  1. Apr 7, 2025 at 6:14 PM
    bobbilly
    bobbilly New Member
    I don’t think it’s shoes/boots. My guess is the door is rubbing but I can’t see anything on the other side of the door. Touch up and door sills are in the future I suppose
  2. Apr 7, 2025 at 6:18 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Not with OEM wheels.
    Tripleconpanna likes this.
  3. Apr 7, 2025 at 6:29 PM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    By communicating with the TPMS sensors inside your wheels (if you have them) through the OBD2 network that the adapter plugs into below your dashboard.
  4. Apr 7, 2025 at 6:53 PM
    Azblue
    The Dirty T ( ^_^)_且
    Even pants or socks will do that over time. I had a RHD Jeep Cherokee with tall (unibody) door sills when I still worked at the post office and the driver's (right) side was much worse than that from the thousands of times I got out to deliver a package, swap mail trays, etc.
  5. Apr 7, 2025 at 7:06 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    There are a few aftermarket black springs on Amazon that are at the blue rate. The rubber on the sumo's looks far superior and taller and not as airy/urethane on the knock offs. Yours look pretty authentic.
  6. Apr 7, 2025 at 7:16 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    :eek:
    Oh no! Those look just like the ones I have. Do the Sumo's have any identifying markings on the sides. I'm gonna check out a couple videos to see if I can spot something.
  7. Apr 7, 2025 at 7:21 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I was just saying there are knock offs. Yours are 5 rings vs the aftermarket 4. The rubber on the aftermarket are more of a urethane than rubber.
    Yours look good.
  8. Apr 7, 2025 at 7:35 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    If it is the door, you may want to see if the door can be adjusted slightly... Body shop should be able to handle that, but I'd be weary of causing more harm than good.
  9. Apr 7, 2025 at 9:33 PM
    bobbilly
    bobbilly New Member
    I could see that if I drove it daily, it sits for a week at a time some times. Working remote I'm averaging around 550 miles/month.
    Might have to see if they can look at it, body/door lines look fine. Gap between the fenders/doors seems to be consistent top to bottom. Odd for sure.
  10. Apr 7, 2025 at 9:41 PM
    jspec rsx
    jspec rsx New Member
    I'm planning to remove the headliner on my SR5 CM as it needs to be reupholstered. Is it really that difficult to remove or is it because your platinum has extra wires glued? I'm debating on diy or if I should just get it done. But if I diy I'll also sound deaden the roof
  11. Apr 7, 2025 at 10:04 PM
    Tripleconpanna
    If the lines look clean, I'm not sure I'd mess w/it... Probably just grab some protectors from Anderson's while the sale is on would be your best bet:
    Bdiddy, JMGmanAZ and HulkSmurf14 like this.
  12. Apr 7, 2025 at 10:13 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    LOL - I keep a Surefire E2D in that same spot
    TundyManFL[QUOTED] likes this.
  13. Apr 7, 2025 at 10:25 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Not with the factory BBS wheels - there is a pocket in the back of the wheel that provides just enough clearance.
  14. Apr 8, 2025 at 5:09 AM
    Tundra family
    Tundra family New Member
  15. Apr 8, 2025 at 5:12 AM
    Tundra family
    Crewmax rear window for the win. Easiest headliner removal ever.
  16. Apr 8, 2025 at 5:17 AM
    Tundra family
  17. Apr 8, 2025 at 6:02 AM
    Pimpala1962
    Pimpala1962 New Member
    Kyle
    Massachusetts
    2015 double cab
    I have a set like that i bought off ebay for 140 bucks with sequential signals and they are great
  18. Apr 8, 2025 at 6:12 AM
    Tundra family
    I'll probably be hittin you up for advice on where to tap for the lights. I assume they are not plug and play.
  19. Apr 8, 2025 at 6:29 AM
    Blkdmax
    Blkdmax New Member
    Tennessee
    2021 Cement CrewMax 4x4
    IMG_0467.jpg Bought a used shell, dropped it off to get painted, wiring everything up while I wait on the paint to be completed. Super pumped to have a shell again for hunting, family trips and dog security.
  20. Apr 8, 2025 at 6:31 AM
    Blkdmax
    Blkdmax New Member
    Tennessee
    To add onto this, I have a gator trifold hard shell bed cover in great shape in the East Tennessee area if anyone is looking for one for a smoking deal.
    bulldog93 and HulkSmurf14 like this.
  21. Apr 8, 2025 at 6:32 AM
    caboj
    caboj New Member
    CA
    2018 CM TRD OR
    You have the 612 on the screen shot which is for Tacoma and has 4 rings. The 610 has 5 rings for Tundra. Each ring is an inch.
  22. Apr 8, 2025 at 6:33 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    I wish mine would fit in the garage...
  23. Apr 8, 2025 at 8:30 AM
    seydou
    seydou Distinguished Member
    That part is most probably the most available part from salvage yards.
    Tundrastruck91 likes this.
  24. Apr 8, 2025 at 8:35 AM
    seydou
    It's not the door. 100% a result of repetitive rubbing by footware and pants. Have had similar in many vehicles over the years. Not odd at all.
    bulldog93 and atc250r like this.
  25. Apr 8, 2025 at 8:58 AM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Get some door sill protectors.
    Not sure what yr/cab size you have. There's a couple different options for CM and DC. I think the last option may just be for the front doors only.
    Door Sill Protectors Accessories | Toyota Auto Parts
    FWIW, a lot of the Toyota dealerships that have online part stores are running sales this next week, similar to what was posted above on this page.
  26. Apr 8, 2025 at 10:15 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Thanks. I just saw the 5 ring one made in china. Was just pointing out that there are sumo knock offs. Not sure how they compare/perform.
  27. Apr 8, 2025 at 12:07 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    You can do it, some of the wires are still glued on the SR5. Just reglue them when you put it back in. Removing the upper handles front and rear was the trickiest part. Best part is you don’t have to worry about folding it, just back it out the back window.
  28. Apr 8, 2025 at 12:28 PM
    caboj
    caboj New Member
    CA
    2018 CM TRD OR
    Very curious how they compare as I am considering the 40 version if anyone knows.
    Sumo from US company $270-$300
    Knock off from US $150-$170
    Knock off from Ali Exp $60-$70
  29. Apr 8, 2025 at 1:53 PM
    jspec rsx
    is the upper handles clipped in?
  30. Apr 8, 2025 at 2:42 PM
    BlueRibbon4x4
    Geno
    The outside edges come off with a pick tool. The pick goes behind the small pieces on the outside edge and gets pulled downward or outward, I can’t remember at the moment.
    bulldog93 and RobertD like this.
