  1. Dec 18, 2024 at 7:19 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    It came with the truck. I haven't washed it in months and this is the first time I noticed it different in the rain only.
    bulldog93 and Terndrerrr[QUOTED] like this.
  2. Dec 18, 2024 at 7:48 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    I just figured they were all a bit off. I bet mine being army green will be really noticeable.
  3. Dec 18, 2024 at 8:01 AM
    Tundra family
    Tundra family New Member
    Oil change, ps fluid, and brake fluid exchange. Retorqued the drive line and inspected the front suspension. Everything is looking great considering the abuse this truck has been through.
    Switched it up to 5W30 and will cut my intervals from 10k miles to 5k miles now she is getting a lil older.
    BR73, CaptRussia253 and bulldog93 like this.
  4. Dec 18, 2024 at 8:21 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    Will you have to do cab mount relocation for the 40's? I've thought about it a bit myself.
  5. Dec 18, 2024 at 8:40 AM
    CaptRussia253
    Ruslan
    He's already done a relocate... :cool:
    Uhhhh....[QUOTED] likes this.
  6. Dec 18, 2024 at 10:18 AM
    STravis
    STravis SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    Cab mount relocation is already done. Definitely needed for the 39's I'm already running.
  7. Dec 18, 2024 at 1:53 PM
    Bayou Spartan
    Bayou Spartan New Member
    Black 2019 TRD PRo
    None
    Installed today.. got through it prayerfully !!
  8. Dec 18, 2024 at 5:42 PM
    Tundra family
    Would a bad ground cause battery terminal corrosion? Every time I open the hood on this pig the clamps have the crust. I've used the purple spray and did the penny trick, they still get crusty within a couple weeks.
  9. Dec 19, 2024 at 7:03 AM
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    Not sure why, but these trucks are just terrible about corrosion. I just rinse mine off with hot water every chance I get and they stay pretty clean.
    BR73 likes this.
  10. Dec 19, 2024 at 7:41 AM
    MVRCA
    MVRCA New Member
    Las Vegas
    2016 Tundra TRD Pro
    White Knuckle sliders, BDS 3" lift with Fox 2.5's. Method 305 NV with 35" Trail Grapplers.
    I've noticed that as well, and out here in the desert, it's a bit of a head scratcher. I need to pay more attention to this stuff.
  11. Dec 19, 2024 at 8:31 AM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    I read once that is an indication of gas being released from the battery, maybe the battery is on its way out.
    Interesting that you mention bad ground. About 25 years ago I bought a Subaru from a coworker for my kid in high school. It seems to run good but he recently rebuilt the engine and put a rebuilt transmission in it. I replaced the cracked windshield and put new tires on it as it had a mismatched tire on one. AWD do not like mismatched tires. Anyways it had 157K on it and figured it would last a few years. It did have an intermittent starting problem….. I was eyeballing it and noticed the ground was off the starter. I attached it and things were better! Anyways my daughter used it tru college and then some, and returned it when she bought a new car. It lasted another 100K+, where I sold it.
    I did clean my battery terminals last year on my 18 tundra, still with original battery. No major corrosion though.
    bulldog93 likes this.
  12. Dec 19, 2024 at 9:36 AM
    moodywizard
    moodywizard New Member
    Lost
    2017 Tundra 4x4 Crew Max
    Haven’t been on here lately, moving to TN end of year so been busy.
    Had premier west gears do the 5.29’s with rear Eaton e locker yesterday. Finally can use drive/6th gear again, fell in love with the tundra all over again.
    Tried to get a OTT tune same day but didn’t get done until late. Might have to wait until I move, no time..
    Also replaced the AAA battery as it was slowly dying and 5 years old. Went with Costco sealed interstate and ordered the GM diode to bump the charging voltage.
  13. Dec 19, 2024 at 11:42 AM
    Tundra family
    Could be, I'd be upset, only had this battery since July. The old one did it too so I'm leaning in another direction, I just don't know which direction.
  14. Dec 19, 2024 at 1:09 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    2020 SR5 Barcelona Red CREWMAX 4x4
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    I've still got to do the coolant,PS and Brake fluid change.I did engine oil,both difs and transfer case back during Thanksgiving.I also switched to 5w-30
  15. Dec 19, 2024 at 1:15 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    Have you tried a little baking soda and water to clean the terminal?
  16. Dec 19, 2024 at 1:22 PM
    Uhhhh....
    Dave
    7” BDS, 37s
  17. Dec 19, 2024 at 1:22 PM
    Tundra family
    Im afraid of what I'll find in my rear diff, and what it's going to smell like after 207k miles.
  18. Dec 19, 2024 at 1:24 PM
    Tundra family
    koditten likes this.
  19. Dec 19, 2024 at 1:29 PM
    250000yota
    Russ
    Berthoud, CO
    Absolutely. And the various aerosol battery terminal cleaner chemicals. I worked as a Toyota dealer tech for almost a decade, and I regularly saw Tundra's with corroded terminals. Haven't seen a 100% long term solution, they all seem to just hold it at bay for a little while.
    BR73[QUOTED] and Tundra family like this.
  20. Dec 19, 2024 at 1:38 PM
    koditten
    Kirk
    Midland of the Mitten
    Grease, spray paint, anything creates a barrier between the terminal clamp/post and the oxygen in the air. No air, no corrosion.
    Like said above, you can only hold off the corrosion, you will have to do a coating every so often.
    BR73, Uhhhh.... and Tundra family like this.
  21. Dec 19, 2024 at 2:53 PM
    WAtundra4x4
    Den
    Wet side WA
    So is it just a corrosion issue or are you having a low voltage draining battery? Does your truck get garaged or is it outside every night?
  22. Dec 19, 2024 at 3:45 PM
    Tundra family
    Just corrosion, it sits outside 24/7 and does double duty charging my camper when Im driving.
    BR73 likes this.
  23. Dec 19, 2024 at 4:57 PM
    WAtundra4x4
    Den
    Wet side WA
    Ok,
    8 years ago I had a truck with battery drainage at a low level. I traced it to a damp ECU board, from a leaky windshield. I found out that Ford had a TSB wrt leaky windshield. I was pissed. It was reacting strangely, with my truck from flashing dash lights to not starting. Other on the Ford forum had instances where the truck would just shut off on the highway… I ended up replacing the windshield and the repair guy said there was evidence of the leaky windshield seal, well I knew that as I saw water dripping in…. I lost confidence in the truck and sold it, bought a Tundra…. I travel in the mountains at times where there is no cell service and no readily available tow service.
  24. Dec 19, 2024 at 5:58 PM
    Steve66
    Steve66 New Member
    2017 Tundra SR5
    from things ive seen and read, once you have the corrocion on the posts, its also developing all along the cable. and it does increase the resistance for the energy transfer. thus reducing the efficiency of electrcal system
  25. Dec 20, 2024 at 5:43 AM
    justcuz
    justcuz 2.5 Gen Member
    my mechanic friend told me to put a thin layer of grease on the battery posts. Never had a problem.
  26. Dec 20, 2024 at 5:46 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Same, I used the grease that came with the NOCO pads when I purchased them. May take out the terminals and give them a clean. My X2power has not had any problems.
    bulldog93, MVRCA and Tundra family like this.
  27. Dec 20, 2024 at 7:35 AM
    retiredtanker
    retiredtanker I GOT MORE TATTOOS THAN I DO FRIENDS
    Lee
    Georgia
    2019 TRD Sport 4X4
    Looks Good
    2014 Black tundra likes this.
  28. Dec 20, 2024 at 9:55 AM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    I ordered the auto up and auto down switch like a month ago and still haven't shipped ! says still waiting. I might trade the truck in before it gets here lol
  29. Dec 20, 2024 at 11:17 AM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    Had it hauled away. Sad day. Off for repairs from rodent damage. No idea when I'll get it back...
    Abos, RealTruck, 250000yota and 7 others like this.
  30. Dec 20, 2024 at 11:20 AM
    Bullshawrk
    Bullshawrk New Member
    IDK rodents like our trucks I had my wires all chewed up. its so lame. Hopefully not too bad of damage!
    woods and JDR76[QUOTED] like this.
