  1. Nov 1, 2024 at 7:20 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    You have the sickest fleet of rigs out there
  2. Nov 1, 2024 at 7:46 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    :cheers:
    BreyTundy[QUOTED] likes this.
  3. Nov 1, 2024 at 8:18 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    Super easy! Get yourself one of those fluid extractors. There's a few good brands out there like MightyVac. I got this one by Four Uncles because it seems like you get more for less..
    https://www.amazon.com/dp/B0836GH3G7
    Then I used this video as a guide as it seemed to be the better of a few that I watched...
    https://www.youtube.com/watch?v=_FOYgaNMeZc
    Just make sure that the reservoir doesn't go empty while extracting.
  4. Nov 1, 2024 at 8:59 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Primo. Much appreciated!
  5. Nov 1, 2024 at 9:42 AM
    CaptRussia253
    Ruslan
    Thank you for this. Added to the list of things to do this winter.
  6. Nov 1, 2024 at 10:42 AM
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    Yesterday the truck got an oil change, and I got motivated. Finally swapped my Baja Designs Squadron Sport 2's for my new Diode Dynamics SS3 Max's. I should have done them earlier...
    The old lights. The Baja ditch lights, stock LED fog's, TRD Pro LED Headlights, and my DD 40" bumper bar.
    The new sexy's...
    And the improved lighting pattern. This also includes the upgrade from the OEM LED fogs to the SS3 Pro's in the fog pocket with their SAE fog pattern. I went with the combo beam on the ditch lights. Seriously should have done this sooner.
  7. Nov 1, 2024 at 10:44 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    A certain improvement!
    Tripleconpanna and 250000yota like this.
  8. Nov 1, 2024 at 11:02 AM
    250000yota
    Russ
    Berthoud, CO
    I drive to work between 3-4 AM, and I regularly get herds of elk and the occasional kamikaze deer, and I've found that it's easier to prevent hitting them by seeing them sooner than building the front of the truck to take the hit :rofl:
    That doesn't mean something like a RCI or Ironman front bumper isn't in the plans though lol
  9. Nov 1, 2024 at 1:14 PM
    SDiegoTT
    SDiegoTT New Member
    San Diego
    2021 Tundra Platinum Silver 4x4 CC
    Stock for now
    2021 Platinum 4x4. Has been a slow build process but got Bilstein 6112s up front on 1.9 inch setting to level it out and 5160s on the rear. Stock leafs and UCA
    285/70/18 Toyo Open Country AT3
    Method NV305 18x9 +25 offset
    Removed front mud flaps
    No rubbing or trimming needed.
    Tire poke is just enough, see pic.
    Very little road noise so far but certainly more compared to the stockers.
    For tires, I considered NITTO Recon Grappler and Falken Wildpeak. Both the TOYO OC and NITTOs were lighter than the Falkens. All are great tires.
  10. Nov 1, 2024 at 1:54 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Finally found a good muffler shop to slap my cats on... Truck still sounds great but a lot less drone at 1600-1800 RPM. A lot quieter on startup too.
  11. Nov 1, 2024 at 6:53 PM
    dan8906
    dan8906 New Member
    Daniel
    2017 MGM Tundra SR5 TRD OR, 2011 Tacoma TRD OR & 2004 Tacoma TRD OR
  12. Nov 1, 2024 at 7:16 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Put some gas in it…
  13. Nov 1, 2024 at 7:18 PM
    Azblue
    The Dirty T ( ^_^)_且
    That's an old pump, can't remember last time I've seen one of those.
  14. Nov 1, 2024 at 7:33 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Most of the fleet cardlocks around here are still mechanical pumps…maybe that’s how they keep the price down? :notsure:
    I pay the same price for ethanol-free 87 at this location as the 10% shit at the exit I take off the freeway, so I’ll take the short detour here.
    She was a thirsty beast tonight though.
    Mater, WFD473, bulldog93 and 2 others like this.
  15. Nov 1, 2024 at 7:40 PM
    Azblue
    Now that you mention it, I have seen one fairly recently. Usually if I'm out and about at work and need gas in a State vehicle, I just hit whatever gas station is close. But, a while back I was picking up a vehicle at ADOT after maintenance and decided to fill up there. It was an old mechanical pump, so I guess you're right.
    bulldog93 likes this.
  16. Nov 2, 2024 at 5:10 AM
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    Ok so finally got rid of the chrome and silver trim. Now on to changing the fake wood trim and the peanut butter leather.
    welshmike, rob1208, Fobroader and 9 others like this.
  17. Nov 2, 2024 at 8:45 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    What head unit is that??
  18. Nov 2, 2024 at 8:48 AM
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Its a Phoenix SC7862, just added a Tmobile sim so no need to use Hotspot.
  19. Nov 2, 2024 at 11:40 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Congrats. You will fall in love with your truck all over again. (At least I did.)
    bulldog93 and French Avocado like this.
  20. Nov 2, 2024 at 12:28 PM
    Xcumminsguy
    Xcumminsguy New Member
    NY
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    Changed front and rear diff oil. Front got 2qts. of Lucas 75w-90 and rear got 4 of Mobil 1 75w-90. Would like to have used Mobil 1 throughout but I got the last 4 qts. I’ve heard good things about the Lucas so I’m not sweating it. Same price per qt. 19.99. Can’t wait to do the transfer case next, dropping that cat shield should blow. Truck has 41k but I’m not the original owner so I like a fresh start, although I’ve owned it for almost a year now. Didn’t add and limited slip fluid, is that ok?
  21. Nov 2, 2024 at 1:50 PM
    HulkSmurf14
    2014 Tundra Limited
    You're good to go without the LSD fluid...mostly because, you really don't have a "limited slip"...unless it's aftermarket...
    Tripleconpanna, Xcumminsguy and BR73 like this.
  22. Nov 2, 2024 at 3:56 PM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Knocked out Transfer Case and Transmission fluid changed today. Transfer Case fluid was basically new, but the transmission, let’s just say it was time.
    And I tried to do my front diff just to find out that the last guy stripped out the bolt. Going to pick up an extractor set and order a set of Lexus bolts.
    After the obligatory drive around the neighborhood, I swear the drivetrain is just a little more responsive and efficient feeling. I’m sure it’s a placebo, but that’s fine with me
  23. Nov 2, 2024 at 4:07 PM
    stevep0925
    stevep0925 New Member
    Trinity, AL
    19 Cav Blue Limited 4x4
    Installed Sony XAV-9500 ES from Trailgrid Pro. Super easy to do. It was all mounted and came pre wired. Did front camera but have not mounted it yet..still thinking that through.
    Also installed 12volt solutions remote start. Super happy with both.
  24. Nov 2, 2024 at 4:18 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    2020 SR5 Barcelona Red CREWMAX 4x4
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    Get the phone app for the 12volt Solutions remote start.... you will like it
  25. Nov 2, 2024 at 4:19 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    Have you got a part number on the Lexus bolts?
  26. Nov 2, 2024 at 4:23 PM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
  27. Nov 2, 2024 at 4:24 PM
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    I sure did, all I want to do is drive and watch podcasts lol
    1UP[QUOTED] and koditten like this.
  28. Nov 2, 2024 at 4:30 PM
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    The one I got came out to $750 is with warranty and it's will worth it. I did have a little problem with my HVAC not working but it was a setting that Phoenix walked me through. There customer support was beyond my expectations. Supposedly they are around all the time. I called at 6EST and got a video call back at 7EST.
    I also loaded a launcher which gives you endless customization. The best was the Tmobile sim card. Now I don't worry about Hotspot or wifi. Just Bluetooth for phone and the rest is internal.
    batman900[QUOTED] and bulldog93 like this.
  29. Nov 2, 2024 at 4:35 PM
    stevep0925
    Trinity, AL
    Nah. It's a paid service ..not that cool
    koditten likes this.
  30. Nov 2, 2024 at 5:10 PM
    haysr1
    haysr1 New Member
    2015 Tundra TRD 3'' Toytech Boss on 34'' Nitto Ridge Grapplers
    I was curious. What amber lights are in your your grill? Thanks in advance!
    2014 Black tundra likes this.
