  1. Aug 29, 2024 at 12:19 PM
    RobertD
    Robert
    DFW, Texas
    Odd, I have the RAS as well and gained an inch with it. I'm a little confused how you have so much more lift in the rear with having blocks up front too.
    I have about 2" lift up front with 6112, I added the RAS cause I was about level without and I'm back to having some rake. But not like what you have. Take a pic of your leaf springs to show the u-bolts. If you have blocks, they will be between the leafs and the frame.
    BR73 likes this.
  2. Aug 29, 2024 at 1:33 PM
    Gecko.
    Gecko. New Member
    CT
    2014 Tundra DC
    Thanks. I'll try to grab some pics tonight.
    RobertD[QUOTED] likes this.
  3. Aug 29, 2024 at 2:10 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    That is a cheaper steel spacer lift on your front struts.
    Like Robert said, something ain’t right in the back if you’re getting that much lift in the ass unless you’ve got lift shackle or non-factory leafs
    bulldog93, RobertD and Gecko.[QUOTED] like this.
  4. Aug 29, 2024 at 4:40 PM
    SR5style
    SR5style New Member
    2019 MGM SR5 4wd Crewmax
    Installed the TRD air flow accelerator (PTR03-34079) in the stock airbox.
    Hardest part was not losing the rubber grommets on the 10mm bolts holding the lower airbox in. Total install time was 15 minutes, and 10 of that was messing with the grommets.
    I can't tell any difference in power or sound, but I do think it flows better and it's OEM fit and cheap enough ($30), so I'm happy with it.
  5. Aug 29, 2024 at 5:12 PM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    2020 SR5 Barcelona Red CREWMAX 4x4
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles +2 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI High flying steering wheel TRD shifter knob LED lights inside/outside Morimoto 3rd brake light
    Did you remove the grey filter in the top of the air box?
  6. Aug 29, 2024 at 5:15 PM
    I did that on my 2013 but never did it on the 2020. Now I don't have to worry about removing it with the Stillen.
    bulldog93 and pvn.beluga like this.
  7. Aug 29, 2024 at 5:17 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Didn’t really need to do anything with the grommets. Once you loosened the (2) 10mm bolts holding the air box in place, the box should have just came out easily.
    BR73 likes this.
  8. Aug 29, 2024 at 5:30 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Did 400 mile trip on mine after the swap. Truck runs smoother, shifts smoother. I also think it downshifts better also. No power gains from what I can tell, but I love what it does for 30 bucks invested.
    French Avocado and pvn.beluga like this.
  9. Aug 29, 2024 at 5:31 PM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    2017 SR5 5.7 4x4 quicksand dbl cab
    Guys I know this is a forum for out tundras but you’re always so helpful. My dads GM dealer says dealer they diagnose transmission problem until the engine runs well on his 2017 gmc Sierra.
    Father lost power on the highway and truck would only move in one gear. Had it towed to dealership who says that the truck “runs rough” and occasionally misses, says they can’t diagnose any transmission issues until that is figured out. My father states that at times the truck does run rough. Dealer attempted to replace an injector which didn’t fix the issue. Service advisor says five mechanics were puzzled and ultimately decided that the crankshaft must have lost shape and that it needs to be replaced to the tune of $5000. Is it true the transmission can’t even be diagnose posed until the engine issue is solved?
    They aren’t charging him for the injector replacement (for now, I’m sure they would if he took the truck elsewhere)
  10. Aug 30, 2024 at 3:46 AM
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    Did you reset your ECM after the install? Did you unhook your battery during the install?
  11. Aug 30, 2024 at 5:16 AM
    1UP
    1UP Truck Gang
    I did neither. You can do the entire install without unhooking any electronics. The video I saw on it didn't have me doing any resets.
    Bergy24[QUOTED] and HulkSmurf14 like this.
  12. Aug 30, 2024 at 5:20 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    I'd buy that. I would imagine that they can still read any codes that the transmission is throwing just fine, but without consistent load (ie: a well running engine) I'd think it would be impossible to actually run the truck through all the gears to see what's wrong. But I'm just some dude on the internet with a keyboard, not an actual mechanic, so take this with a very large grain of salt
    250000yota likes this.
  13. Aug 30, 2024 at 7:45 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    No need to do that. Just take out the air box and remove the piece that’s on the air box and replace with TRD intake accelerator.
    Bergy24[QUOTED], BR73 and HulkSmurf14 like this.
  14. Aug 30, 2024 at 7:52 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I think he's merely asking to say that mileage/hp output could be more accurate from a reset post install.
    Wallygator and Bergy24 like this.
  15. Aug 30, 2024 at 7:53 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    For a better gain, now do a SABM
    BlueRibbon4x4 and HulkSmurf14 like this.
  16. Aug 30, 2024 at 2:00 PM
    Gecko.
    Gecko. New Member
    CT
    2014 Tundra DC
    Here are the promised pictures. My apologies in advance for the quantity. Since I wasn't sure which one may or may not prove relevant, I just went ahead and uploaded them all:
    The End. :D
  17. Aug 30, 2024 at 2:20 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    Has it arrived yet? ;)
  18. Aug 30, 2024 at 2:22 PM
    Just got delivered right before the storm came in. I already have a simple project in mind for the name on the lid.
  19. Aug 30, 2024 at 2:23 PM
    TacomaTRD4x402
    Southern California
    Are you gonna keep the stock lid? Or plexiglass a new one
  20. Aug 30, 2024 at 2:39 PM
    Keep it. Just going to cut some color matched letters for it.
  21. Aug 30, 2024 at 3:01 PM
    TacomaTRD4x402
    Southern California
    Ooo niice, can't wait to see that
  22. Aug 30, 2024 at 3:09 PM
    SAGE63
    San Diego County
    Yeah, There is a block in there.
  23. Aug 30, 2024 at 3:35 PM
    Gecko.
    Gecko. New Member
    CT
    2014 Tundra DC
    I was thinking that little thing was an OEM piece, especially since its not very big and its in a wedge shape (smaller end forward). I've installed blocks on my Jeeps and Excursion, and those looked nothing this one. Sorry for my misrepresentation then.
    1794TX likes this.
  24. Aug 30, 2024 at 3:38 PM
    1794TX
    Steven
    N.TX
    '20 1794
    Don't be sorry. If everyone knew everything about their trucks this forum would be 'somedudeswithnothingtodo.com'
  25. Aug 30, 2024 at 3:56 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Reworking a few bed items.
  26. Aug 30, 2024 at 7:09 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Finish mounting the power tank tomorrow. And the blower comes Wednesday
  27. Aug 30, 2024 at 7:29 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    Yesterday, I took her to the mechanic down the street from me for some 65K mile work. Radiator flush, Tranny flush and a new belt before it starts to make noise (it had 8 years on it). They did it in just a few hours and cost just over $600.
  28. Aug 30, 2024 at 9:22 PM
    FireFinder44
    FireFinder44 New Member
    Albany, OR
    2019 Super White Tundra TRD Pro
    Mostly stock TRD Pro
    Bought a Diode Dynamics 42" white driving LED light bar, with the perfect mounts from Hotshot Offroad and a couple of amber wide lenses for the outboard pods of the bar, and a set of DD LED reverse lights to augment the Rigid Ignites I put in the rear bumper. Guess I will be doing my battery terminals this weekend, possibly doing the seat heaters, and several other mods after F1 and WVU game tomorrow and the GP on Sunday.
  29. Aug 31, 2024 at 12:09 AM
    RainMan_PNW
    Casey
    Clark County, WA
    You have a block lift back there under the spring. That thing is where the extra height is coming from
  30. Aug 31, 2024 at 6:43 AM
    Mountaineer
    Mountaineer New Member
    TN
    2019 MGM Platinum
    "After the WVU game". Sounds like you've got your priorities in order. GO MOUNTAINEERS!
    Jaypown and FireFinder44[QUOTED] like this.
