  1. May 30, 2024 at 1:44 AM
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    That looks awesome! What fender flares are those?
  2. May 30, 2024 at 2:40 AM
    junior, bulldog93 and Pillslinger like this.
  3. May 30, 2024 at 4:21 AM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
  4. May 30, 2024 at 5:08 AM
    :hattip:
  5. May 30, 2024 at 5:47 AM
    BOSSARU
    BOSSARU Warthog_Tundra
    Splendora, TX
    2018 Super White 1794 4x4
    7" BDS, Kings, 40" STT Pros, 17" Method 702s
    Got the @RainMan_PNW switch panel installed. First couple cuts were stressful, but I just slowly whittled it with a dremel for that super tight fit. Now I need to fill it in with locker switches!
  6. May 30, 2024 at 5:52 AM
    Pillslinger
    Rollin
    SWMO
    It just occurred to me that the '21 LR PRO in the Forum Header is another great example. (@RainMan_PNW ) Casey's build thread will convince you to dig out your wallet if you're not careful but he has done some awesome stuff to his rig.
    Tripleconpanna, bulldog93 and RobertD like this.
  7. May 30, 2024 at 6:35 AM
    Retired Blue
    Retired Blue New Member
    Steven
    Round Rock, TX
    2020 Super White Platinum
    Jomax Customs front end links.
    Instructions say to set them at 3.5", center to center, as a starting point and adjust from there. I assume the 3.5" is based on stock suspension, but don't know. Since I've a 2" front CO lift, I thought maybe to start longer, so I asked. Jomax responded that my Installer would know what to do. My installer, me, decided to start at 4". Clearance is good, at least a finger width of space around, wheels turned both ways, as well as jacked-up to full droop. Went on a quick drive around the hood and climbed several 8 - 12" curbs, at different approach angles, some faster than others. Not a clunk, squeak, nor grind one. My installer is good with the 4" setting, for now.
    Great to have: sway bar to end link bolt can be torqued to spec while installed. No issues getting a 22mm open-end on the nut and a 1/2" drive torque wrench with 12mm hex bit on the bolt, so on Tundra adjustment is doable should it be needed.
  8. May 30, 2024 at 6:54 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Wow.
  9. May 30, 2024 at 7:14 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Nice install! Curious to see what articulation is like with one of those
    Retired Blue[QUOTED] likes this.
  10. May 30, 2024 at 7:20 AM
    Retired Blue
    Steven
    Round Rock, TX
    Thank you! So am I, but I'm not planning to get into a situation where I will find out. :D
    BreyTundy[QUOTED] likes this.
  11. May 30, 2024 at 7:26 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Nice. I went to order them a couple months back and they were OOS.
    I went with BDS links instead with no regrets - they've got zerks and more height for lifted applications.
  12. May 30, 2024 at 7:33 AM
    stevep0925
    stevep0925 New Member
    Trinity, AL
    19 Cav Blue Limited 4x4
  13. May 30, 2024 at 7:39 AM
    Retired Blue
    Steven
    Round Rock, TX
    Amazing. With all the Googling I did I don't think I've seen the BDS before. Love the zerks. I was leery of the Heim joints vs. ball joints. Do you know if they've other lengths for less of a lift, or is the for 4.5 to 7" lifts it?
    One thing I did find in my research, is the Heim joints for the Jomax, both ends, are sold at Summit Racing, and at good pricing. So, if I do have a Heim go out, I can replace.
    bulldog93 likes this.
  14. May 30, 2024 at 8:08 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    This looks fantastic! Are there clear instructions on how to do this to a 1794 somewhere on here? I really want to do this but I'm afraid of screwing up the leather.
    rdiddy5 likes this.
  15. May 30, 2024 at 8:28 AM
    reneaux
    reneaux I've been around
    2017 SR5 CM 4x4
    D6 Boards
    superdenk, P-bar, RainMan_PNW and 8 others like this.
  16. May 30, 2024 at 10:12 AM
    Begbie
    Begbie The big yellow one is the sun!
    Wilmington, NC
    2020 White Tundra Limited
    This is the part number: 55405-0C020-C1 and linked here. Just make sure it's not the part number ending in -B0, as that one is the surround with the silver finish. The rep at Ourisman clarified that with me after he checked my VIN number and I told them that C1 is correct and that I wanted black and I double checked with him just to make sure it included the 4x4 hole. All good there.
    Ourisman was the cheapest I was able to find at $201.13, but shipping ended up being an additional $31.46. But they had shipped to me within 4 days or so.
    bulldog93 and stevep0925[QUOTED] like this.
  17. May 30, 2024 at 10:37 AM
    BOSSARU
    Splendora, TX
  18. May 30, 2024 at 10:41 AM
    Xcumminsguy
    Xcumminsguy New Member
    NY
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    V3N0M, RobertD and texasrho83 like this.
  19. May 30, 2024 at 10:42 AM
    BOSSARU
    Splendora, TX
    I took mine off, I think it looks better that way.
    Mend0k, equin, V3N0M and 11 others like this.
  20. May 30, 2024 at 10:46 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The BDS don't, but I came across these that also have zerks. If you want more of the OEM look but have a milder lift, Rough Country has some too.
  21. May 30, 2024 at 10:46 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Damn! That’s a bad A$$ looking truck! :muscleflexing:
    V3N0M and BOSSARU[QUOTED] like this.
  22. May 30, 2024 at 10:50 AM
    BOSSARU
    Splendora, TX
    RC links are good for mild lifts, I run them on my work Tundra on a 3.5”
    P-bar, Tundra-XP, Rugerla1 and 5 others like this.
  23. May 30, 2024 at 10:56 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yeah ppl talk crap about RC stuff but they've gotten better over the years.
    Rugerla1 and Retired Blue like this.
  24. May 30, 2024 at 11:29 AM
    Retired Blue
    Steven
    Round Rock, TX
    I came across those too, on Rock Auto. Some reviews I read said they are good a few months post install, but then start "clunking." Too, the zerks are supposedly non-standard, aluminum, and cross-thread easily (they don't come installed) There's YT videos of folks having trouble getting their grease gun fitting on, and one of the links, I think passenger side, has the zerk pointing to the rear, which makes it even more of a pain.
    If I hadn't of damaged a grease boot on one of my factory ones when I installed my Eibachs, I wouldn't have been looking. With OEM replacements running $120+/side, I bought a set of Detroit Axle ones off Amazon; same part numbers as the Moog ones, also on Amazon, but half the price. Those turned out to be junk; all supplied nuts had malformed threads and couldn't be used, and I rounded out the 6mm hex socket on the end of the ball-joint pin on one. That's when I decided to cry once and get the Jomax Customs set, which are about the same cost as OEM, but still twice what I paid for the TRD HD Front Stabilizer Bar itself. Time will tell. :burnrubber:
    Edit: And Charles, thank you for the heads up on BDS. I read their installation instructions, and they give an explanation of how to line up (set the total link length) that Jomax instructions doesn't. I may just adjust my links another 1/8" to 1/4" longer; get the bar to link bolt more perpendicular to the top heim joint. :thumbsup:
  25. May 30, 2024 at 11:41 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Jomax is good ppl. If anything craps out you can reach out to him and he'll respond.
  26. May 30, 2024 at 11:59 AM
    Florida AF
    Logan
    North Florida
    I am in a rental, but saw this beautiful rig while out exploring!
    Whoever you are, cool setup!
  27. May 30, 2024 at 12:25 PM
    BOSSARU
    Splendora, TX
    I recommend their shocks and other hard parts for anyone on a budget. But not their bracket lifts, seen far too many fail doing mundane stuff.
  28. May 30, 2024 at 12:44 PM
    grant.ducckk
    grant.ducckk New Member
    Grant
    2019 DC Cavalry Blue Limited 4x4
    You don't see a lot of Kimbo Campers out there! I have been in one, they are super roomy.
    Florida AF[QUOTED] likes this.
  29. May 30, 2024 at 3:42 PM
    CBrider
    CBrider New Member
    Cary
    Eugene, OR
    2017 1794 Edition TRD Sunset Bronze Mica TRD exhaust
    Diamond Back Cover
    I Cerakoted the original chrome door handles. The black plastic OEM ones started looking like shit after a couple of years.
  30. May 30, 2024 at 5:12 PM
    therealjonwick
    JR
    2019 OR
    Awesome! Thank you. I like the look of those. Appreciate it. What’s your lift and tire size? Sorry if you posted it before.
