  1. Sep 6, 2024 at 6:50 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    After nearly losing my shit with those bolts both times installing that box on my truck I ended up not using the rubber grommets from the stock box and instead just stacked a few rubber washers on the bolt. I figured all the grommets really do is just creates a good air seal at each hole n so that's what the rubber washers will do. You can also put a rubber washer right on the fender if you don't want to scratch the paint there. It worked for me and makes reinstallation a breeze whenever n after I gotta smog.
    Give it a try @pvn.beluga and @Tundra234 :thumbsup:
    Also, what makes it a struggle is having to simultaneously pull the box toward the fender, line up the 2 holes, starting to thread the bolts while having the little hood shock/strut support keeping your head from looking straight down into the hole to see if your lined up. I found it hard to start the thread by hand so I used a ratchet but then even the shallow socket was too deep because you have to push down but the head of the bolt is just pushing into the socket. So either stuff your socket with something to keep the bolt pushed down or use one of these bit drivers
    Anyways, hope that helps
  2. Sep 6, 2024 at 7:03 PM
    TundraTXTSS
    TundraTXTSS New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
    Got new BFG's went from 285 65 18 to 275 70 18;s pleanty if room on stock sunpension. Then had to wash it.IMG_6072.jpg
  3. Sep 6, 2024 at 7:05 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    It was definitely an awkward position with that hood strut in the way. I actually got the middle bolt on and then used an allen key to guide the bolt to the hole.
    Thumbs felt like when I was installing my EVLMFG 3rd brake light… lol
  4. Sep 6, 2024 at 7:15 PM
    TacomaTRD4x402
    Southern California
    Didn't catch if you said it but did you get the wet or dry filter?
    BR73 likes this.
  5. Sep 6, 2024 at 7:29 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    :yes:
    Those 81's should be freakin' sweet :thumbsup:
    PS>>> Thanks for touching on the BBS bullet point (that would've been my next question) :anonymous:
    If you end up getting rid of your OE Fox stuff, let me know...
    RainMan_PNW[QUOTED] likes this.
  6. Sep 6, 2024 at 7:30 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Dry is what you want
    bulldog93 and pvn.beluga like this.
  7. Sep 6, 2024 at 7:32 PM
    Tripleconpanna
    Devil's lube or a little water-based KY or Astroglide (don't waste money on the good stuff) definitely helps anything rubber or plastic slide in place...
    Passing shielded wires through the firewall grommet is another great example of how lubing up gets rid of the 'bind' :thumbsup:
    bulldog93, camron1039 and Mater like this.
  8. Sep 6, 2024 at 7:37 PM
    Vizsla
    Vizsla pretend2send
    Rear bed bar supports finished and installed.
  9. Sep 6, 2024 at 9:44 PM
    TacomaTRD4x402
    Southern California
    Couldn't agree more. Even though mines a payment princess I threw a nice lil piece of lingerie on my AFE for that extra piece of mind.
  10. Sep 7, 2024 at 12:59 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Went with dry. Heard the oiled version screws up the MAF.
  11. Sep 7, 2024 at 3:14 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    That's a good approach, sadly it isn't the approach most are taking.
  12. Sep 7, 2024 at 7:09 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    So, I had replaced the shifter trim and the cup holder trim with the AJT replacements. I thought that it looked so good that I also replaced the vent rings, climate control knobs, climate control rings, radio knobs, shifter, and the door handles. It looks so much better.
  13. Sep 7, 2024 at 7:16 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    I hand washed my truck for the first time in over a year. Accidentally popped it out of park. Cruised down the driveway into the neighbors tree.
    So I just learned that my truck can shift out of park without depressing the brake pedal or having the keys on the ignition. Suspecting a bad brake pedal solenoid switch thing. But body shop and I agreed to not try to fix anything until insurance adjuster takes a look at it.
    reneaux, Begbie, ATV25 and 6 others like this.
  14. Sep 7, 2024 at 7:18 AM
    Thankfully nobody was hurt.
  15. Sep 7, 2024 at 7:34 AM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    Now replace the silver U piece with black and spray the shift indicator with matte to get rid of the reflection.
    bulldog93 and TacomaTRD4x402 like this.
  16. Sep 7, 2024 at 7:46 AM
    TacomaTRD4x402
    Southern California
    Like this...;)
  17. Sep 7, 2024 at 7:49 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    What's the $145 hype here? Let me know!
    https://wholesaledirect.moderntoyota.com/oem-parts/toyota-blower-motor-8710360560
  18. Sep 7, 2024 at 7:53 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Truck still looks better than most vehicles on the road.
    Glad everyone is OK. Musta been one wild ride for the kiddo!
  19. Sep 7, 2024 at 8:14 AM
    SAGE63
    San Diego County
    Cannot like this
  20. Sep 7, 2024 at 8:21 AM
    French Avocado
    Utah / Wyo
  21. Sep 7, 2024 at 9:45 AM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    2020 SR5 Barcelona Red CREWMAX 4x4
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles +2 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI High flying steering wheel TRD shifter knob LED lights inside/outside Morimoto 3rd brake light
    mgm16trdpro and bulldog93 like this.
  22. Sep 7, 2024 at 10:10 AM
    bulldog93, BR73 and OHwendTrd[QUOTED] like this.
  23. Sep 7, 2024 at 10:19 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    Thanks, you figured they would be the same motor between the models. Strive to be a level of LC fancy.
  24. Sep 7, 2024 at 10:19 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Mine is on back order... :(
  25. Sep 7, 2024 at 10:44 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
  26. Sep 7, 2024 at 11:16 AM
    ZPhilip
    Philip
    West Chester, PA
    I keep telling myself that. Could have been much worse if a car was driving down the street. Just a huge inconvenience. I was rear ended 2 years ago and was in a rental for 3.5 months.
    Tripleconpanna likes this.
  27. Sep 7, 2024 at 12:57 PM
    ZPhilip
    Philip
    West Chester, PA
    Only went about 60 feet but he was absolutely terrified.
    Mater[QUOTED] and koditten like this.
  28. Sep 7, 2024 at 12:58 PM
    rcsbguy
    rcsbguy New Member
    Swapped from 2.5s to 3.0s.
  29. Sep 7, 2024 at 1:05 PM
    koditten
    Kirk
    Midland of the Mitten
    I don't know if I'd report to the insurance that there was an unattended child in a vehicle.
    With today's society, you could end up with a knock on the door to find child protection services wanting ask some questions.
  30. Sep 7, 2024 at 1:26 PM
    Velocity72
    Velocity72 New Member
    Upstate SC
    2021 Platinum
    How many miles on your 21?
    OhioCBtundra likes this.
