  1. Mar 29, 2018 at 4:40 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Love how you have the heimholtz intergrated! What size mufflers did you go with?
  2. Mar 29, 2018 at 4:43 PM
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    It was the 16x something cant remember off the top of my head. Its def more aggressive then stock trd duals and not annoying in the cab. Had to keep it kinda mild for my lil one and the wife.
  3. Mar 29, 2018 at 4:59 PM
    BayRunner
    2017 Tundra Platinum
    Looks good! I recently had mine done by a local shop custom fit using the high quality 3M vinyl. He used string tape to get the exact shape desired with no cutting. I think it turned out well.
  4. Mar 29, 2018 at 5:08 PM
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    * single unit box versus old 2 piece design, still has side open option
    * has 3 base attachments versus 2
    * tube is more fluid and connects to throttle body easily
    * MAFS they provide a gasket, rubber seal, 2 new screws
    * top seal is recessed and sits on a rubber gasket
    * screws are cooler looking and comes with 5 versus 4
    *most importantly it fits like a glove with easy installation
  5. Mar 29, 2018 at 5:17 PM
    geno0506
    geno0506 New Member
    Michael
    Sexy at its sexiest!
  6. Mar 29, 2018 at 5:18 PM
    BayRunner
    Looks good. I've been eyeing this as well. Anyone wanting the new design should call and specifically ask for it. They told me that there are still some of the older design In Inventory and will be shipped first until they run out unless you ask for the new design.
    Watt maker likes this.
  7. Mar 29, 2018 at 5:19 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Yes it’s the same price too
  8. Mar 29, 2018 at 5:22 PM
    BayRunner
    Did it change the sound any?
  9. Mar 29, 2018 at 5:26 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    From stock yes anything over 2.5-3.75 rpm you can tell, over 3.75 you feel it. But need to try drive normal so I can compare from stock.....oh well guess I will wait til I have to fill up and start then, for now WOW
    mgm16trdpro and Watt maker like this.
  10. Mar 29, 2018 at 6:16 PM
    BayRunner
    Cool. How long did it take to install the new design?
  11. Mar 29, 2018 at 6:42 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    I’ve installed cai before, and really OCD about things so safe to say 1.5 hrs but could easily be about 40 minutes as it’s pretty simple. Everything fit perfect no need to force things. S&B really did a great job with the redesign. And FYI so far got 1.75-2 mpg more in city driving, probable could have gotten over 2 but any open chance had to see what this beast is hiding and made off
    cjmay13, easleycrawler and Watt maker like this.
  12. Mar 29, 2018 at 6:55 PM
    IndyTundra
    IndyTundra Did someone say beer?
    Ronnie
    Indianapolis, IN
    2015 Radiant Red SR5 CM TRD
    Toytec, 34" Ridge Grapplers, MBRP Exhaust, Linex'd TRD Pro grill
    Thanks. Seems to drive pretty good. Runs straight on the interstate at speed. I'l deff let it settle then take it back. Would you suggest a less negative camber?
  13. Mar 29, 2018 at 7:00 PM
    BayRunner
    I like it. Seeing the new design in your truck I think seals the deal for me. Gives me something to spend tomorrows pay check on. :)
  14. Mar 29, 2018 at 7:03 PM
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    Total was $1029, but thats because i wanted stainless steel
  15. Mar 29, 2018 at 7:25 PM
    dradd
    dradd Sometimes there is just us
    City of Champyinz
    '17 TRD Pro
    pending...
    Today I did a few things.
    1. Installed color matched door handles. Thank you @SparksParts.
    20180329_215628.jpg 20180329_155241.jpg 20180329_155238.jpg 20180329_160227.jpg 20180329_160224.jpg
    2. Swapped 3rd brake light and cargo lightbulbs for LED.
    3. Installed Pop & Lock.
    Jagamov, Ortho281, GAknight and 10 others like this.
  16. Mar 30, 2018 at 2:10 AM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Here’s a little helpful tips on the new installation:
    *when bolting the box to the engine bay, do the center 1st but leave a little slack to give some play. Then do the back as it’s a hard spot, then do the front and make sure the rubber bushing and screw are all the way out so you can hand tight. Then lock all in place
    *when installing the rubber connectors that connect the throttle body and air tube, instal to the tube 1st and slides in to throttle body easier and tighten.
    *when installing the rubber gasket that goes around the top of the box which the clear cover will sit on, go about 1/8” over so there a little pressure to keep the seal seated better
    *last but not least. Try and go easy on the foot just so you can see that your investments yields a better mpg and then you can enjoy what it was made for.....hehe
    .......I was getting 12 mpg city driving and this is what I got so far in city driving, have to admit could have gone over 2mpg but had a hard time opening it up when possible...lol
  17. Mar 30, 2018 at 8:33 AM
    d0zer
    d0zer I beat the internet.
    Definitely somewhere
    2017 MGM Platinum
    ADS 3.0" & 2.5" AllPro APEX Sliders SCS SR8 on Cooper ST MAXX 295/70r18
    TAX18 at RCI
  18. Mar 30, 2018 at 8:52 AM
    WatTundra
    WatTundra New Member
    Kenny
    FTW, TX
    2016 MGM Tundra
    Stock as a rock minus tint
    I might have done something similar but with TAX10
    d0zer[QUOTED] likes this.
  19. Mar 30, 2018 at 10:49 AM
    Brimaster
    Brimaster New Member
    2017 Magnetic Gray Metallic DC TRD
    Finally had some time and was able to install the TRD skid plate I picked up from the_midwesterner back in Dec. Next have to get to the demello sliders....
    mgm16trdpro likes this.
  20. Mar 30, 2018 at 10:58 AM
    cd121082
    cd121082 New Member
    chris
    Washington State
    2016 Silver Tundra TRD OffRoad
    none yet
    MPG gains?
  21. Mar 30, 2018 at 11:53 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    MPG will probably go down cause I’ll be spending more miles off-roading!
    More smiles per mile, perhaps....:yes:
  22. Mar 30, 2018 at 12:20 PM
    BayRunner
    Thanks for the tips. I'm sure they will come in handy.
    PaulROahu[QUOTED] likes this.
  23. Mar 30, 2018 at 12:37 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    You'd NEVER GO BACK :anonymous:
  24. Mar 30, 2018 at 4:31 PM
    obz
    obz Not a New Member
    Utah
    Went from this...
    To this...
    mxz83, TomC843, Ortho281 and 16 others like this.
  25. Mar 30, 2018 at 4:56 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    I did that as well....and I don't find myself using it .....i use my runningboards to step into the truck....and I don't even grab my steering wheel......Oh well....Still nice to have
  26. Mar 30, 2018 at 4:57 PM
    obz
    Utah
    I don't know how much I'd use it either, but she wanted it pretty bad. She's short so that may be the reason.
  27. Mar 30, 2018 at 5:01 PM
    geno0506
    geno0506 New Member
    Michael
    My favorite mod!
  28. Mar 30, 2018 at 5:02 PM
    geno0506
    geno0506 New Member
    Michael
    Your still young and the force is yet with you!
  29. Mar 30, 2018 at 5:03 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    Lol.....yeah.....a young 52
    geno0506[QUOTED] likes this.
  30. Mar 30, 2018 at 5:05 PM
    geno0506
    geno0506 New Member
    Michael
    Better then an old 57,
