  1. Sep 17, 2025 at 4:55 AM
    OHwendTrd
    OHwendTrd Aging Member
    2021 SR5
    ATF Cooler, FRAC, RCI Skid, Bilstein 6112/5160
    THANK YOU! :burp: cart so far below... Anyone know if this is all I need (or anything I don't need) for a full brake replacement (front/rear)? TIA
    2 Front Brake Rotor. 43512-0C020
    2 Rear Brake Rotor. 42431-0C011
    1 Front Disc Brake Pad Kit. 04465-02440
    1 Rear Disc Brake Pad Kit. 04466-02340
    1 Anti-Squel Shim Kit Front. 04945-0C040
    1 Anti-Squel Shim Kit Rear. 04946-02110
    4 Pin with Hole. 90240-06024
    2 Pin Hold Clip. 90016-AS903
    1 Disc Brake Fitting Kit Front. 04947-0C030
    1 Disc Brake Fitting Kit Rear. 04948-02140
    12 ATF WS. 00289-ATFWS
    8 Spark Plugs. 90919-01191
    8 Spark Plug Tube Gaskets. 11193-70010
    $450
  2. Sep 17, 2025 at 4:58 AM
    Correct. You will need a harness. @iHacker has those and there is a thread on it.
  3. Sep 17, 2025 at 5:03 AM
    TBS
    TBS New Member
    2021 SR5 CrewMax 4x4 Barcelona Red
    E50 extinguisher, Valhalla Plates, ESP Storage, Chrome Delete, Pwr Tailgate Lock,
    bulldog93 and HulkSmurf14 like this.
  4. Sep 17, 2025 at 5:39 AM
    SND Racing
    SND Racing New Member
    2020 Tundra Limited TRD Off Road Crewmax
    2 inch lift, Fuel wheels, cat back exhaust, Diode Dynamics amber front lights, ARE topper, custom storage boxes, and more...
    Updated and completed.
    Boneskull420 likes this.
  5. Sep 17, 2025 at 5:50 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    I could be mistaken but I'm pretty sure all 21' TRD Sport came with LED headlights from the factory.
    Toe404 and woods like this.
  6. Sep 17, 2025 at 6:02 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    mine did.
    Gaston[QUOTED] likes this.
  7. Sep 17, 2025 at 6:24 AM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM Tundra & 25 TRD Pro Sequoia
    Truck came factory equipped with LED headlights and fog lights.
    BR73[QUOTED] and Gaston like this.
  8. Sep 17, 2025 at 6:32 AM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    Did you install a switch and relay for the light bar wiring harness or tap it into the factory headlights wiring?
  9. Sep 17, 2025 at 6:51 AM
    xcalbr2
    xcalbr2 New Member
    Is the discount code a one time deal? I tried to use it for a 2nd order today and it said "please enter a valid code".
    Thanks,
    X
    BR73 likes this.
  10. Sep 17, 2025 at 6:54 AM
    Sent you a PM
  11. Sep 17, 2025 at 7:02 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Only once per signed in user...make an account for your wife!
  12. Sep 17, 2025 at 7:40 AM
    xcalbr2
    xcalbr2 New Member
    what was/is the code for originally? Can you use it once a year etc?
    thanks,
    X
    HulkSmurf14 likes this.
  13. Sep 17, 2025 at 7:56 AM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    the NSV light bar is the most pain in the ass install of any lightbar ive delt with.
    the wiring ties into the headlight/turn signal stalk. the harness that connects to the light ties into the front turn signals and headlight ajustment motor. there are piggy back harness that connect to those plugs. Ive researched everything I can find, re-pinned the connectors, doubled checked my work. Im pulling my hair out here..
    Yota303[QUOTED], HulkSmurf14 and BR73 like this.
  14. Sep 17, 2025 at 8:29 AM
    HulkSmurf14
    2014 Tundra Limited
    But damn, it's pretty rad how well it works, IMHO...I've had the version 2 bar and converted it to the verison 1 that offered strobe at the time....the version 3 makes it impossible, now...I didn't care for the DRL lights so I made that one (pin 8 to pin 5) into the strobe. Works great and is very usable light for my needs. Some throw dislike to it on the bar's output but it works great for me!
    Boneskull420 and Yota303 like this.
  15. Sep 17, 2025 at 8:47 AM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    yeah, looks wise its killer! im also not racing the baja 1000 so I dont did the output of the sun. I doubt I would have ever bought it new, but for 250 bucks it was impossible to pass up. I believe that I might have the gen 1 bar becuase it came with the strobe switch panel. the wiring kit was brand new, but the lightbar was used. so I think I have a newer gen wiring kit with the old light bar...
    thats the only conclusion I can come to since the DLR wont turn off. I assume the strobe feature doesnt work due to the pin 3 not being used... so If I wanted to use the strobe feature, assuming my light bar is gen 1, then would I just remove pin 8 and put it into pin 3 position?
    if I cant turn off the DLR and I dont have strobe, I might as well "enable" the strobe feature.
    HulkSmurf14[QUOTED] likes this.
  16. Sep 17, 2025 at 9:33 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    did you smack the muffler and cats with your hand? any rattling coming from them?
  17. Sep 17, 2025 at 9:36 AM
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    Yes and nope. Had the sound on my drive from work to home today so 2/3 drives so far it was there. It's a puzzler. I think handing a go pro under frame is the next move.
  18. Sep 17, 2025 at 11:00 AM
    HulkSmurf14
    2014 Tundra Limited
    Does anyone have the part number for the 38 gallon fuel tank cross member?
    Is it: 57407C ?
    **Nope, the cross member is part no.:510380C040
    I'm seeing if I want to upgrade from the 26gallon tank to the factory 38gallon fuel tank:
  19. Sep 17, 2025 at 11:14 AM
    SAGE63
    San Diego County
    you have to sign in to your toyota account. I had the same problem before I logged in.
    looks like a few of you answered before me...
    btw I purchased a replacement passenger Headlight. broken top right mounting tab. tried using JB weld... it did not hold...
  20. Sep 17, 2025 at 11:33 AM
    HulkSmurf14
    2014 Tundra Limited
    Here's what it would cost, though, no shipping available:
    The heat shields in the above quote were removed...
    https://www.tundras.com/threads/38-gallon-fuel-tank-upgrade.79154/#post-2095914
    23Tundy likes this.
  21. Sep 17, 2025 at 12:40 PM
    Xcumminsguy
    Xcumminsguy New Member
    NY
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    Did rear brakes. R&R rotors as they were junk. Used all OEM parts. Sucks that the pads did not include the little metal insulators that mount on the caliper in which the pads tabs slide so I cleaned and reused them. I also reused the steel backing plates that clip to the pads as well as the wear feeler. Is it typical with dealership parts that I must reuse all these parts? In the pas using aftermarket parts for other cars new pads always include these support parts. For the price of this OEM crap you would think everything is included.
    Tundra2n3 and bulldog93 like this.
  22. Sep 17, 2025 at 1:25 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Some solid progress on pops rig. Our setups will be very similar once complete.
  23. Sep 17, 2025 at 1:33 PM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    Assuming that’s for storage, I had considered doing that at one point as well to the unused space between the leaf springs. About how much weight will it hold?
    Tripleconpanna and HulkSmurf14 like this.
  24. Sep 17, 2025 at 1:58 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    This will hold spare tires and some recovery gear.
    Wallygator, 00h2itr, Gaston and 13 others like this.
  25. Sep 17, 2025 at 1:59 PM
    ToyoMafia
    ToyoMafia SSEM #15-3MW-RGBA#? Vendor
    Magic carpet.
    Damn I thought it was for pizza and beer
  26. Sep 17, 2025 at 2:25 PM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    To be fair it probably could hold pizza and beer. Need fuel for changing a flat.
  27. Sep 17, 2025 at 2:47 PM
    Uhhhh....
    Dave
    7” BDS, 37s
    I thought it would have a lid in the bed and be used for storage. you guys are on a different plane than me lol
    23Tundy, Tripleconpanna, BR73 and 3 others like this.
  28. Sep 17, 2025 at 3:22 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    It’ll also have a lid for when you don’t want the tires in.
    23Tundy, Tripleconpanna, BR73 and 5 others like this.
  29. Sep 17, 2025 at 3:27 PM
    19_Sr5_XSP
    19_Sr5_XSP New Member
    2019 Sr5 XSP
    None for now
    looks nice, I bought the 13" screen one so doesnt fit in the opening, but looks really nice when I powered it up on my bench
  30. Sep 17, 2025 at 3:30 PM
    19_Sr5_XSP
    2019 Sr5 XSP
    None for now
    got my final coupler in & installed me new "intake"
    this is a cut rough country pipe tied into the stock airbox (i really just wanted to remove the sound resonator from the stock & get rid of the ugly ribbed tube)
    dont worry about the singular clamp on the left side, that coupler is on the pipe almost 2" & its TIGHT....its not going anywhere
