  1. Mar 13, 2024 at 5:26 AM
    Henry1jg
    Henry1jg 2021 TRD Sport
    MI
    You said that these are knockoffs. Can you send a link? They look fantastic!
  2. Mar 13, 2024 at 6:02 AM
    Gecko.
    Gecko. New Member
    CT
    2014 Tundra DC
    Looks good. :thumbsup: Where did you buy them? Thnx in advance.
    Vizsla[QUOTED] likes this.
  3. Mar 13, 2024 at 6:57 AM
    texasrho83 likes this.
  4. Mar 13, 2024 at 7:11 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    Henry1jg likes this.
  5. Mar 13, 2024 at 7:18 AM
    Wishbone Runner
    Wishbone Runner Toyota Connoisseur
    2019 Platinum
    :rofl: That makes much more sense. Looks good!
    JMGmanAZ[QUOTED] likes this.
  6. Mar 13, 2024 at 7:24 AM
    RobertD
    Robert
    DFW, Texas
  7. Mar 13, 2024 at 7:30 AM
    Vizsla
    Vizsla 2 = 2.5
    Thanks. Have to completely disassemble the hood bulge to install, little invasive because of the welded plastic fasteners used during assembly.
    The lights are the 150LM 3” - https://www.vleds.com/shop-products/light-bars/wpb-hv-a.html
    Gecko.[QUOTED] likes this.
  8. Mar 13, 2024 at 7:51 AM
    I thought those looked like Vleds when you posted. How did you attach them? The 3M tape?
  9. Mar 13, 2024 at 7:52 AM
    Henry1jg
    MI
  10. Mar 13, 2024 at 7:54 AM
    Gecko.
    Gecko. New Member
    CT
    2014 Tundra DC
    Thank you. Can I assume you went with two 3" pass through bars and one 3" end bar?
    Seems the pass through bars are out of stock with no eta on restock. :(
  11. Mar 13, 2024 at 8:17 AM
    Vizsla
    Vizsla 2 = 2.5
    Yes, and the 10’ extension to get to the parking light circuit. Have to notch out a tiny section of the grille at the end(s) behind the light to pass the wire connector(s) through, 4 - M3 lock washers, washers and screws attach each light from the back through the grille. Screw spacing is perfect for the grille. Wiring is fastened to the top inside of the grille cavity at the mid point between each light, and exits through a grommet in the end of the cavity.
    bulldog93 likes this.
  12. Mar 13, 2024 at 9:05 AM
    Tundra21NS
    Tundra21NS New Member
    2021 Black Tundra limited Nightshade Edition
    Pimpala1962 and Henry1jg[QUOTED] like this.
  13. Mar 13, 2024 at 9:17 AM
    roughfisher
    roughfisher Aggressive hockey is back in town!
    JP
    Northern Minnesota
    2021 MBM CM SR5 TRD OR 4x4
    great looking rig sir, even if you have cheesehead plates :p
  14. Mar 13, 2024 at 9:19 AM
    Vizsla
    Vizsla 2 = 2.5
    That happens with them, had to wait almost 3 months last year for a 6” red bar. Probably be fine to use 3 end bars, just order the 3 way splitter, or cut the plugs off and wire them together with whatever. Might be little harder to hide wiring, but less notching of the grille.:notsure:
    https://www.vleds.com/base-adapter-2-pin-waterproof-y-adapter.html
  15. Mar 13, 2024 at 9:25 AM
    Gecko.
    Gecko. New Member
    CT
    2014 Tundra DC
    Yup, that's exactly where my mind was wandering off to.
  16. Mar 13, 2024 at 9:43 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Thanks. Looks great on black. I'll have to pick up a set.
    Tundra21NS[QUOTED] likes this.
  17. Mar 13, 2024 at 12:56 PM
    Oops
    Gaston[QUOTED], Gecko. and RobertD like this.
  18. Mar 13, 2024 at 2:24 PM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    Finally got around to doing the first brake job at 50k miles. I know some people do not like the powerstop z36 rotors but I wanted to give them a try. so far so good but they are barely bed in. I also swapped in stainless steel red pvc coated brake lines, changed the brake fluid, and painted the calipers. Now I just need to do a good spring cleaning and a wax.
  19. Mar 13, 2024 at 2:36 PM
    Reddawg1100
    Reddawg1100 New Member
    FL
    21 SR5 Midnight Black DC, AKA: Bat Truck
    Custom rims, front leveling spacers
    Nice job on the brakes and all... but we need many more pictures of the Vette! That looks sweet!
  20. Mar 13, 2024 at 2:59 PM
    justcuz
    justcuz 2.5 Gen Member
    Applied “back to black” on the tailgate handle after waxing the truck. IMG_2902.jpg
  21. Mar 13, 2024 at 3:21 PM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    What brake lines did you go with?
  22. Mar 13, 2024 at 3:29 PM
    Tundra21NS
  23. Mar 13, 2024 at 4:22 PM
    Lifer
    Lifer New Member
    Vince
    2000 Ltd 4x4 2008 SR5 4x4 LB 2021 SR 4x4 LB
    Fab tech on the 2000
  24. Mar 13, 2024 at 4:34 PM
    TundraMidwesterner
    Northern Illinois
    Crown. originally I ordered the powerstop lines but they didn't ship for Maybe 6 weeks. I called up powerstop and apparently they don't actually make them anymore.
    koditten, Vr0ck[QUOTED] and bulldog93 like this.
  25. Mar 13, 2024 at 6:41 PM
    kbahus
    kbahus New Member
    MI
    2015 MGM Tundra Limited Crewmax
    Genuinely curious as to what the country of origin is on those RC parts?
  26. Mar 13, 2024 at 7:01 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    I hate moving!
  27. Mar 13, 2024 at 8:00 PM
    bflooks
    bflooks New Member
    Metrowest MA
    There are people who do this for a few bucks. You just point and shit automagically moves. :)
    You've got this! Keep up the good work.
  28. Mar 14, 2024 at 1:57 AM
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    What paint did you use?
  29. Mar 14, 2024 at 7:20 AM
    TundraMidwesterner
    Northern Illinois
    I've had great luck with the Duplicolor ceramic caliper paint kit. I've done 4 cars or so over the last 10 years. One kit is enough paint to do 2 or 3 cars easily. I dremel, wire wheel, the rotor then clean with brake cleaner and a toothbrush.
    It's brush on, I did 2 coats in an hour on each caliper, two calipers at a time. Key is getting the caliper prepped right, nice and clean then after paint you give it MORE than 24 hours to cure, I let mine sit for 48.
    https://www.amazon.com/Dupli-Color-BCP400-Single-Brake-Caliper/dp/B000B6AF80?th=1
  30. Mar 14, 2024 at 7:22 AM
    Lifer
    Lifer New Member
    Vince
    Moving does suck man but new places are cool too! Beautiful rigs, nicely set up.
    CaptRussia253[QUOTED] likes this.
