  1. Mar 27, 2018 at 8:45 PM
    RoVASr5
    RoVASr5 New Member
    Daniel
    Lynchburg, VA
    '14 Tundra CM MGM
    Gibson Metal Mulisha Exhaust BDS Suspension Lift - 7 Inch Icon Dynamic 2.5 coilover reservoirs 18 "Moto Metal 18x9 +18 37x12.5R18 Federal Couragia MTs DV8 Front Bumper
    Yes Sir! And thank you!!!
  2. Mar 27, 2018 at 9:15 PM
    NCinCO
    NCinCO Is it Friday yet?
    Gary
    Thornton, CO
    2018 Smoked Mesquite Limited CM TRD
  3. Mar 27, 2018 at 9:23 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    No......would like it though. ..in gunmetal :thumbsup:
  4. Mar 27, 2018 at 10:21 PM
    geno0506
    geno0506 New Member
    Michael
    Hello all,
    I installed my 2018 LED headlights on my 2017 a couple months back!
    I have noticed that the front drivers side beam seams a little higher then the pax side! I bought a long screwdriver to make the adjustments now!
    Question:
    How do I know if the drivers side is high or the pax side is to low, meaning which side is correct before I start or would I just assume the drivers side is the incorrect height and just adjust it lower, or do I leave that height and adjust the pax side up!
    If I make any sense, any advice thanks
    I do have the Video on adjusting and the correct height for each, just wondering which side to adjust so I can use the in cabin manual light hi or low adjustment after I set the headlights themselves
    Thanks
  5. Mar 27, 2018 at 10:55 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    Yes, you do make sense. In the video instructions, he said there is a mark that you can use in the headlight lens to begin your measurements. You should be able to follow his steps to measure from the mark to the ground, mark the same height on a board or some flat surface that you can use from several feet away and it will be obvious which one is incorrect.
    When I replaced headlights on my older Tundra when they got too cloudy, I used my garage door to mark a baseline before removing the old fixtures. So, I did it the same way again... before I removed the 2016 headlights, I marked the level of the low and high beams on my garage door with headlights on from 15 feet away. Then, after changing to the 2018 headlights, I checked the beams from the new headlights against the marks from the 2016 baseline (both were level for 2016; driver side was higher for 2018) and then adjusted the driver side down to match my previous readings. Since you don't have a baseline, I would use the method he talks about in the video...most of the comments I've read have been the driver side.
    Watt maker likes this.
  6. Mar 27, 2018 at 11:08 PM
    geno0506
    geno0506 New Member
    Michael
    Thanks,
    So it would be safe to say the drivers side is to high and should I leave my in cabin headlight dial set at zero first, thanks for the help!
  7. Mar 27, 2018 at 11:23 PM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
  8. Mar 27, 2018 at 11:24 PM
    seniramsu
    Nate
    VA
    Very niCe touch gentlemen!!!:thumbsup::thumbsup:
  9. Mar 28, 2018 at 12:47 AM
    NCinCO
    Gary
    Thornton, CO
  10. Mar 28, 2018 at 1:41 AM
    geno0506
    geno0506 New Member
    Michael
    Thanks for making me piss myself!
    ZPMAN and NCinCO[QUOTED] like this.
  11. Mar 28, 2018 at 5:13 AM
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    thats a big ol hook!
  12. Mar 28, 2018 at 5:15 AM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    Size does matter lol
    geno0506 likes this.
  13. Mar 28, 2018 at 5:16 AM
    sjrash
    sjrash New Member
    Scot
    2018 TRD Sport
    Is there a brand name on your tri fold?
  14. Mar 28, 2018 at 5:57 AM
    itsdchz
    itsdchz 50statesoverland
    Clovis, CA
    2018 SR5 CM Cement 4x4
    Icon, UCAs, Method, SSO, KB VOODOO, Skids and Sliders
    Nameplate is the bare metal version that comes with the raw sliders. It will most likely start to rust, which I do not mind unless it gets real bad. Going for the rat rod, rusty gold look... maybe..
    TRD15559 likes this.
  15. Mar 28, 2018 at 6:39 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    I would start with the drivers side...with leveling adjuster on zero
    geno0506[QUOTED] and Watt maker like this.
  16. Mar 28, 2018 at 7:10 AM
    geno0506
    geno0506 New Member
    Michael
    Will do, thanks! :cheers:
  17. Mar 28, 2018 at 8:30 AM
    Brian0414
    Brian0414 Doomsday
    Tucson, AZ
    2017 Tundra Limited 4x4
    - Winjet Black/Smoke Fiber Optic LED Tail Lights Bilstein 5100
    @YTThao530 Looks good! Is that vinyl? If so, Did you have to cut the piece yourself?
  18. Mar 28, 2018 at 8:45 AM
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    once they are on, its going to be tough to get them off....
  19. Mar 28, 2018 at 9:49 AM
    mgm16trdpro
    Northern NJ
    Hopefully don't have to find out. But if someone hits me I'm not gonna feel sorry ripping their front bumper or whatever else comes off as I stomp on it forward.
    Stulloh[QUOTED] likes this.
  20. Mar 28, 2018 at 10:16 AM
    JRPro
    JRPro Snappin’ necks & cashin’ checks
    Rich
    Austin, TX
    17 TRD Pro CM Cement
    Bought these. Apparently there were only 8 left in the US, so I got 5 of them. Sorry to whoever is pissed off out there now...
    JohnJr, GAknight, Paulskie and 5 others like this.
  21. Mar 28, 2018 at 10:50 AM
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    Coil overs (3”) and 295 tires, ESP storage, grab bar; RCI skids; tinted windows; rear air bags
    Thanks.
  22. Mar 28, 2018 at 11:25 AM
    geno0506
    geno0506 New Member
    Michael
    Thats what she said! :rofl:
    mgm16trdpro likes this.
  23. Mar 28, 2018 at 12:29 PM
    YTThao530
    YTThao530 New Member
  24. Mar 28, 2018 at 12:42 PM
    YTThao530
    Yeah I did myself was easy.
    Every mod on truck did it by myself only the lift has to cut cross member so let a shop do it for me.
    SouthBoundSteve likes this.
  25. Mar 28, 2018 at 12:46 PM
    itsdchz
    Clovis, CA
    Did mine myself:
  26. Mar 28, 2018 at 3:13 PM
    Tundra Girl
    Tundra Girl New Member
    Maddy
    New York, Long Island
    2017 Tundra Limited Metallic Black
    TDR Sway Bar
    I haven't posted in a while due to tight schedule and my car has been in the shop! I finally got it blacked out!!! Not sure if I want to do the rims. Next step is ceramic coating.
    Annnnddd I finally got my plates in!!!!
    SPhotoEditor-20180322_135733.jpg IMG_20180328_173402522_HDR.jpg IMG_20180328_173350019_HDR.jpg IMG_20180328_173414559_HDR.jpg
    And no I did not leave the car parked like that before someone says something!
  27. Mar 28, 2018 at 3:39 PM
    itsdchz
    Clovis, CA
    I see nothing wrong with your parking job.....
  28. Mar 28, 2018 at 3:40 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    :headbang: :headbang:
    Tundra Girl[QUOTED] likes this.
  29. Mar 28, 2018 at 3:43 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    I park like that all the time, no one needs to get close.
    Great job on the murdering...
    NewImprovedRon and Tundra Girl like this.
  30. Mar 28, 2018 at 4:34 PM
    Marty McFly
    Morty McBoonJug
    Your truck is looking awesome :thumbsup:
    I vote for blacked out rims :alien:
