  1. Nov 27, 2024 at 9:08 PM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    Compressor is to air up if needed.
  2. Nov 28, 2024 at 4:32 AM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Which tie downs did go with?
    BR73 likes this.
  3. Nov 28, 2024 at 6:13 AM
    Florida AF
    Logan
    North Florida
  4. Nov 28, 2024 at 7:58 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    2020 SR5 Barcelona Red CREWMAX 4x4
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    Installed Morimoto 2 stroke 4.0 LED HL bulbs last night and didn't realize that they needed to be aligned to work correctly in a OEM housing.Yep got to take all that sh@# apart and realign the bulbs....SMH PXL_20241128_003120444.jpg
    bulldog93 likes this.
  5. Nov 28, 2024 at 8:22 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    You will need to disconnect the sway bar at the links to accurately adjust the tension on the RAS. I did not do that and it will inaccurately loaded the coil on the RAS. You will see that the leaf springs will droop down more when you disconnect the sway links.
  6. Nov 28, 2024 at 8:28 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Gotcha. I will give it a shot later this evening. Thanks for the tip. I had wrapped everything up already. Look like it will be easy to remove the links and readjust the ras tension spring. No need to remove the wheels.
    Tripleconpanna likes this.
  7. Nov 28, 2024 at 11:32 AM
    Fobroader
    Fobroader New Member
    Alberta
    2020 Platinum
    Winter mode on, stock rims with studded Hakkas, man what a difference, these tires are so awesome on ice.
  8. Nov 28, 2024 at 12:14 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Changed the oil this morning. First time with the new RCI skid plates and it was a breeze. Used a socket and an extension to press in the oil filter drain attachment through the access hole :rofl:
  9. Nov 28, 2024 at 12:31 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    What the, where have you been? You know what’s a breeze? Not having a skid at all. LOL
    I took my RCI off to repaint and haven’t put it back on yet… going to get new grade 8 hardware for it since it’s been about 3 years with the one RCI supplied. I may need to pull off my skid plate crossmember bar too, ugh.
  10. Nov 28, 2024 at 12:43 PM
    Bayou Spartan
    Bayou Spartan New Member
    Black 2019 TRD PRo
    None
    purchased a 3rd brake light
    simple but was on my list
  11. Nov 28, 2024 at 12:45 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    What did you go with? Full replacement or just the plastic cover?
    Bayou Spartan[QUOTED] likes this.
  12. Nov 28, 2024 at 12:57 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    I bought the Morimoto but haven't installed it yet
  13. Nov 28, 2024 at 12:59 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    The Motive X tool and drain are game changers .I installed a Fumoto valve also
    AZBoatHauler and BrandonL812 like this.
  14. Nov 28, 2024 at 1:01 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Threw on protection rings. All the protection it can get while undrivable
  15. Nov 28, 2024 at 1:07 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Dust protection.
  16. Nov 28, 2024 at 1:44 PM
    CaptRussia253
    Ruslan
  17. Nov 28, 2024 at 1:47 PM
    RobertD
    Robert
    DFW, Texas
    My issue wasn't installing the plastic cap, but I did 2 oil changes using them and it took me way to much time both changes getting that damn plastic cap removed so I could put my filter wrench on the filter. Like, comically funny. Those threaded drain hoses are soo nice. I just hand tighten and it doesn't leak and comes off with no effort.
    Just make sure you have it closed when you thread it in :anonymous:
    Mine was open from cleaning it and I didn't even check when I threaded it into the filter housing. Slight mess was made hahaha
    BlueRibbon4x4, reywcms, BR73 and 2 others like this.
  18. Nov 28, 2024 at 1:53 PM
    CaptRussia253
    Ruslan
    Ya I too had an issue removing the plastic drain cap thing. Had to use pliers and ended up snapping it into several pieces haha. Thanks for the tip.
    RobertD[QUOTED] and BR73 like this.
  19. Nov 28, 2024 at 2:17 PM
    TNThunder
    TNThunder New Member
    Colten
    TN
    2017 Inferno SR5 Off-Road
  20. Nov 28, 2024 at 2:27 PM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    Looks
    TNThunder[QUOTED] likes this.
  21. Nov 28, 2024 at 2:47 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
  22. Nov 28, 2024 at 3:48 PM
    koditten
    Kirk
    Midland of the Mitten
    You damn right! I tossed my skid on the 1st oil change.
  23. Nov 28, 2024 at 7:02 PM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    morimoto
    Ryuu likes this.
  24. Nov 28, 2024 at 7:03 PM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    i have found their products to be great
  25. Nov 28, 2024 at 7:06 PM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    I also got a garmin Glo 2
    i wanted to try it for some time and i can honestly say that its just what i have been looking for and does what it says
    i connected my ipad to my trucks wifi and blue tooth the glo 2 to the pad and bam!!
    my phone connect automatically and is more accurate
  26. Nov 28, 2024 at 9:51 PM
    Beckusmc
    Beckusmc New Member
    Black Tundra Platinum
    Can you post a picture of your setup? Would really like to see how you set everything up.
  27. Nov 29, 2024 at 4:33 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Something about gas station lights that hit at night. Just had to take a photo of her in her place of paradise. :rolleyes:
  28. Nov 29, 2024 at 4:54 AM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    Sure thing. I have not mounted my old ipad but I will send you pictures of the Glo 2 and mounting. Its smaller than I anticipated.
    HulkSmurf14 likes this.
  29. Nov 29, 2024 at 6:05 AM
    Bayou Spartan
    Black 2019 TRD PRo
    None
  30. Nov 29, 2024 at 6:19 AM
    koditten
    Kirk
    Can't like this.
    Reminds me of the last time I viewed the dash of cop car...
    from the back seat.
    Jaypown, Joro43, BR73 and 4 others like this.
