  1. May 28, 2024 at 8:56 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    A man of fine taste!
    2018Tundra[QUOTED] likes this.
  2. May 28, 2024 at 9:00 AM
    2018Tundra
    2018Tundra New Member
    VA
    2021 Tundra Platinum
    Likewise!
    BreyTundy[QUOTED] likes this.
  3. May 28, 2024 at 9:09 AM
    FireFinder44
    FireFinder44 New Member
    Albany, OR
    2019 Super White Tundra TRD Pro
    Mostly stock TRD Pro
    Grabbed a 2x10 off the 70% discount pile at Home Depot and dropped it inbetween the bed stampings, then used the short end to box in a Rubbermaid Action Packer box for keeping straps, bungees, stinger/ball for towing. I did this in my 2012 until I put a canopy and bed slide on it. Need to bust out the hole saw and paint it black.
  4. May 28, 2024 at 11:33 AM
    TreeCat
    TreeCat New Member
    2017 White Limited 4x4
    Second at-home oil change and installed the all-auto window master switch from cartrimhome. About a month ago my driver door stopped unlocking with the remote or switch. Would lock fine though. Read a few posts on here with similar symptoms, guess weak door actuators are a known issue with the 2.5. Thought I would try a new master switch first because it was on sale (also the coupon code Kingsev7 still works) and less work, and of course my door decided to fix itself the day it arrived. Oh well, now I have auto control over all 4 windows which is nice. The blue led color is slightly more blue than the pale OEM blue color, but not really noticeable imo. If I can find a light-up rear-view mirror button then I'd be set. I'd recommend this part to anyone interested. And I'd also recommend to go ahead and buy the Motiv-X oil change kit. The cheap oil filter wrench I bought lasted 3 oil changes before stripping. Luckily I had a 27mm socket to put over the entire end and get this one done. Each oil change I was undoing the overtightening from the dealership, but I still expected the tool to last longer.
  5. May 28, 2024 at 11:53 AM
    reneaux
    reneaux I've been around
    2017 SR5 CM 4x4
    Installed some GoRhino D6 running boards. They were $515 shipped through RealTruck and come with a rebate to get a free medium sized hard case. Wanted sliders but just wasn't in the budget yet and with a pregnant wife we (I) needed a solution quickly.
    Also drained the coolant and refilled/burped. Easy but took longer than expected.
    Lastly did an oil change.
  6. May 28, 2024 at 12:51 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Trading bulletproof trucks at 1 to 2 year intervals is wild to me
    Nickutta, Johnmatrix, WFD473 and 4 others like this.
  7. May 28, 2024 at 1:46 PM
    Agreed. Especially if there wasn't any major changes.
  8. May 28, 2024 at 5:32 PM
    Terndrerrr
    Music City
    6UR-FE
    Removed TRD Fox shocks and reinstalled my factory original yellow Bilsteins shocks that came with the TRD Off Road package. Thinking I should have the TRD Fox kit rebuilt. ORRRRR…do I buy something else? :notsure:
    For future reference for anyone wondering which side the dots go on, mine had blue and yellow dots on the coils.
    The blue dot on the factory TRD Off Road shocks goes on the drivers side facing out. Yellow dot faces out on the passenger side.
    Driver side TRD Off Road shock on top here:
  9. May 28, 2024 at 5:43 PM
    RobertD
    Robert
    DFW, Texas
    If you have liked the Pro shocks, get them rebuilt. If they aren't worth the rebuild cost to you, buy something else that fits your needs. Rebuild will be less then a new set of shocks, but if you aren't happy with the performance I can understand not wanting to spend the rebuild money.
    bulldog93 and Terndrerrr[QUOTED] like this.
  10. May 28, 2024 at 5:53 PM
    Terndrerrr
    Music City
    6UR-FE
    I really like them. They felt great on any terrain. Nice and floaty. But I may start pulling a small camper around, and I wonder if there is something that better straddles the line between towing stability and off-roading with a small (2-3”) lift.
    bulldog93 and RobertD[QUOTED] like this.
  11. May 28, 2024 at 5:56 PM
    RobertD
    Robert
    DFW, Texas
    Rebuild and add RAS to the rear. @RainMan_PNW has the RAS with his Pro shocks
    Velocity72, Gecko., Jbehredt and 2 others like this.
  12. May 28, 2024 at 6:06 PM
    Terndrerrr
    Music City
    6UR-FE
    Already got RAS. It’s great. The plan is to have them rebuilt.
    Casey’s gotta be getting close to needing to rebuild his.
  13. May 28, 2024 at 6:13 PM
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Have a side pic of those running boards. Interested to see how high and tight they fit. Thanks!
  14. May 28, 2024 at 6:18 PM
    brodesiansneverdie
    brodesiansneverdie New Member
    2020 White Tundra SR5 CM
    Toytec Aluma 2.5/2.0 SPC UCAs U748s Method 705s Toyo AT3 285/75r17 RCI Aluminum skid OTT tune Softopper Decked V2 Diode Dynamics
    A little late, but this past week I had my SPC upper balljoints replaced with the new non-serviceable replacements for their UCAs as well as an alignment. I normally would not have been thrilled about losing the zerk fittings, but I was kind of over the ones that came with it after them blowing grease out within the first few thousands miles. I kept greasing them at regular intervals in the hopes I could make them last, but the constant loss of grease + the concerns about all the QC drop during COVID (when I purchased these) convinced me to pre-empitively upgrade them. They were surprisingly in decent condition so I'll keep them around in case I need an emergency back-up, but in the long run I'll probably move to a different brand UCA completely if I run into more issues.
    Also, finally started running 93 octane in my truck this week. I've had the OTT tune for about a year, but didn't think I was going to appreciate any noticeable gain on 93 and ended up completely forgetting about the need to try it out. 93 didn't turn it into a race car overnight, but I just finished a 300 mile drive from South Eastern NC to the Augusta, Ga area and was pleasantly surprised by how much more likely it was to hold 6th gear on slight inclines going through those rolling hills across SC. Overall trip mileage was noticeably a bit better than times I've made this trip previously, probably by roughly .5mpg to 1mpg keeping it in the 65-70mph range. Too early to tell if this is just a placebo effect or if I'll notice it over the long term.
    bulldog93 likes this.
  15. May 28, 2024 at 8:11 PM
    Begbie
    Begbie The big yellow one is the sun!
    Wilmington, NC
    2020 White Tundra Limited
    Purchased the black radio surround from Ourisman Toyota and installed it tonight. I love the look over the silver...especially alongside the tan leather. The only silver left inside now is on the doors (and radio of course)...and the chrome on the dials. Only one issue with the reassemble: the black trim that surrounds the instrument cluster has two pins that get inserted at the top side...for the life me, I can't get them reinserted correctly. I'll try to search here, I'm sure many have run into the same problem.
    Anyway, not a great pic since it got dark out and had to pull it into the garage.
    The bumper caps from Ecoological have been ordered and next purchase will likely be a TRD Pro grille (have the Limited chrome grille now)...just have to shop around, I guess.
    For the last few months, I was thinking about trading in and upgrading to a 24. But I just can't do it. Only 28K miles on a 2020 and that V8 engine runs so smooth. I can't give it up...so it's time to put some serious money into it after three years of stock(iness). ;)
  16. May 28, 2024 at 8:16 PM
    brodesiansneverdie
    Hey, another Wilmington Tundra! I did the TRD grill on my 2020 earlier this year; I ordered the grill, hood bulge (was on back order foreverrrr), and garnish from Hendrick Toyota in Apex and got a great deal when they were running one of their sales + free shipping. May be worth watching them to see if they have another sale running.
    bulldog93 and Begbie[QUOTED] like this.
  17. May 28, 2024 at 8:43 PM
    Begbie
    Wilmington, NC
    Very cool! Yeah, I've seen a few white Tundras around. I know we're all out there around town and on the beach.
    Thanks for tips too! I'll definitely check there. And that's the other thing I'm trying to avoid, is back ordered items and having to wait, but I guess I'm not in any rush. Like I said, I've had the truck three years and I've only blacked out some of the interior and replaced the chrome mirror caps to white. But it's definitely time to make some upgrades if I plan to keep it long term.
  18. May 29, 2024 at 7:37 AM
    reneaux
    2017 SR5 CM 4x4
    I will get you some shots when it stops raining out today. They sit snug to the body and have both side-to-side adjustment as well as up and down. Mine are touching the pinch welds under the door/rocker.
  19. May 29, 2024 at 10:38 AM
    Tboh1870
    Tboh1870 New Member
    Herman
    Just starting reno
    Anybody have recos for aftermarket Hood Bulge Grille surround? So much ebay junk to sort thru thought I'd ask the experts for reality. 2017 Mgm. Thanks!
  20. May 29, 2024 at 11:07 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
  21. May 29, 2024 at 2:17 PM
    2018Tundra
    VA
    The modding begins...tint all around.
  22. May 29, 2024 at 3:38 PM
    MJustice
    MJustice New Member
    Mitch
    Sacramento CA
    2021 Platinum Tundra MGM
    6 window Ceramic tint, TRD Exhaust, TRD front and rear sway bars, TRD BBS wheels, temporary 2" front leveling spacer.
    Did you buy it new? Have any oil leaks addressed since owning it? That's FIPG(form in place gasket) and factory applied FIPG is mostly grey, or orange for high temp like diff, transfer, trans.
  23. May 29, 2024 at 3:45 PM
    MJustice
    MJustice New Member
    Mitch
    Sacramento CA
    I'm a Toyota MDT and just bought a 2021 Platinun Tundra with 8500miles on it, bought a Toyota 10/100k for it without batting an eye. You can easily get your money back in repairs and extended warranty if you intend to keep it long term. You're eligible to buy an extended warranty as long as it's in factory warranty(which it is) just keep in mind the extended starts from date of first use, so not from the date of extended warranty purchase.
    bulldog93 and 2018Tundra[QUOTED] like this.
  24. May 29, 2024 at 4:15 PM
    Tsm503
    Tsm503 Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    De-badged the truck
  25. May 29, 2024 at 4:33 PM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    Looks awesome! :fistbump: For me this mod was totally worth the trouble and makes it so much easier to wash/dry.
    Now, how about those 'B' pillars? Gonna just leave that black vinyl on that naked truck?
  26. May 29, 2024 at 5:23 PM
    Tsm503
    2021 DC SR5
    Yeah I think it look a lot better. And wasn’t to hard to do in the sun, the adhesive came easily. Didn’t have to even use Goo Gone or anything. If you peal it parallel to the body panel, it will peal right off. As for the pillars, I dunno. Did you take the vinyl off of yours? Do you like it that way?
  27. May 29, 2024 at 5:37 PM
    Tboh1870
    Tboh1870 New Member
    Herman
    Just starting reno
  28. May 29, 2024 at 6:25 PM
    Pillslinger
    Rollin
    SWMO
    I did and I do. I like the way it breaks up the 'unibrow'. I like the way it looks on the DC also, but I think the change is more drastic on a DC too.20230315_160300.jpg
  29. May 29, 2024 at 6:31 PM
    Pillslinger
    Rollin
    SWMO
    Here's a DC example. Belongs to another member. @Jjclamdips39B3E1A2-7161-4B82-A1D3-47EC922F0BBB.jpg
  30. May 29, 2024 at 6:49 PM
    RoniusMaximus
    RoniusMaximus The One and Only
    J
    Tri-Cities, Washington
    2020 MGM Toyota Tundra TRD PRO
    Synthetic Blinker Fluid
    Installed Rokblokz XL mud flaps. Sticks out
    a bit more than I anticipated but it’s growing on me. I like it.
