  1. Sep 8, 2025 at 8:41 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    lol yea starting to lose my mind on items I’ve ordered vs what I already have lol. Thats what we get for redoing everything on the truck but the diffs lol
  2. Sep 8, 2025 at 9:01 AM
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    2018 Crewmax 1794 4x4
    I tried out all the recent All-Top gear I got from Amazon- I bought the compressor, but got the Y splitter (4 tires at a time) and the deflators as part of a review. The quick deflator took my tires from 38psi to 20psi no problem in a few seconds. I was able to fill the tire up from 20-35psi in under a minute hooked up directly. That's all I got done in the test due to it being hot and dinner time.
    compressor https://amzn.to/3V6DIyA
    deflators https://amzn.to/41DOeRK
    4 tire hose https://amzn.to/4mgSG0g
    woods, GAknight, WAtundra4x4 and 10 others like this.
  3. Sep 8, 2025 at 9:07 AM
    ThatGuyTheCooler
    ThatGuyTheCooler New Member
    I love mine. Did you run the separate wire for DRL?
    Tripleconpanna and reywcms like this.
  4. Sep 8, 2025 at 1:16 PM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    Did you order your grille and hood bulge from Toyota or aftermarket? I ordered the same setup from the Toyota dealership beginning of August and they still don’t have an ETA for me yet…
  5. Sep 8, 2025 at 1:23 PM
    fyrfytr26
    fyrfytr26 New Member
    Eastern PA
    2021 DC SR
    Saturday I installed a Sony XAV-9500ES from Trail Grid Pro. Having the Maestro already flashed, and everything pre-wired made installation a breeze.
    My only complaint is with their microphone mount. Based on their installation video it looks like they re-designed it. It was too tight to fit the microphone, and ended up breaking when I tried to push the microphone in. I ended up just putting the microphone on the top of the steering column.
  6. Sep 8, 2025 at 1:48 PM
    LabRat
    LabRat New Member
    North Caroline
    '14 Tunda
    Absolutely, wish I could have retained the amber DRL.
    It was aftermarket, its not perfect but its "good enough". Its an 11 year old truck, not a show car.
  7. Sep 8, 2025 at 3:08 PM
    stevep0925
    stevep0925 New Member
    Trinity, AL
    19 Cav Blue Limited 4x4
    Yeah that little mic holder is a 3d printed piece of shit. I said the same thing in my review on their page . But they took it down . (They gay like that) The wiring and harness are ok but a dude on you tube has it down to a science, his harness setup for this radio is way cleaner and they should really learn how to use tesa tape. All in all, a good unit prewired, from them but yeah the mic piece is garbage.
  8. Sep 8, 2025 at 3:33 PM
    Yota303
    Washington
    Looks pretty damn good to me for being an 11 year old truck! Thanks for sharing
  9. Sep 8, 2025 at 3:57 PM
    Pimpala1962
    Pimpala1962 New Member
    Kyle
    Massachusetts
    2015 double cab
    How bad of
    A job to swap these out i need to
    Do mine but never did it before
  10. Sep 8, 2025 at 4:18 PM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    I know you’re not asking me, and not to step on @BR73 toes, but it’s pretty simple. I’ve replaced several broken ones before, and last year replaced all of mine for longer ones as well.
    Just hammer out the old ones, and pull the new ones through with one of these guys (linked below), or just a bunch of washers.
    https://www.amazon.com/dp/B000ETUD22
  11. Sep 8, 2025 at 4:44 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    I have this same compressor under my hood. Works great, super fast.
    woods, Boneskull420 and RobertD like this.
  12. Sep 8, 2025 at 5:19 PM
    Pimpala1962
    Kyle
    Massachusetts
    2015 double cab
    Literally hammer out the old ones and pull new ones in no tricks to it, do t have to line up the groves on the new studs or anything?
  13. Sep 8, 2025 at 6:14 PM
    Uhhhh....
    Dave
    7” BDS, 37s
    Yes literally hammer out the old ones. That’s the easy part.
    No tricks. Stage the new one in the backing plate, no need to line up the grooves on the new stud’s collars with anything, they are just for friction… to keep them in the backing plate. Just eye it to make sure it’s going in straight, then screw the lug nut on it (with the tool I linked or a bunch of heavy duty washers…and w/o the tire on of course lol) and start cranking to pull the stud through the plate until it’s fully seated. Ju can doo iiit
  14. Sep 8, 2025 at 6:27 PM
    centex
    centex New Member
    I use an air hammer to drive them out and an air hammer to drive them in. Easy peasy.
  15. Sep 8, 2025 at 6:51 PM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    2020 SR5 Barcelona Red CREWMAX 4x4
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 KSP 1.25" Spacers Coachbuilder Shackles +2 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI High flying steering wheel TRD shifter knob LED lights inside/outside Morimoto 3rd brake light Coupe Battery Hold Down Under Hood LED Rear under seat storage Blue Sumo's rear Superbumps up front Fumoto oil valve TRD RAD CAP TRD Billet oil cap
    I ran an old Toyota lug nut on the stud I was removing first then a couple of wacks with the ole ball peen hammer . Make sure when you use the stud tool to have the flat against the hub before you crank on it with a 1/2 drive impact.The conical shape should be facing out.I destroyed mine. Also make sure to pull the new stud through until it touches the hub PXL_20250907_230009976.jpg
  16. Sep 8, 2025 at 6:57 PM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    Jump on in that's what this forum is all about besides I bought and destroyed the same install tool :D
  17. Sep 8, 2025 at 7:22 PM
    Racer X
    Racer X New Member
    Bob
    North Carolina
    2018 Tundra Limited 4WD 5.7 V8
    I’m with you, I’ve been a Maiden fan for a long time. I saw them several times live back in the 80’s, great shows!
  18. Sep 8, 2025 at 8:43 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Hey that’s George’s line
    woods, 23Tundy, Tundra234 and 3 others like this.
  19. Sep 8, 2025 at 10:21 PM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    That totally crossed my mind when I posted it. :rofl:
    Tundra234 and Tripleconpanna like this.
  20. Sep 9, 2025 at 3:10 AM
    Uhhhh....
    Dave
    7” BDS, 37s
    lol I went through three of them before I was done
    BR73[QUOTED] likes this.
  21. Sep 9, 2025 at 8:17 AM
    DrRansom
    DrRansom New Member
    Utah
    Silver Sky 2021 SR5 Tundra 4WD
    That looks really nice. I have wanted an updated head unit for a while. Could I ask a few questions about yours?
    1) I have a column shifter as well, so how does the floating screen work with it? Any issues?
    2) which steering wheel controls did you lose if any?
    3) did you lose anything in the center dash screen, like music, tire pressure, etc?
    joseph_womack likes this.
  22. Sep 9, 2025 at 3:12 PM
    WSDMetal
    WSDMetal Motorsports Fabrication & Design
    Huntington Beach
    Took the Tundra out for some light wheeling/photos and found my air up/down solution. Apex Designs makes this really sweet High Flow Push-on Chuck that makes airing up and down super easy when paired with the Milwaukee M18 Inflator. It's not the fastest setup ever for airing 37's back up to 35psi from 12psi but it's really nice that I can set the target psi and walk away for each tire.
  23. Sep 9, 2025 at 3:13 PM
    23Tundy
    23Tundy New Member
    SE Pa
    19 SR5 Cement crewmax
    5100s,Diode Dyn fogs, ARE topper, AJT interior chrome delete, meso lights/vleds, RC neoprene seat covers.
    IMG_5595.jpg IMG_5591.jpg image.jpg image.jpg Couple little touches the last few weeks.
    Nbab23, Yota303, GAknight and 5 others like this.
  24. Sep 9, 2025 at 3:17 PM
    WSDMetal
    Huntington Beach
    Installed an Alpine iLX-F511 with the Trail Grid Pro Bundle. Sound quality and overall volume is much better now.
    Install couldn't have been easier. The 3D-printed microphone bracket makes the install undetectable and OEM-level.
  25. Sep 9, 2025 at 4:56 PM
    jdg1982
    jdg1982 New Member
    Florence, Colorado (From Louisiana)
    2017 Magnetic Gray Tundra SR5 4x4
    Got my truck back today..
    They changed the fuel pump, as well as, the wiring and connector. Hopefully, this fixes her for good!
    I had to adjust to driving her again because I've been driving a 2025 Camry XSE for a week.
  26. Sep 9, 2025 at 5:26 PM
    Boneskull420
    Boneskull420 God loving,Tundra driving,rednek custom joker!
    Mark
    Tn
    2018 tundra crewmax magnetic gray trd offroad
    Ironman 4x4 foamcell pro 3.5in lift Complete custom stereo with 2 12's under rear seat S&B/stillen Frankenstein cold air intake True dual exhaust with Carven Tr mufflers Rough country hood bulge led strip Running board led's
    Nice truck!
    WSDMetal[QUOTED] and BR73 like this.
  27. Sep 9, 2025 at 6:22 PM
    Did you notice the accent light on the bottom? I ran across it by accident lol. Did you install the brake bypass on yours?
  28. Sep 9, 2025 at 6:39 PM
    NMRich
    NMRich New Member
    Rich
    2017 Tundra 1794
    RCI skids and sliders, 2018 LED headlights, Bilstein 6112/5160
    Now the fuel tank skid installed. trying to decded between a Baja Designs hood bulge light bar, cat anti-theft plates, or a differential skid.
  29. Sep 9, 2025 at 6:40 PM
    Boneskull420
    Mark
    Tn
    What is that box above the fuse box next to the fender. I see the RC on it?
    Bayou Spartan likes this.
  30. Sep 9, 2025 at 7:10 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    Looks like a relay box for a switch panel, similar to the auxbeam switch panels and other models
