Liner, Blacked Out Badges, Mirrors and Door Handles, Black Bedside Decals, Bak Revolver X2 Tonneau Cover, Swing Case Tool Boxes, DIY Tailgate Lock, Deck Rail System, Recon Smoked LED Tail Lights With LED Reverse Lights, Smoked Vinyl Wrapped Cargo Light, LED License Plate, Cargo, and 3rd Brake Lights, Dirty Deeds 8" BAMuffler, Black Powder Coated Front and Rear Bumpers, TRD Rear Sway Bar.
    Put these Swing Cases in when I first bought my truck along with the Revolver X2 by BAK.
