  1. Sep 20, 2024 at 6:55 PM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    2020 SR5 Barcelona Red CREWMAX 4x4
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles +2 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI High flying steering wheel TRD shifter knob LED lights inside/outside Morimoto 3rd brake light
    PXL_20240921_011906557.jpg PXL_20240921_011635782.jpg PXL_20240921_011623422.jpg
    Swapped out the sorry screws they send with the Stillen CAI for some stainless hex heads that are MUCH better and even look better imo..:yes:
  2. Sep 20, 2024 at 6:57 PM
    koditten
    Kirk
    Midland of the Mitten
    I like the bigger Allen head bolts.
  3. Sep 20, 2024 at 6:57 PM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    Ordered a stainless metric kit off Amazon
    koditten[QUOTED] likes this.
  4. Sep 20, 2024 at 7:12 PM
    centex
    centex New Member
    Only problem I see is the original hardware had a built in washer to spread the load and I don’t see a washer on the new bolts. Tighten to much and you could crack the lid.
  5. Sep 20, 2024 at 7:17 PM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    Yes I used washers but may swap to a larger diameter
    centex[QUOTED] and koditten like this.
  6. Sep 20, 2024 at 8:07 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Looks good! What size are those?
    reywcms and BR73[QUOTED] like this.
  7. Sep 20, 2024 at 9:05 PM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
  8. Sep 21, 2024 at 7:54 AM
    seydou
    seydou Distinguished Member
    What is the procedure to add the turn signal function? Is the wiring already there? What year/model is your truck?
  9. Sep 21, 2024 at 8:08 AM
    RobertD
    Robert
    DFW, Texas
    As long as the mirrors purchased have the turn signal function and are wired for a Tundra, the turn signals will work even if your stock mirrors didn't have a turn signal indicator. The wiring is already there in the truck harness.
    Some of the lower cost mirrors are not pinned to match the truck harness and it normally just takes swapping 2 wires in the mirror harness for everything to work.
    The only functions that require running wires is if you add power folding (not adjusting) and your truck didn't have it, or the reverse light that most of the GM style mirrors have.
    Mullen, BlueRibbon4x4 and bulldog93 like this.
  10. Sep 21, 2024 at 8:36 AM
    Xcumminsguy
    Xcumminsguy New Member
    NY
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
  11. Sep 21, 2024 at 1:14 PM
    smokint
    smokint New Member
    2017 1794 2002 Tacoma
  12. Sep 21, 2024 at 2:40 PM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    Got my fender flares on today. The rubber strip between flare and body was a pain. :mad: But, I like it. :) There’s just a little bit of sidewall sticking out. Hopefully the side of the truck won’t get as dirty.
  13. Sep 21, 2024 at 2:43 PM
    2014 Black tundra
    2014 tundra sr5
    The bolt head pattern on the flares goes well with the bolt pattern on my wheels and lug nuts. :thumbsup:
  14. Sep 21, 2024 at 2:56 PM
    Pimpala1962
    Pimpala1962 New Member
    Kyle
    Massachusetts
    2015 double cab
    Looks good
    what suspension do you have truck sits nice
  15. Sep 21, 2024 at 2:58 PM
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Put mine in last week. Works great! I think they updated the part.
    Bergy24[QUOTED] and BR73 like this.
  16. Sep 21, 2024 at 3:19 PM
    2014 Black tundra
    2014 tundra sr5
    Thank you. I have a 3.5 RC full struts in the front. 2” blocks in the rear. Also have airbags in the rear to help tow the 29’ camper. The RB 20 slim running boards give it a higher look than the OE side steps.
    bulldog93 and koditten like this.
  17. Sep 21, 2024 at 4:03 PM
    Pimpala1962
    Kyle
    Massachusetts
    2015 double cab
    Did you have to do upper control arms
  18. Sep 21, 2024 at 4:23 PM
    therealjonwick
    JR
    2019 OR
    Put new side steps on. Tiger trax. Coated them with rust inhibitor first. They were cheap but hope they last. Also put on color matched mirror caps and RCI engine skid. Not a bad weekend.
  19. Sep 21, 2024 at 4:36 PM
    2014 Black tundra
    2014 tundra sr5
    Yes. I didn’t have to, but I wanted to upgrade. I put RC upper control arms in.
    Pimpala1962[QUOTED] likes this.
  20. Sep 21, 2024 at 7:16 PM
    RoniusMaximus
    RoniusMaximus The One and Only
    J
    Tri-Cities, Washington
    2020 MGM Toyota Tundra TRD PRO
    Synthetic Blinker Fluid
    Picked up an offroam phone holder on fb marketplace for $20 and installed it. I was originally waiting out for a cheap ram x holder but am happy with this. In case anyone else cares or was curious, the offroam phone holder works perfectly fine with AJT vent trim covers installed.
    Also, after moving to Eastern Washington from Oregon nearly 2 years ago, I finally got WA plates for the Tundra. I had to milk the 4 year tabs I bought with the truck when new in 2020.
  21. Sep 21, 2024 at 7:24 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Helped install a TX light bar in my buddy's Tundra.
    We used his canopy and side curtain to stave off the direct sun, but the beer supply definitely took a hit today due to the heat.
  22. Sep 21, 2024 at 7:24 PM
    Stanky10
    Stanky10 New Member
    Stanky
    W Columbia SC
    2019 MGM Tundra TRD Sport
    3/1 leveling kit with 295/60/20 Nitto Ridge Grapplers, Go Rhino Dominator D6 step rails, Husky X-Act floor liners (front and back).
    What flares did you go with
  23. Sep 21, 2024 at 7:25 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    You stole that phone holder ;)
  24. Sep 21, 2024 at 7:27 PM
    RoniusMaximus
    J
    I know. The guy got rid of his Tundra over a year ago and had it at $50 for almost a year. Finally dropped the price and I pounced on it.
  25. Sep 21, 2024 at 7:30 PM
    RoniusMaximus
    J
    Looks good! I have that same front body armor bumper piece. I just need to get the right light bar for it before I install it.
    bulldog93 and texasrho83[QUOTED] like this.
  26. Sep 21, 2024 at 7:42 PM
    That is a cool light bar.
    smokint and texasrho83[QUOTED] like this.
  27. Sep 21, 2024 at 7:44 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    It is not fun to install imo - we both agreed it ain't coming off again.....then realized he needs a winch :frusty:
  28. Sep 21, 2024 at 7:45 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Pretty sure I paid something like $70 new
  29. Sep 21, 2024 at 7:52 PM
    2014 Black tundra
    2014 tundra sr5
    1.75 bushwhacker fender flares. I also got them from Summit Racing.
    bulldog93 likes this.
  30. Sep 21, 2024 at 7:54 PM
    RoniusMaximus
    J
    What was the worst part about the install? Also, do you recall if he was able to install a skid plate and/or keep oem tow hooks installed at the bottom? Some days I just think about selling it and keeping the stock bumper.
