  1. May 13, 2024 at 2:33 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Same, 3 sets of bushwhacker smooths on my gen 2 and 2.5's and rough country's on my 22 tundra. Fender flares should always be color matched, from a purely aesthetical point of view as well. If and when I do the sequndra conversion Ill do the bushwhacker smooths, again.
  2. May 13, 2024 at 2:56 PM
    redrum448
    redrum448 New Member
    Anyone have a link to the 2 -12v jack plate 3d print for the back of the armrest please?
  3. May 13, 2024 at 3:20 PM
    AZTundra
    Paul
    Phoenix, AZ
    Just following up. Discount Tire had set them to 37 PSI for both front and rear. I emailed Falken earlier this morning and below is their response. I think I'll drop the front down to 35 PSI and then do a chalk test.
    Per Falken Tire:
    Your OEM Size (P275/65R18 114 SL) has a load capacity of 2,421 lbs. @ 30 psi. per tire in the front and 2,535 lbs. @ 33 psi. per tire in the rear; if you were staying in a metric size this is the load capacity you want to meet or exceed.
    Passenger type tires are fitted with a 10% overage in load capability when used on SUV's, Light Trucks, and Vans because of the difference in load handling. This load overage can be removed when changing to an LT type tire, that brings the effective load capacity to achieve down to 2,201 lbs. in the front and 2,305 lbs. in the rear.
    The new size (35X11.50R18LT 117 C) has a load capacity of 2,205 lbs. @ 35 psi. cold in the front and 2,349 lbs. cold @ 38 psi. in the rear; this would be the recommended air pressure for everyday driving.
    Best Regards,
    Falken Tire- Quality Assurance Team
    8656 Haven Avenue
    Rancho Cucamonga, CA 91730
    P 800-723-2553 Ext 2
    Monday- Friday 8 A.M to 5 P.M Pacific Time
  4. May 13, 2024 at 3:38 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    That's a great follow-up! Thanks! I always thought you put a bit less in your rear tires when rolling empty and increase the PSI when loaded...
    AZTundra likes this.
  5. May 13, 2024 at 3:52 PM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    This one...? Just got mine in today:
  6. May 13, 2024 at 4:37 PM
    redrum448
    Yes, but Id like to print my own and I know the file has been shared here before I just cant find it
    rdiddy5 and JMGmanAZ[QUOTED] like this.
  7. May 13, 2024 at 5:01 PM
    Sent you a PM
    bulldog93, HulkSmurf14 and JMGmanAZ like this.
  8. May 13, 2024 at 5:08 PM
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    Any chance you could PM me the same info?
  9. May 13, 2024 at 5:10 PM
    PM sent.
  10. May 13, 2024 at 6:31 PM
    thebuildist
    thebuildist New Member
    Bob
    2017 SR5 Crewmax 4x4
    Rear seat storage
  11. May 13, 2024 at 6:52 PM
    Bayou Spartan
    Bayou Spartan New Member
    Black 2019 TRD PRo
    None
  12. May 13, 2024 at 7:14 PM
    thedoodab1des
    thedoodab1des New Member
    2021 Voodoo Blue Tundra Crewmax
    Step 1. Bought Truck Step 2. Mod
  13. May 13, 2024 at 8:00 PM
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    Some progress today.
    Installed the carrier bearing drop kit and no more vibrations! Issue solved.
  14. May 13, 2024 at 8:19 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    That’s one thing I miss from my 2008. But the sunroof won’t let me do that to my current rig
    bulldog93 and RobertD like this.
  15. May 13, 2024 at 8:22 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Really?
    I hadn’t ever seen the actual file shared…
    Tripleconpanna and RobertD like this.
  16. May 13, 2024 at 9:20 PM
    AZTundra
    Paul
    Phoenix, AZ
    Let me know if you get anything in the crankcase can. Mine has been bone dry in over 4 years and 37k miles. The pcv can gets a good amount at each oil change.
  17. May 13, 2024 at 9:22 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    I need to do this!
  18. May 13, 2024 at 9:25 PM
    AZTundra
    Paul
    Phoenix, AZ
    Radium makes a great kit. A bit pricey compared to others, but no complaints here.
  19. May 13, 2024 at 9:50 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Did you leave out the 'baking' step of the process??? :crapstorm:
    bulldog93 likes this.
  20. May 13, 2024 at 10:01 PM
    kcaustin66
    kcaustin66 New Member
    kevin
    Palestine Texas (East Texas)
    2015 Toyota Tundra CM 1794 4wd
    3” lift, black step bars, aftermarket wheels, LT305/55R20 was this way when I brought it.
    Installing a wireless charger, glued it down and then put black duct tape to help seal board. And will plug in in center console.
  21. May 14, 2024 at 3:53 AM
    PixelPusher
    PixelPusher New Member
    New Hampshire
    2020 Tundra Limited, Super White
    What charger did you pull those electronics from? How well does it function?
  22. May 14, 2024 at 4:03 AM
    sofaking
    sofaking New Member
    Karl
    2021 Toyota Tundra SR5
    What brand are those?
  23. May 14, 2024 at 4:30 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Since you’re down there… If you push up and down on the driveshaft, do you have any movement in the bushing?
    When I push up and down on the driveshaft next to carrier, I get about 1/4”-3/8” total movement in the bushing. Not sure if that’s normal or bushing is shot. I’ve been experimenting with various sized carrier bearing drops and can’t get rid of my vibration.
    coTony likes this.
  24. May 14, 2024 at 4:52 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    careful with the fuse that runs that circuit. if you have 3 iphones charging on that same cicuit...it will blow.
    I learned this upon taking the fam to a concert* & everyone was charging. and I keep an Ipad, in the center console, on the charger connection under the lid.
    *it was The Eagles. and Steely Dan opened. all those dudes got old, but could play like the old days.
    thedoodab1des and koditten like this.
  25. May 14, 2024 at 4:53 AM
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    I did the same an noted similar movement. I took a short vid. for reference. For sure someone here can tell us if this is normal.
    https://youtu.be/1HuMe0ZoOgA
    Looks like it is normal. Other related post:
  26. May 14, 2024 at 7:03 AM
    GLaDOS
    GLaDOS Engineer
    Central Oregon
    2014 Tundra SR5 Double Cab
    Wait, what? The can directions don’t mention anything about baking…
  27. May 14, 2024 at 7:53 AM
    kcaustin66
    kevin
    PixelPusher[QUOTED] likes this.
  28. May 14, 2024 at 8:09 AM
    kcaustin66
    kevin
    I have a charger that has 2 charging ports (me and the wife) so now 1 is wireless and the other is a wire for her. But thanks for the heads up.
  29. May 14, 2024 at 8:10 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Driving around data logging and tuning
  30. May 14, 2024 at 8:28 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Had an unexpected day off for Election Day; oil and filter change, cabin and air filter clean and recharge and replaced all of the weatherstrip gaskets on my diamondback HD to better keep the water out. Productive day so far - and now it’s raining so finished just in time
