  1. May 25, 2024 at 4:28 PM
    catus
    catus New Member
    Centennial, CO
    '19 MGM DC Limited, stock for now
    Just truck stuff at the horse rescue where I volunteer...
  2. May 25, 2024 at 6:44 PM
    centex
    centex New Member
    Only picture I got of it but it spent the day hauling a rototiller, concrete blocks, and dirt to build this.
    RainMan_PNW, Vr0ck, woods and 4 others like this.
  3. May 25, 2024 at 8:41 PM
    FireFinder44
    FireFinder44 New Member
    Albany, OR
    2019 Super White Tundra TRD Pro
    Mostly stock TRD Pro
    I did the zip tie fix for the Ridgid fog lights, LED bulb swap for the interior and license plate, installed my Blackvue dash cam and used the bracket for the rear camera from thedashcamstore.com, and installed my phone mount.
  4. May 25, 2024 at 9:26 PM
    Voda48
    Voda48 New Member
    Wisconsin
    2016 Platinum
    Used the truck to run to the hardware store, saw this out in the wild on the way there
  5. May 25, 2024 at 9:33 PM
    dan8906
    dan8906 New Member
    Daniel
    2017 MGM Tundra SR5 TRD OR, 2011 Tacoma TRD OR & 2004 Tacoma TRD OR
  6. May 26, 2024 at 4:14 AM
    koditten
    Kirk
    Midland of the Mitten
    dan8906[QUOTED] and bulldog93 like this.
  7. May 26, 2024 at 7:33 AM
    Retired Blue
    Retired Blue New Member
    Steven
    Round Rock, TX
    2020 Super White Platinum
    I'll get it dialed in. Just trying to figure this out...
    Before I installed Eibach Pro 2R shocks and RAS, my stock, center of hub to fender, measurements were:
    (in a flat parking lot, ~3/4 tank, ~600 lbs, in bed)
    LF = 20.84"
    RF = 21.28"
    RR = 22.59"
    LR = 22.34"
    After installation:
    (Eibachs @ out-of-package settings, RAS adjusted using white spacer, in a flat parking lot, ~5/8 tank, ~600 lbs, in bed)
    LF = 22.72"
    RF = 23.22"
    RR = 23.47"
    LR = 23.34"
    After first adjustment:
    (Added Durobumps, front and rear, which meant I needed to loosen and then re-adjust RAS; still using white spacer. LF Eibach raised 1/8", as measured on the shock. RF Eibach lowered 1/8", as measured on the shock. In a flat parking lot, ~full tank, ~600 lbs, in bed.)
    LF = 23.09"
    RF = 23.28"
    RR = 23.84"
    LR = 23.47"
    (Front) Driver's side lean: before = 0.44"; after installation = 0.5"; after adjustment = 0.19"
    At this point, I'll likely drive a few hundred miles and let all settle in before measuring again, and adjusting again, if necessary.
    Pics to come, after I wash the filthy beast.
    (Note: my tape measure does not have 100ths of an inch markings. Measurements were taken to the nearest 1/16th inch. However, my rims, both OEM and Fuel - Blitz, measure 21 9/16" in diameter, or 21.5625". I took height measurements from the lowest point of the rim to the bottom of outer fender (w/factory flares), then divided rim diameter by 2, and subtracted that from what I measured.)
  8. May 26, 2024 at 10:37 AM
    Tripleconpanna
    2021 TRD PRO CM; 2011 SR5 SC'd DC; 2008 SR5 CM
    So, here's something that I"ve always wondered...
    We are measuring the center of the hub to the bottom of wheel well in each corner (at least that's how most of us are doing it), and then we'd like to see a 'level' truck so adjustments are made. But, are the discrepancies in the suspension or the cosmetic potions of the body (bed and front quarter panels)??? The reason I'm wondering, is because if the discrepancies are in the body and how it ties in to the frame, are we ending up w/a suspension that's not 'level' to have the appearance of 'level' truck in the area where the measurements are taken?? :notsure:
    BlueRibbon4x4 likes this.
  9. May 26, 2024 at 11:01 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Yes, factory driver spring is longer for reference
    Tripleconpanna likes this.
  10. May 26, 2024 at 12:46 PM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Gained at least 15HP with some @ToyoMafia goodies today
  11. May 26, 2024 at 1:25 PM
    TrashcanBand
    TrashcanBand New Member
    CenTex
    Tundra
    Ticked over 90K miles and toted around the legend today. He went to the groomer if you can’t tell by the entire tufts of hair he’s leaving in the seat.
    RainMan_PNW, junior, TreeCat and 7 others like this.
  12. May 26, 2024 at 1:43 PM
    BoyHowdy
    BoyHowdy New Member
    2021 Tundra
    Looks like you could a seat cover
  13. May 26, 2024 at 2:02 PM
    MJustice
    MJustice New Member
    Mitch
    Sacramento CA
    2021 Platinum Tundra MGM
    6 window Ceramic tint, TRD Exhaust, TRD front and rear sway bars, TRD BBS wheels, temporary 2" front leveling spacer.
    I can't get a good guess on how big it is from the picture... is it a terminal post cap from a battery replacement? Not threaded inside I'm guessing. Could have been a cap to some sort of sensor or something that was replaced. I wouldn't be terribly concerned, being I'm a toyota technician. I'd guess it's just a piece of trash
    MS22[QUOTED] likes this.
  14. May 26, 2024 at 2:31 PM
    Retired Blue
    Steven
    Round Rock, TX
    Let me give her a bath, and then I'll tell ya. :burp:
  15. May 26, 2024 at 3:20 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    Not threaded inside, just a soft plastic cap of some sorts. I was hoping that it was a cap that was dropped down in there and nothing important. Lol, I was not looking forward to all the stuff it looked like I was going to have to take off to get access in there. A lot more bits and pieces on the 5.7 than my 4.7. Appreciate the reassurance :thumbsup:
    MJustice[QUOTED] likes this.
  16. May 26, 2024 at 3:36 PM
    BoxersBrew
    BoxersBrew New Member
    Thomas
    Northern Virginia
    2020 Black Tundra Limited Crewmax TRD
    Dealer installed TRD dual exhaust system and tonneau cover. Personally installed TRD Pro grille and surround, side mirror caps, and TRD shifter.
    Looks like a cap that would go over a grease fitting.
  17. May 26, 2024 at 3:42 PM
    texasrho83
    texasrho83 Ye Olde Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Still waiting on the ol mailman to bring me mine
    JMGmanAZ and Tripleconpanna like this.
  18. May 26, 2024 at 3:44 PM
    BoxersBrew
    Thomas
    Northern Virginia
    Saw this the other day.
    IMG_20240522_181535.jpg IMG_20240522_181510.jpg IMG_20240522_181626.jpg IMG_20240522_181601.jpg
  19. May 26, 2024 at 6:09 PM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    The wait is well worth it
    sbxx312 and texasrho83[QUOTED] like this.
  20. May 26, 2024 at 6:12 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    BreyTundy[QUOTED] likes this.
  21. May 26, 2024 at 6:28 PM
    Rugerla1
    Rugerla1 New Member
    Tennessee
    2018 Tundra TRD Sport
    Good evening everyone!
    Started arranging a few things on my molle seat panels. Have a couple of bags I’m going to put on soon and still have to figure out a way to mount a small fire extinguisher. I’m liking it so far. IMG_5956.jpg IMG_5958.jpg
  22. May 26, 2024 at 8:35 PM
    ghott86
    ghott86 New Member
    VA
    ‘21 Super White SR5 CM 4x4
    Not a "what I've done to the Tundra" post...but my middle son and I took the truck for a "range day" yesterday to do some plinking. He was all smiles.
  23. May 26, 2024 at 8:37 PM
    Rugerla1
    Rugerla1 New Member
    Tennessee
    Doesn’t get much better than that!
  24. May 26, 2024 at 11:18 PM
    J's 4x4
    J's 4x4 New Member
    Juan
    Los Angeles County
    2020 Tundra Cement Grey TRD 4x4
    King lift,Leather seats,3m film wrap around,35's KO2 on FUEL Wheels,Line-X, backflip,Bam 10" exhaust with Toyota Black Chrome Exhaust tip,Amp research step,K&N air Filter,TRD air flow Accelerator
    Almost done with wiring my rear bumper lights. Think I spent more time trying to figure out how to hide and run the wire then installing the lights them selves . Tested the lights with a battery and wiring seems all good. Have a goodnight all
  25. May 27, 2024 at 6:37 AM
    Retired Blue
    Steven
    Round Rock, TX
    Giving this some thought. Maybe so. I know when I jack it up, either from the pumpkin, or from the center of a front cross member, the passenger side tires always clear the concrete first. Even on the alignment rack, raised on a cross member but with the two support points outboard, and close to the frame rails, the passenger tires were higher off the platform than the driver tires. Are our Tundras just heavier on the driver's side, or are our suspensions designed to droop more on this side, or both?
    If we tried to level by measuring frame height off the concrete, where, what points on the frame, would we measure?
  26. May 27, 2024 at 7:02 AM
    coTony
    Tony
    Montrose, CO
    Where did you find the molle panels for the back of the seat?
  27. May 27, 2024 at 8:35 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Back from Vegas for the annual offroad trip. Couple busted rear bumpers, and an exploded rotor (not mine). The new Kings are amazing.
    F54EC023-1461-4C28-A743-B1A1306F2C81.jpg IMG_0572.jpg IMG_0551.jpg IMG_0422.jpg IMG_0424.jpg
  28. May 27, 2024 at 8:39 AM
    RobertD
    RobertD SSEM#123
    Robert
    DFW, Texas
    Obviously not your rotor, that caliper isn't painted :rofl:
    Glad you had a good trip and the new shocks are being a noticeable difference.
  29. May 27, 2024 at 8:57 AM
    Rugerla1
    Rugerla1 New Member
    Tennessee
  30. May 27, 2024 at 9:39 AM
    BlueRibbon4x4
    Geno
    Yessir! It was an awesome trip
