  1. Dec 9, 2024 at 6:09 AM
    Tundra family
    Tundra family New Member
    Says for mustang GT, but it looks pretty damn universal to me.
  2. Dec 9, 2024 at 6:13 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
  3. Dec 9, 2024 at 6:15 AM
    Tundra family
    That is sexy. Tacoma boot?
  4. Dec 9, 2024 at 6:38 AM
    Tundra family
    Found this one from redline. Not so sure about the tan. Mind sharing the source for the boot?
  5. Dec 9, 2024 at 6:56 AM
    BlueRibbon4x4
    Geno
    It’s a Tacoma knob, boot from ebay.
  6. Dec 9, 2024 at 7:20 AM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    Finally after way too long I washed the truck and detailed the interior. The cleaning got severely neglected the last 8 months while I moved. So happy to have it clean again.
  7. Dec 9, 2024 at 8:34 AM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    Haha. I had a M235 for 8 years, got on it a few times but did not race it. It was probably one of the fastest bummers at 0-40. They depreciate in value quickly.
  8. Dec 9, 2024 at 8:51 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Thanks, I didn't see that exact mount on Amazon... I just ordered an ICS kit with a 3.5" arm to try. I imagine there will be some trial and error to get a set up that works.
    AZ Red Nek[QUOTED] likes this.
  9. Dec 9, 2024 at 8:57 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    Stock rim should have +60 offset, so a 1.5in spacer would put you at +22 offset
    redrum448[QUOTED] likes this.
  10. Dec 9, 2024 at 9:02 AM
    You will have some vibration or movement regardless of what's used as the dash flexes. I use my Rago for my radar detector.
  11. Dec 9, 2024 at 9:09 AM
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    2018 Crewmax 1794 4x4
    For the recent posts about the RAGO dashplate, here's my setup, and links to the parts being used.
    RAM threaded stud https://amzn.to/4goc4po to replace the 2 screws that hold the plate to the mount, it now allows you to get 2 more mounting spots
    RAM ball magsafe phone holder https://amzn.to/4gkXj7n so far hasnt let me down
    RAM radar mount plate https://amzn.to/4g1MFSA this holds an Escort IX and fits perfectly
    RAM phone holder that can hold a phone, or primarily our backup/reverse camera for the trailer. https://amzn.to/3ZsIjwX
  12. Dec 9, 2024 at 9:12 AM
    Holy crap.....you have your radar detector up high lol.
    rdiddy5[QUOTED] likes this.
  13. Dec 9, 2024 at 9:13 AM
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    there aren't many RAM mount options that have shorter arms to use.
  14. Dec 9, 2024 at 9:39 AM
    Spoke to SPC today. He said that is mounted correctly. Torque the nut to 45 ft lbs, then adjust higher to line the cotter pin up with the upper hole. He said 1/4 to 1/2 inch showing is normal. He also said the boot is sealed so it should not be moved down. At least I didn't need a new alignment. The funny thing is, both joints were loose. The passenger side with the torn boot came right out of the spindle. The drivers side not so much. The shop found them worn a couple of months ago when they were mounting my wheels.
    https://youtu.be/lB2mCm2iwgc?si=QLCr4IO0Ga9JrbXJ
    Yota303[QUOTED] and bulldog93 like this.
  15. Dec 9, 2024 at 9:42 AM
    bulldog93 likes this.
  16. Dec 9, 2024 at 9:45 AM
    For power I use the mirror tap and spliced it into the USB power under the plate. I put a large zip tie around the wire under the plate so I don't have to worry about accidentally pulling through.
  17. Dec 9, 2024 at 10:16 AM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    That’s a good idea. I’ll have to make one.
    koditten likes this.
  18. Dec 9, 2024 at 11:21 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Trans pan has arrived
  19. Dec 9, 2024 at 11:23 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Sweet, that is on my list of things to do before next summer...
    reywcms[QUOTED] likes this.
  20. Dec 9, 2024 at 12:24 PM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Is that a trans pan with a drain?
  21. Dec 9, 2024 at 12:27 PM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
  22. Dec 9, 2024 at 1:24 PM
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    I've had mine mounted under the rear view with a tap to the mirror power for years. Mighty Mouse patches and mirror.jpg
    mgm16trdpro, Florida AF and bulldog93 like this.
  23. Dec 9, 2024 at 5:32 PM
    Mullen
    Mullen Desert Dude
    Corona, CA
    2001 Prerunner, 2014 DC 4wd
    The MM carrier looks bitchin. I have the Bruno Fab one on my first gen and the NVH are intense, so much so that I’m ditching it for the Inland Driveline unit. The billet bearing is worse than the clicking bypasses through the cage.
  24. Dec 9, 2024 at 6:16 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Probably won’t notice over the long tubes lol
    Mullen[QUOTED] likes this.
  25. Dec 9, 2024 at 9:48 PM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    bulldog93 and JMGmanAZ[QUOTED] like this.
  26. Dec 9, 2024 at 10:19 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    RAM sells a full one that holds the entire phone too. I’ve got one.
  27. Dec 10, 2024 at 7:09 AM
    MatD13
    MatD13 New Member
    2018 Limited Cement Crewmax 4x4
    Did you have to do anything special to get your new sensor to register within the truck after replacement?
    I have a bad TPMS sensor and Discount Tire is telling me if they replaced the TPMS sensor with a new one, Tundras won’t register it after replacement. Got turned away by them this morning
  28. Dec 10, 2024 at 7:16 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    My understanding is you have to purchase Toyotas specific TPMS.
    I learned this because I paid extra for TPMS sensors when I bought my wheel and rim pkg and wasted the 150 bucks cause they don't talk to the truck.
    Sucked.
  29. Dec 10, 2024 at 7:25 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Interesting, Discounts Tire put new ones in my wheels, no issues at all.
    Tripleconpanna and SAGE63 like this.
  30. Dec 10, 2024 at 7:31 AM
    MatD13
    MatD13 New Member
    they said Toyotas and Lexus vehicles they won’t do. Would’ve been nice to know before I made an appt on their website.
