  1. Oct 7, 2024 at 4:33 PM
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    Is a pain because they are plastic welded. Some guys have done it. You have to melt the weld off and then some used epoxy others used screws with washers.
    Yes I got them Amazon, beware you see a slight amount still of the silver is some spots. Not alot just enough to bug me but there decent.
  2. Oct 7, 2024 at 5:06 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Heated seats, dual climate control, sensors? What else does the 1794 have?
  3. Oct 7, 2024 at 5:10 PM
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    I believe the SR5 doesn't have pull down rear window, sunroof I'm sure there can be more bit not sure.
    BR73 likes this.
  4. Oct 7, 2024 at 5:46 PM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    2020 SR5 Barcelona Red CREWMAX 4x4
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles +2 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI High flying steering wheel TRD shifter knob LED lights inside/outside Morimoto 3rd brake light
    2020 SR5 has the roll down back glass but no stinking moon roof
    Dave8699[QUOTED] likes this.
  5. Oct 7, 2024 at 5:49 PM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
  6. Oct 7, 2024 at 5:52 PM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    But at least I put on new front bump stops and most all LED's on the ass end
    I have the new Morimoto 3rd brake light, turn signals and tag lights to put inPXL_20241007_235828665.jpg
  7. Oct 7, 2024 at 7:28 PM
    Voda48
    Voda48 New Member
    Wisconsin
    2016 Platinum
    Picked these up from HF, unfortunately the plug is in between sizes and I could get it out.
    BR73[QUOTED] likes this.
  8. Oct 7, 2024 at 7:32 PM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    Damn the luck
  9. Oct 7, 2024 at 8:00 PM
    NorthShore
    NorthShore New Member
    2014 SR5 TRD Offroad Crewmax
    Yesterday changed the oil and prepped the new RCI Skid for install. Had bronze paint and matte clear left over. Figured why not. 3 coats of paint and 3 of the clear. Will let if sit and cure until next weekend before installing.
  10. Oct 7, 2024 at 8:04 PM
    JrJrOffroad
    JrJrOffroad Somewhere in the west
    Anthony
    Monument, CO // Cave Creek, AZ
    Mine are getting delivered this week and testing them in moab this weekend. Hopefully they live up to the hype- Patrick has been awesome to work with
  11. Oct 8, 2024 at 5:22 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Yep. Just removed mine and had them color matched to my truck. Used JB Weld and screws to get them back on. Black door handles are from a Sequoia. Same handle, just OEM black.
  12. Oct 8, 2024 at 6:44 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Cooled seats, heated mirrors, folding mirrors, BSM, LDA (depending on year), Trans Cooler (depending on year), moonroof... I might be forgetting a few options.
  13. Oct 8, 2024 at 6:58 AM
    1794TX
    Steven
    N.TX
    '20 1794
  14. Oct 8, 2024 at 6:59 AM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    1794TX[QUOTED] likes this.
  15. Oct 8, 2024 at 7:01 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    This is the only thing keeping me from doing this mod
    My 8 year old would lose a finger being a jackass.
  16. Oct 8, 2024 at 7:06 AM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    That's why you only get the driver's control and don't install the auto up switches on the rest of the doors....you stay in control
  17. Oct 8, 2024 at 7:12 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    That doesn’t prevent a kid from shoving their fingers in a closing window, though. I definitely did that crap as a kid, so as a former idiot, I watch out for my next-gen idiot lol
    Steve66, woods, koditten and 6 others like this.
  18. Oct 8, 2024 at 7:29 AM
    1794TX
    Steven
    N.TX
    '20 1794
    Yep. All sorts of inspirational posters about how we drank from the water hose and rode bikes without helmets, but none of it confirms the truth that we were lucky to make it to our teens with our faculties intact.
  19. Oct 8, 2024 at 7:41 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    When gentleman gets older he needs to work smarter.
    Basically, how the rear shock is replaced: shock gets the lower rubber mount between two dished washers, then it is compressed with your body weight, then it is quickly inserted into the upper mount and aligned for the bolt insertion through the lower mount holes and shock itself. I could not do it in time. The shock comes compressed in the box, you are supposed to reuse that strap to hold the shock compressed while it is prepared for the installation, then you bolt it to the lower mount, cut the strap, guide it through the upper mount and fix it there. No brainer.
    Unfortunately, I screwed up my first attempt installing them and had to redo it all over. Both straps were cut, but this is what locking pliers are for:
    Compressing the shock and routing the strap over the shock was too difficult, so a piece of scrap lumber to the rescue!
    Bolted to the lower mount, now can release the pliers:
    ~80 lbs wheel is too much for my back, so here's another tool wife is complaining about :)
    Hint: keep the stock shock hardware, Toyota makes it better IMO. I'll see how those poly bushings survive the negative temps, but old rubber bushings were not disposed of.
    Tundra805, WBW, Florida AF and 11 others like this.
  20. Oct 8, 2024 at 8:22 AM
    SAGE63
    San Diego County
    what faculties
  21. Oct 8, 2024 at 10:12 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Got the harness bar all coated with steelit. Couple more spots then back in the truck it goes. Then off to get some leather quotes at some point
  22. Oct 8, 2024 at 10:55 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Looks factory-sealed! Nice choice of coating!
    Tripleconpanna and reywcms like this.
  23. Oct 8, 2024 at 11:40 AM
    koditten
    Kirk
    Midland of the Mitten
  24. Oct 8, 2024 at 11:41 AM
    koditten
    Kirk
    I like tools that help make the job suck less.
    French Avocado, RetiredTundra and vtl like this.
  25. Oct 8, 2024 at 2:33 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Back together
  26. Oct 8, 2024 at 3:18 PM
    Where are you mounting the idash?
  27. Oct 8, 2024 at 5:02 PM
    DrRansom
    DrRansom New Member
    Utah
    Silver Sky 2021 SR5 Tundra 4WD
    I'm not a big fan of side steps, but my kindergartener has been struggling to get in and out of the car during school drop off. So the high clearance of the truck has become a safety concern. Luckily, I found these chrome beauties on Facebook for about $50.00. I don't care for the look, but the utility has been worth it this week at school drop off time.
  28. Oct 9, 2024 at 3:39 AM
    It's not that big, especially where mine is mounted.
    batman900[QUOTED] and 250000yota like this.
  29. Oct 9, 2024 at 4:04 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Filled it with gas, went fourwheeling. Filled it with gas again.
    The other day, I changed the oil, element and air filter. ONLY about 100 bucks.....good Lord stuff got expensive. And I did it myself to save money........
    ATV25 and Damie Street like this.
  30. Oct 9, 2024 at 4:10 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Buy OEM filters in bulk. You can find them cheap in 5- or 10-packs on Amazon and eBay.
    For oil, nothing beats the quality of Kirkland for the price. When it’s on sale, you can get 10qt for $30-33.
    My oil changes have cost me less than $40 each. And check out this thread for how well that oil holds up in a 185k mile 3UR.
