  1. Aug 19, 2024 at 10:11 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Probably just a custom exhaust job. They probably chopped close to the secondary cats and did a closer side exit instead of the original side exit going above the axle and out the back of the rear passenger wheel.
    I dumped my exhaust after the axle like most do here so it’s hidden and tucked away underneath the bed. Slight drone, but I’ve gotten used to it.
    Gecko.[QUOTED] and JMGmanAZ like this.
  2. Aug 19, 2024 at 12:19 PM
    :thumbsup:
    Look for my picture on the wall.:rofl:
    Gecko.[QUOTED] likes this.
  3. Aug 19, 2024 at 5:13 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    After years of 8 dealing with this;
    AC cuts out (blows warm air) for a few seconds sometimes. | Toyota Tundra Forum (tundras.com)
    I think I narrowed down my AC clutch cutting out to the climate control in the dash.
    It randomly cuts out and ALWAYS comes back on hitting a good bump in the road.
    Had to be a bad connection or ground somewhere.
    I had a local shop check all the connections and of course, they couldn't get it to cut out the 3 days they had it.
    Even during oil changes at the dealer throughout my extended warranty, I'd note the issue but they could never replicate it.
    The local shop replaced the clutch relay (I did that already) and didn't charge me labor since they didn't fix it.
    I think I finally narrowed it down to hitting my climate control in the dash when it cut out and it would come back on.
    Been doing that for about a month without fail.
    Last week I bought a used climate control on eBay for $85.
    It came today, I swapped the innards (circuit board) on the new (to me) part and put it my old case with AJT knobs.
    We will see if it fixed the problem.
    It's better to spend $85 on the eBay part with the shot that might work than buy a new one for $700 + and it not work...:D
  4. Aug 19, 2024 at 7:34 PM
    jdg1982
    jdg1982 New Member
    Florence, Colorado (From Louisiana)
    2017 Magnetic Gray Tundra SR5 4x4
    I used my hailprotector today.. photos are roughly an hour apart
  5. Aug 19, 2024 at 7:38 PM
    centex
    centex New Member
    How long did that take to setup?
  6. Aug 19, 2024 at 7:43 PM
    jdg1982
    jdg1982 New Member
    To put on maybe 5-10 minutes.. You wanna make sure that it's really tight under the front wheels, so that the wind doesn't blow it loose. Maybe 10 min for it to fully inflate, which once you turn the switch, it does on it's on. I bought it in early June after they had a hail storm in Florence and I ran to the gas station for cover. This is the first time, I've actually had to use it. Worth the cost.
  7. Aug 19, 2024 at 7:54 PM
    Nice, here's the link
    Tundra is .....Truck & SUV Size 3 (234" - 270")
    https://hailprotector.com/pages/protect-your-vehicle-from-hail
  8. Aug 19, 2024 at 7:54 PM
    BOSSARU
    BOSSARU Warthog_Tundra
    Splendora, TX
    2018 Super White 1794 4x4
    7" BDS, Kings, 40" STT Pros, 17" Method 702s
    I had no idea there was an OEM no screen gasket. I just use snips and cut the screen out of mine :rofl:
    BR73 and 2Tall[QUOTED] like this.
  9. Aug 19, 2024 at 8:35 PM
    Echo5Golf
    Echo5Golf New Member
    Phil
    Tundra Hunter
    1st, it’s minimal at worst. 2nd, any mudding? When you get back a power wash with that small gap makes for an easy clean up. I really like it.
  10. Aug 19, 2024 at 9:48 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    That is sweet. Did you order yours on line?
  11. Aug 19, 2024 at 9:51 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I've never seen that before... nice!!!!
    Y0TA PR0[QUOTED] likes this.
  12. Aug 19, 2024 at 11:20 PM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Right!
    Thks Jim for the link. @Jim LE 1301
  13. Aug 20, 2024 at 6:13 AM
    mfelton18
    mfelton18 New Member
    South Central Texas
    2014 Magnetic Grey SR5 4x4 crewmax
    I spray painted mine and some 2k clear coat. been holding up for 2 years now.
  14. Aug 20, 2024 at 6:50 AM
    :hattip:
  15. Aug 20, 2024 at 7:23 AM
    Wishbone Runner
    Wishbone Runner Toyota Connoisseur
    2019 Platinum
    I see you left the indictor whereas the way it is "supposed" to be installed either covers that piece or it is removed, I like it!
    bulldog93 likes this.
  16. Aug 20, 2024 at 7:41 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    I touched up some scratches and put gas in it.
  17. Aug 20, 2024 at 10:11 AM
    FireFinder44
    FireFinder44 New Member
    Albany, OR
    2019 Super White Tundra TRD Pro
    Mostly stock TRD Pro
    Replaced one of the 12V sockets in the dash with the dual USB rapid charger (00016-00225) that I got off ebay from a Toyota/Lexus dealer in Miami. Ordered another one to do the rear.
    I just clipped the oem connector off, and used a Deutsch 2-pin connector after shortening the leads off the USB.
    BOSSARU, Bowzer, grant.ducckk and 6 others like this.
  18. Aug 20, 2024 at 10:17 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Reamed out the hubs to accommodate my extended lugs. And ripped out the radium catch can and moved to a different unit. Pre ran the hoses and will cut to length once the blowers back.
    Next on the hit list is throw in a fresh belt. Ordered some new fender washers for my door liners we made should have those this week along with the new upgraded Lexus coilpacks. Got the new plugs gapped tighter. Need to order the o2’s while I’m at it.
  19. Aug 20, 2024 at 10:26 AM
    15SR5CM
    15SR5CM New Member
    Roseville, CA
    2015 SR5
    Bilstein 6112/5160 3/1 w/CB shackles Ironman front bumper, 18+SR5 Honeycomb grill
    does it actually fast charge with the factory wiring?
  20. Aug 20, 2024 at 12:38 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Swapped out to the TRD Intake Accelerator. Figured it’s a cheap upgrade. Also took out the carbon filter from the intake box.
    Changing out and removing both items really made a sound difference with the start and revving!!
  21. Aug 20, 2024 at 4:51 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Dude where’s that SABM mod! Get it goin
  22. Aug 20, 2024 at 4:57 PM
    I did that mod on my 2013. I kept the kit after I sold the truck but I don't know if it will fit the 2020 or not.
  23. Aug 20, 2024 at 5:12 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Should fit box didn’t change much
  24. Aug 20, 2024 at 5:19 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Lol man!! I’ll get to it!!!
    RobertD likes this.
  25. Aug 20, 2024 at 5:22 PM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Oil/filter change; propeller shaft lube; rear diff service, transfer case service; front diff service; transmission service; coolant flush/fill and $1248.39 lighter...Should hopefully be good for a while...
  26. Aug 20, 2024 at 5:27 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    reywcms, RobertD and bulldog93 like this.
  27. Aug 20, 2024 at 6:00 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Boom even better
    Tripleconpanna and RobertD like this.
  28. Aug 20, 2024 at 6:01 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    2020 SR5 Barcelona Red CREWMAX 4x4
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    Nice cell phone charger....I have one on the way
    1lowlife[QUOTED] likes this.
  29. Aug 20, 2024 at 6:12 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    Installed a 12volt Solutions remote start kit on my 2020 SR5.They make it look easy on the instructional video cause they have little hands.:yay:
  30. Aug 20, 2024 at 6:23 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Does the accelerator even make power or change the sound?
    reywcms likes this.
