  1. Jan 14, 2024 at 10:26 AM
    tjthescott
    tjthescott New Member
    that looks good!
  2. Jan 14, 2024 at 10:26 AM
    AZBoatHauler
    So.Arizona
    Use a torque wrench. The spec is like 7 ft lbs for the bottom plug and 15 for the housing.
  3. Jan 14, 2024 at 10:27 AM
    koditten
    Kirk
    Midland of the Mitten
    It's because you install the plug cool, but remove it when hot. It swells from the heat
    If you let the truck cool overnight, then removed the plug, it would come out easy.
  4. Jan 14, 2024 at 10:28 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    So the muffler is what comes in the 6, 8, 10, or 12 options?
  5. Jan 14, 2024 at 10:30 AM
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    Is that a factor lift if so what size tires did you go with?
  6. Jan 14, 2024 at 10:31 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Fancy torque wrench lol, fair point made to correct the problem. Just a little extra ugga ugga's, but no UGGAs should do it. :)
  7. Jan 14, 2024 at 10:40 AM
    S13ka24de
    S13ka24de New Member
    What size tire n rim u got there?
  8. Jan 14, 2024 at 10:42 AM
    S13ka24de
    Any drone noise?
    Tundra Dude 45 likes this.
  9. Jan 14, 2024 at 11:04 AM
    JaBeau
    JaBeau Grumpy Old Metalhead
    Ohio
    '15 SR5 CM
    Braved the elements and removed damaged bully bar, grille, and headlight. Discovered hidden damage. Reinstalled damaged goods, cracked open a beer and fantasized about the one who walked away slowly roasting, marinated, upon the grill.
    Oh, and swapped the interior lights to LEDs.
    bulldog93 likes this.
  10. Jan 14, 2024 at 11:11 AM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    2019 Super White 1794 Edition Tundra CrewMax 4x4
    3/2" Readylift, TRD Dual Exhaust, TRD Sway Bar, Line-X Bedliner, ArmorFlex Tonneau, ESP 3 bin storage, Amp Power-Steps, Driver Side Grab Handle, Ronin Antenna, Window Tint, ClearBra. Coming Soon: 20" Method MR305NV. BF Goodrich KO2 275/60/20
    Unfortunately my torque doesn't go that low. I'll get one that does for next time but for now I'm just going to do my best guess to achieve these numbers. Thanks!
    Oh, and I'll try the cold removal of the housing drain plug first next time.
    koditten and bulldog93 like this.
  11. Jan 14, 2024 at 11:20 AM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    I use a torque wrench and that seems to work. I change the oil after warming it up for a few minutes, so the oil is slightly warm but the metal is ok to handle.
    bulldog93 and Long Duck Dink like this.
  12. Jan 14, 2024 at 11:21 AM
    Azblue
    The Dirty T ( ^_^)_且
    I just never take that plug out. It's easier for me to just slowly lower the housing over my drain pan and dump it out.
    Voda48, koditten and bulldog93 like this.
  13. Jan 14, 2024 at 11:27 AM
    Yes
  14. Jan 14, 2024 at 12:02 PM
    Tundar the Barbarian
    Tundar the Barbarian New Member
    2020 MGM TRD OffRoad
    Speakers, amp, subs, floorboard lights...and the little step thing under the bumper
    New wipers so they hopefully won't 'scrunch' in light rain.
    Changed the oil...Fumoto plug is the bomb-diggity...not a drop outside the pan, and very little there!
    Forgot to drain the filter casing first, so that was a little messy, but still confined to drain pan.
    Toughttundra and bulldog93 like this.
  15. Jan 14, 2024 at 12:08 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    Thank you! :thumbsup:
  16. Jan 14, 2024 at 12:15 PM
    TacomaTRD4x402
    Southern California
    Correct, that's what determines how loud you want it. I just went for a drive and the 8" is definitely a good choice. Description on the website is spot on. It's quiet when idling and really brings the sound of the v8 when you step on it. I'll post up a cold start video in a bit..
    @Oey12
    https://youtube.com/shorts/H8MXKKZA1u4?feature=shared
  17. Jan 14, 2024 at 12:16 PM
    SAGE63
    San Diego County
    Keith will also make other dimensions just call him or email
    TacomaTRD4x402 and Oey12[QUOTED] like this.
  18. Jan 14, 2024 at 12:47 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    I am between the 8 and the 10 without the resonator. And just recently started researching. Don’t wanna make the wifey or kids mad if it is too loud.
    I am planning to call him in the next few months. I am not buying until it warms up…lol. There are other questions I have…. One being, does the muffler size have any effect on performance?
  19. Jan 14, 2024 at 12:53 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    It will sound even better when under 'load'... IE>>> In drive and rollin'; it's way different in park revving the engine than it is on the road :thumbsup:
    You'll be even more :bananadance:
  20. Jan 14, 2024 at 1:07 PM
    2Tall
    2Tall New Member
    Chance
    South MS
    2020 Super White CM SR5 4x4
    Engine oil and filter, t-case oil, front diff oil, cleaned air filter.
  21. Jan 14, 2024 at 1:40 PM
    WAtundra4x4
    Den
    Wet side WA
    Yikes, it looks like your filter is starting to decompose. How many miles on the filter?
  22. Jan 14, 2024 at 1:45 PM
    2Tall
    2Tall New Member
    Chance
    South MS
    Are you talking about the drain plug? That’s from the front diff.
    koditten likes this.
  23. Jan 14, 2024 at 1:48 PM
    TacomaTRD4x402
    Southern California
    Yeah, it sounds awesome! I took it out for a drive to my mom's house and really opened it up. :bananadance: Lol
  24. Jan 14, 2024 at 1:54 PM
    WAtundra4x4
    Den
    Wet side WA
    Oops my bad, needed to refocu my eyes..
    2Tall likes this.
  25. Jan 14, 2024 at 1:58 PM
    TacomaTRD4x402
    Southern California
    :rofl: I saw the same thing too quickly looking at it
  26. Jan 14, 2024 at 2:33 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    I just bought fluid for my front/rear diff, transfer case and transmission. Need to do mine soon before the move.
    2Tall[QUOTED] likes this.
  27. Jan 14, 2024 at 2:34 PM
    CaptRussia253
    Ruslan
    First patch for the tundra. Thanks @STravis
  28. Jan 14, 2024 at 3:23 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    9 ft-lbs for the plug and 18 ft-lbs on the housing.
    And as Josh also said, lube that o-ring for the plug. I've never had it locked up on me since I started doing my own changes (as opposed to the time I had to use an air impact to get the housing off after the dealer did it).
  29. Jan 14, 2024 at 5:06 PM
    ThatGuyTheCooler
    ThatGuyTheCooler New Member
    I have the 6", no resonator, and it's not too loud
  30. Jan 14, 2024 at 5:48 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Right? Better than the 9 today. Everyone will be walking into work sick next week lol
    FISHN43[QUOTED] likes this.
