  1. Jun 15, 2025 at 6:58 AM
    jackienguyener
    jackienguyener OKToyota
    Jackie
    2016 Tundra 1794
    Yes. But honestly, I don’t think you’d need it. I bought the $120 kit for the CSB spacers and didn’t end up using them. You should be able to reuse what you already have
    HulkSmurf14 likes this.
  2. Jun 15, 2025 at 7:05 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    Good morning
    Question: When replacing your upper control arms, are you properly torqueing down the bolt/nut? Or are you just doing the ugga ugga method? If you are properly torqueing, how are you getting the socket/wrench on the nut for the driver's side? There's no room to fit a socket on the nut. I'm able to get the socket/wrench easily on the bolt head but is that providing the proper torque spec needed?
    Any tips? Recommend tool? TIA
    Florida AF and bulldog93 like this.
  3. Jun 15, 2025 at 7:08 AM
    centex
    centex New Member
    I’ve always just torqued from where I can get the wrench on.
    Henry1jg, ATV25, HulkSmurf14 and 2 others like this.
  4. Jun 15, 2025 at 7:17 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    If the bolt can spin freely then your torque should be relatively the same when applied to the nut or the bolt. Is not exact, but it’s within the range of ugga duggas.
    Otherwise, you could get a crowfoot wrench - technically it adds distance so the torque wrench value will be lower than what is actually applied, but not by that much in this application. You could calculate that difference if you wanted to get fancy but I wouldn’t sweat it
  5. Jun 15, 2025 at 7:22 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    They have to be on torque wrench at 90 degree angle. Probably can find single longer ones in size you need.
    ATV25, Leedaar, HulkSmurf14 and 4 others like this.
  6. Jun 15, 2025 at 7:23 AM
    TacomaTRD4x402
    Southern California
    Appreciate the quick responses! :thumbsup:
    I got the torque wrench on the bolt and it felt like I was overtightening so I backed off and left it loose for now. I also thought of using crowfoot to see if I can get on the nut side. Unfortunately I don't have a 22 crowfoot nor do I have another vehicle so I ended up ordering it on Amazon. Should be here today!
    https://www.amazon.com/dp/B0D59QQTJ9
    ATV25 and BR73 like this.
  7. Jun 15, 2025 at 7:26 AM
    TacomaTRD4x402
    Southern California
    Nice! That looks like it would also work
    Tunrod[QUOTED] likes this.
  8. Jun 15, 2025 at 7:27 AM
    RainMan_PNW
    Casey
    Clark County, WA
    If anything, I would expect turning the bolt would under tighten slightly due to the (potential) added resistance of the bolt turning.
  9. Jun 15, 2025 at 7:32 AM
    TacomaTRD4x402
    Southern California
    That reassuring to hear. Thank you. Last thing I want is to snap that bolt. I felt like I was about to.
  10. Jun 15, 2025 at 7:33 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    I was always taught if using adapters 90 degree angle no calculations require however this may help if you go on straight.
    https://belknaptools.com/extensions-calculator/
  11. Jun 15, 2025 at 7:38 AM
    TacomaTRD4x402
    Southern California
    Super helpful. Thanks :thumbsup:
    I've also always used extensions at 90° so this will be helpful if I can't get the 90° angle with the crowfoot.
  12. Jun 15, 2025 at 9:30 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Hit the trail yesterday with the steepest climb and descent we have around.
  13. Jun 15, 2025 at 9:53 AM
    RainMan_PNW
    Casey
    Clark County, WA
    As an engineer…that isn’t 100% accurate, but it is close enough for the degree of precision needed for this sort of application.
    Torque is a measurement of force applied at a specific distance from the center of rotation. A Foot-Pound is one pound of force applied exactly one foot away from the center of the bolt.
    Your torque wrench is made to pop/break over at the set torque based on that setting and a specific distance from the center of the anvil to the setting point in the wrench. If you “choke up” on the wrench, it won’t change the applied torque because the internal setting is built into the wrench (it will make it harder for you to apply the needed force though).
    Adding anything to the anvil that changes the center of the rotation will change the applied torque. It’s a straight line from the pre-determined point in the wrench and the center of rotation.
    If we assume the point in the handle is exactly 1 foot from the center of the anvil, and you add an offset (crowfoot or one of the box-end versions) that is exactly 3” long from the center of the anvil square to the center of the hex, then you would measure the new applied length from the point in the handle to the new hex:
    If straight forward, the distance is 15”
    If straight backward, the distance is 9”
    If 90*, the distance is 12-3/8”
    The amount of actual torque applied (above or under the value of the wrench) is the difference between the wrench’s calibrated length and the actual length above - 125% for scenario 1, 75% for scenario 2, and 103% for scenario 3.
    Gaston, ATV25, Xcumminsguy and 3 others like this.
  14. Jun 15, 2025 at 1:37 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Father’s Day camping trip. Good time with the family.
  15. Jun 15, 2025 at 2:03 PM
    Boneskull420
    Boneskull420 God loving,Tundra driving,rednek custom joker!
    Mark
    Tn
    2018 tundra crewmax magnetic gray trd offroad
    Ironman 4x4 foamcell pro 3.5in lift Complete custom stereo with 2 12's under rear seat S&B/stillen Frankenstein cold air intake True dual exhaust with Carven Tr mufflers Rough country hood bulge led strip Running board led's
    Good times indeed!
    OHwendTrd[QUOTED] and BR73 like this.
  16. Jun 15, 2025 at 2:32 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Spent the weekend at the family cabin collecting fire wood for the winter. Then drove to Mt Rainier for Father’s Day.
  17. Jun 15, 2025 at 2:50 PM
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Installed diode SS3 Pro with SDHQ mounts and bonobo 360 swivel mounts. The click adjustability with the swivel mounts is great. I’m not sure if I like how high it puts the pods. Debating if I’ll keep them mounted that way. Shout out to @memario1214 for the hookup.
  18. Jun 15, 2025 at 3:15 PM
    TacomaTRD4x402
    Southern California
    Got bored n did this with a spare set of dash trims I got from a part out sometime ago. I've gone back and forth with painting these things but I wanted a bit more texture so this is what came of it..
    Will install later this week as I've got a list of mods I'm currently working on.
  19. Jun 15, 2025 at 3:45 PM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    You go bro! :thumbsup:
    Boneskull420 and CaptRussia253 like this.
  20. Jun 15, 2025 at 4:20 PM
    TacomaTRD4x402
    Southern California
    Crowsfoot finally got delivered and it definitely helped. My torque wrench has a big head so it doesn't sit flush on the nut with the bolt pushing through so I had to use an extension bar to get it to sit flush on the nut. Plus it ran right through the hardlines perfectly. Not sure how much that affects proper torque but I doubt it's not a big issue.
  21. Jun 15, 2025 at 4:50 PM
    therealjonwick
    JR
    2019 OR
    I used crows feet also. I think I also may have torqued at the bolt side. These bolts are way overtightened. I went to 150ftlbs with some blue locker and nylock nuts. No issues so far.
  22. Jun 15, 2025 at 5:56 PM
    TacomaTRD4x402
    Southern California
    Totally agree! Felt like I was gonna snap the damn thing! :eek2:
    French Avocado likes this.
  23. Jun 15, 2025 at 6:15 PM
    therealjonwick
    JR
    2019 OR
    Pretty sure Tacomas and 4Runners use same bolts and only torque to 85ft/lbs. strange.
  24. Jun 15, 2025 at 7:53 PM
    SwitchThrottle
    SwitchThrottle Living in Idiocracy
    2021 Barcelona CrewMax
    Did someone say firewood?
  25. Jun 15, 2025 at 9:41 PM
    Boneskull420
    Mark
    Tn
    I don't know about someone saying anything about firewood but my 1st thaught is I see one heck of a 4th of July bonfire in the near future!:nuclear:
    Tripleconpanna and BR73 like this.
  26. Jun 15, 2025 at 10:34 PM
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    I’m so unhappy with the state of Colorado for switching back to road salts :mad: Mag chloride was bad enough but the rust development is now ridiculous. Those shocks I had seize up were 3 years and 60k miles old.
    On a positive note, Father’s Day was busy. Started out with a park picnic/BBQ with my dad, brother and uncles families with cornhole, squirt guns and plenty of food. We then hit the road around 6:00 pm for Yellowstone. Drove till I felt we’d made a decent dent and pulled into a Walmart for the night to finish the drive tomorrow.
    I’ve gotta say, I’m thrilled to death with the OTT tune. Had it done a month ago. My main goal with it was better trans control while towing. The minor extra power has been fun but today justified the tune.
    By comparison last year towing our camper from northern Colorado to Macanaghy and back, I averaged 6.5-7 mpg at around 70 miles an hour over relatively flat land. The truck would hang itself in 4th with the torque converter locking and unlocking, sending trans temps into the 220’s.
    Today took us north climbing out of Ft. Collins to Laramie and beyond, with much more hills. The truck did much better. It didn’t hang up in 4th gear like before, it actually went into 5th and 6th when it felt necessary on the flatter stretches, and as you can see, even over the hills of Wyoming, the truck managed better mileage at the same speeds. Trans temps stayed in the 200-210° range on the pan and fluctuated as the converter locked and unlocked on hills, but it spent more time locked and unlocked for heavy throttle climbs. Overall much happier. Can’t recommend the tune enough. And good lord, I’d love Wyoming gas prices at home. Filled with midgrade 87 octane for $3.52/gallon before leaving Colorado, but I filled in Casper Wy for $2.77/gallon.
    So here’s our sleeping situation for the night, to be continued to Yellowstone tomorrow.
  27. Jun 15, 2025 at 11:34 PM
    Boneskull420
    Mark
    Tn
    Nice, which option of the ott tune did you go with? I'm hoping to get mine done in the near future. Enjoy your trip! Went to Yellowstone about 2 years ago with the family in early spring when there was still snow on the ground. Would love to go back in warmer temps and enjoy some hiking and outdoorsy stuff.
  28. Jun 15, 2025 at 11:46 PM
    blenton
    blenton New Member
    If you have time to stop at Grand Teton National park on your way to Jellystone, they weather is nice this time of year. These are from String lake, which is just down the road from Jenny Lake. Great views.
    B580F432-7D0B-46EF-A78D-3CDBFC96E39B.jpg C0A105E4-2C75-4DA9-95E6-AE088C872411.jpg E95BB876-5B07-4AB1-903D-D9B79E8359BD.jpg
  29. Jun 16, 2025 at 12:00 AM
    Boneskull420
    Mark
    Tn
    I second that! I don't think we made it to that lake or not but I know we were at Jenny lake.
    Corndog123 and blenton[QUOTED] like this.
  30. Jun 16, 2025 at 4:02 AM
    TacomaTRD4x402
    Southern California
    Wow! :eek:Those are some beautiful pictures. Looks like something out of Red Dead Redemption 2.
