  1. Jul 12, 2025 at 6:45 PM
    Dr3wski
    Dr3wski New Member
    2018 SR5 4x4
    Oil change today. Installed a Valvomax drain valve and aluminum oil filter housing while I was at it
  2. Jul 12, 2025 at 6:46 PM
    NMRich
    NMRich New Member
    Rich
    2017 Tundra 1974
    Is there a .stl file that is being shared for the center speakers or someone that is these available?
  3. Jul 12, 2025 at 6:52 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Pre-92 for sure :rofl:
  4. Jul 12, 2025 at 7:09 PM
    blenton
    blenton New Member
    :rofl::rofl::rofl:
  5. Jul 12, 2025 at 7:30 PM
    bulldog93 and HulkSmurf14 like this.
  6. Jul 12, 2025 at 8:04 PM
    NEVERGIVEUP
    NEVERGIVEUP New Member
    2021 Super White Tundra SR5 CM
    @Toe404 what’s your offset for your wheels?
  7. Jul 12, 2025 at 8:06 PM
    NEVERGIVEUP
    What’s the offset for the rock warrior wheels? Anyone know?
  8. Jul 12, 2025 at 8:31 PM
    5x150, +50mm offset, and ~24 pounds each.
  9. Jul 12, 2025 at 8:36 PM
    NEVERGIVEUP
    Thanks @Jim LE 1301. Any other comparable wheels out there with similar offset and weight?
  10. Jul 12, 2025 at 8:37 PM
    Wheels/Tires:
    Relations race wheels RR7 17x8.5 0 offset
    Relations race wheels black lug nuts
    Relations race wheels black lug locks
    20mm longer wheel studs
    Falken WildPeak AT335x12.5 x17
  11. Jul 12, 2025 at 8:38 PM
    ATV25 and bulldog93 like this.
  12. Jul 12, 2025 at 8:48 PM
    NEVERGIVEUP
    @Jim LE 1301 I’ve been looking at those rr7. Only issue is the 0 offset will probably have my tires and wheels stick out more than my current OEM setup. My steel wheels are +60 offset. So it lines up more flushed and tucked under the wheel well. I’m afraid changing offset to zero will potentially affect the steering geometry, put more stress on the suspension components and handling. It will however give it a more aggressive looking stance. Just thinking what would be best. My suspension is OEM thus far.
  13. Jul 12, 2025 at 8:49 PM
    NEVERGIVEUP
    I’d like to keep tire size at OEM spec so 255/75r17.
  14. Jul 12, 2025 at 9:17 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    Oh man. Got the summer of 69 going on here!
  15. Jul 12, 2025 at 9:23 PM
    blenton
    blenton New Member
    Do they make Molle mounts for your walker…? :anonymous:
  16. Jul 12, 2025 at 10:36 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Was it a pain? I've read nothing but heartburn installing this mod.
    JMGmanAZ and BR73 like this.
  17. Jul 13, 2025 at 3:23 AM
    Boneskull420
    Boneskull420 God loving,Tundra driving,rednek custom joker!
    Mark
    Tn
    2018 tundra crewmax magnetic gray trd offroad
    Ironman 4x4 foamcell pro 3.5in lift Complete custom stereo with 2 12's under rear seat S&B/stillen Frankenstein cold air intake True dual exhaust with Carven Tr mufflers Rough country hood bulge led strip Running board led's
    If your antique at 85 I must be pushing creation days at 1981:tumbleweed:
  18. Jul 13, 2025 at 3:38 AM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    2020 SR5 Barcelona Red CREWMAX 4x4
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles +2 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI High flying steering wheel TRD shifter knob LED lights inside/outside Morimoto 3rd brake light
    I installed one a few months ago and you don't have much room to work with so it is kinda rough on old folks . I probably would just replace the bulbs with LEDS if I had it to do again and tint the lens.PXL_20250511_202930463.jpg PXL_20250511_203021244.jpg
  19. Jul 13, 2025 at 4:07 AM
    Boneskull420
    Mark
    Tn
    Is that the morimoto 3rd brake light? I like the looks but haven't purchased. Has it worked well for you and did you opt for the flashing brake light?
    BR73[QUOTED] likes this.
  20. Jul 13, 2025 at 4:39 AM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    Yes it's the Morimoto and I did add the flashing module.So far so good on the functionality and it does look good.
  21. Jul 13, 2025 at 4:52 AM
    Boneskull420
    Mark
    Tn
    :thumbsup: thanks
  22. Jul 13, 2025 at 5:18 AM
    BAM3
    BAM3 New Member
    Houston
    2016 MGM CrewMax Platinum
    Nitto RGs, KMC wheels, DD fog lights, '21 LED Headlights, Retrax, 3" RC Lift, Tech12Volt Processor/JBL amp, TRD Sways
    Although these are the budget option, I’ve had them on my truck for 75k+miles. I don’t off-road but I do tow a 27’ center console boat. They are great for what they are. I bought my truck used and it came with them to i decided to leave them on.
    2014 Black tundra and BR73 like this.
  23. Jul 13, 2025 at 6:44 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    :pout:
    Boneskull420[QUOTED] and bflooks like this.
  24. Jul 13, 2025 at 6:46 AM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    That does look really nice. :thumbsup:
  25. Jul 13, 2025 at 7:55 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Severely underestimated how much clearancing I still have to do to stuff 37’s
    But it’s totally worth it for the droop
  26. Jul 13, 2025 at 8:14 AM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM Tundra & 25 TRD Pro Sequoia
  27. Jul 13, 2025 at 8:20 AM
    NEVERGIVEUP
    @Toe404 how are you liking that wheel setup so far? Any issues? Was thinking about the difference in offset from OEM +60. Any plans on getting new mud flaps, since OEM doesn’t cover the 0 offset?
  28. Jul 13, 2025 at 8:23 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Color matched the front grille surround and bulge. Took a chance on it, I did like the dull black front end. But ya gotta change things up sometimes.
  29. Jul 13, 2025 at 8:30 AM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    it’s been 2 and a half years, roughly 20k miles and zero issues. It mildly affected turning radius but I spend .005 percent of my driving making u-turns so it’s not a problem for me. I have a set of pro-comp fender flares I plan on installing but I need to source a set of front fenders as I don’t want to cut my OEM ones up. But even with stock flaps I’ve gotten maybe 3 small rock chips on the doors
    I love the wheels, the wide stance is perfect without looking ridiculous.
  30. Jul 13, 2025 at 8:59 AM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    Hackett gulch trail?
    BreyTundy[QUOTED] likes this.
