  1. Jan 4, 2024 at 4:42 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    He's really good at those offers. He's kind of a pusher
    bulldog93, RobertD and TRDFerguson like this.
  2. Jan 4, 2024 at 4:43 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Can confirm. Hard pusher.
  3. Jan 4, 2024 at 4:43 PM
    Cthulhu
    Daaaaammmmmmnnnniiitttttt!!! :annoyed:
  4. Jan 4, 2024 at 5:51 PM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    Nice looking truck! Darn it, now I have to remove step bars and paint my wheels!
  5. Jan 4, 2024 at 6:13 PM
    Quicksand_Tundra
    Quicksand_Tundra New Member
    Jon
    2019 Quicksand Tundra CM 4x4
    -Color keyed grill & bumper -Diode Dynamic SAE LED Foglights -Headlight Revolution LED Light upgrade -SCS SR8 18x9 with 295/70/18 Toyo Open Country AT3 -Go Rhino Dominator D6 Steps -TRD OEM Intake & Dual exhaust -Bilstein 6112 front and 5160 in rear -JL Audio C2 6.5" speakers upgrade powered by JL Audio RD 400/4 amp -Pair of AudioFrog GS25 speakers front dash -10” Kicker Hideaway subwoofer under driver seat -All doors covered with Soundskins deadening mat (inside/outside) -Front window tinted at 35% -Paint protection film full front -30” Rigid Industries SAE light bar -Body Mount Chop -Diode Dynamics SS2 (red) setup for brake light & turn signal -Katzskin Custom leather upgrade (Black/Bamboo) -Amber led running lights (Hood bulge) -AJT Design: Black vent rings, steering wheel trim, shift gate trim, emblem overlay -AJT Design: Quicksand door handle cover -Carbon fiber wrap (silver part on door panel) -Air Design tailgate applique (Line-X in smooth gloss finish) -Air Design tailgate spoiler (Line-X in smooth gloss finish) -Smittybilt beaver step (Line-X) -Valhalla Cat Shield (Line-X) -Coachbuilder Shackles kit +2 -Coachbuilder Strut/Coilover shim (0.5" for driver side) -Sumosprings (rear bumpstop) -Meso Custom Led front and rear cab lights -Teton shop shift knob -TRD Seat belt shoulder pad -Husky floor liner front/back -LED courtesy door/step light -LED bed light kit w/ outside switch
    Just realize the screws actually goes thru the wheel well into the bed. Not good!
    So, I did some modifications. Found the shortest screw possible with a hex nut to secure it inside the bed. This helps by shortening the length of the screw. I do not want to gash my ankle or feet on the open screw. I also painted the screws on the bracket black to blend in with the liner.
  6. Jan 4, 2024 at 6:35 PM
    Was the line too short to mount to the frame rail?
  7. Jan 4, 2024 at 7:25 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Those look perfect for you rig's current set up :muscleflexing:
  8. Jan 4, 2024 at 8:06 PM
    dan8906
    dan8906 New Member
    Daniel
    2017 MGM Tundra SR5 TRD OR, 2011 Tacoma TRD OR & 2004 Tacoma TRD OR
    You could flip the bolt around so the nut if on the other side
  9. Jan 4, 2024 at 10:39 PM
    RainMan_PNW
    Casey
    Clark County, WA
    perhaps reverse the screws so the heads are inside the bed and the nuts are by the reservoir?
  10. Jan 5, 2024 at 7:45 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
  11. Jan 5, 2024 at 9:04 AM
    Quicksand_Tundra
    Jon
    Thanks. Your setup is nice. But I'll check again to see if the line is long enough. If you look at the Bilstein, the line comes from the side instead of from the top. It will swivel, but I'll see if it's possible. Thanks.
  12. Jan 5, 2024 at 9:10 AM
    Quicksand_Tundra
    Jon
    Yes. I actually wanted to do that, but the screw will extend too far out where it will hit the reservoir. I will go back to the hardware store to look for a shorter bolt and redo it. Will keep ya posted. Thanks.
    bulldog93 likes this.
  13. Jan 5, 2024 at 9:43 AM
    RainMan_PNW
    Casey
    Clark County, WA
    If you’ve got a grinder or hacksaw, you can make that bolt as short as you want.
    you can also get low profile nylock nuts
  14. Jan 5, 2024 at 10:04 AM
    dan8906
    dan8906 New Member
    Daniel
    Was going to say the same thing.
  15. Jan 5, 2024 at 10:06 AM
    coTony
    Tony
    Montrose, CO
    I was wondering where you found that little space. I have looked there and did not see anything but thought you had it. Always look before you drill :hattip:
  16. Jan 5, 2024 at 11:31 AM
    831mic
    831mic 2016 DC TRD PRO
    California
    '16 DC TRD PRO
    dropped the RSB mounting hardware off at the powder coater. My OCD will thank me later.
  17. Jan 5, 2024 at 12:19 PM
    D3VA
    D3VA New Member
    NoVA
    2021 TRD Pro in the MGM Master Race!
    Received my replacement black center instrument panel from Sparks today and in plenty of time for the removal of the silver unit and install of the new Alpine HU next week.
  18. Jan 5, 2024 at 12:36 PM
    srfndoc
    srfndoc New Member
    2018 Tundra SR5 Crewmax 5.7L
    Bilstein 5100's all around, top setting up front. Nitto Grappler G2's.
    New shoes for the Tundra. The dealer installed rubber lasted all of 25k miles.
  19. Jan 5, 2024 at 12:50 PM
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    I found the same on my original tires (Bridgestone Duelers). Just replaced them with Michelin LTX Defenders a few weeks ago.
  20. Jan 5, 2024 at 12:56 PM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Sparks offers a black center console? Never seen that before.
  21. Jan 5, 2024 at 2:02 PM
    RobertD
    Robert
    DFW, Texas
    Its for the SR trim. But it fits the same and many folks have bought it.
  22. Jan 5, 2024 at 2:14 PM
    redrum448
    redrum448 New Member
    part number please?
    RustyShackle323 likes this.
  23. Jan 5, 2024 at 2:15 PM
    Do58
    Do58 New Member
    Very nice!…. Any chance you have a part number?
  24. Jan 5, 2024 at 2:15 PM
    -MRibz-
    -MRibz- New Member
    San Diego
    2020 Crew Max 4x4
    Center Panel - Toyota (55405-0C010-C1)
    Just noticed that's for a
    2wd
    Do58 likes this.
  25. Jan 5, 2024 at 2:15 PM
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    Or look for one from a wrecked truck. I got one on EBay from a wrecking yard pretty cheap.
  26. Jan 5, 2024 at 2:18 PM
    -MRibz-
    -MRibz- New Member
    San Diego
    2020 Crew Max 4x4
    Instrument Panel Trim Panel - Toyota (55405-0C020-C1)
    4wd
  27. Jan 5, 2024 at 2:22 PM
    D3VA
    D3VA New Member
    NoVA
    The 0C020 is for the 4wd.
    Post 71 & 72 from the Interior Blackout Thread. The 2014-2020 part number works in the ’21 TRD Pro, which is the part I ordered. As stated, it doesn't show as a fit for the '21 TRD Pro as that black trim option wasn't available.
    https://www.tundras.com/threads/interior-black-out.103677/page-3#post-3436432
    These appliques also work but have small areas where you can see the silver trim. I opted for the Toyota part as I’m having the head unit replaced next week and thought it would be easier for the installer to tear apart the dash than me struggling with it.
    https://www.amazon.com/dp/B09KXZ741X?smid=A2SIJPKG1AJQB7&th=1
    bulldog93 and Do58 like this.
  28. Jan 5, 2024 at 3:01 PM
    Cliffy34
    Cliffy34 New Member
    Pittsburgh
    2018 White Tundra SR5 Crewmax
    20x9.5 +6mm Black Rhino Axles and 275/65/20 Milestar Patagonia XT’s going on Tuesday. Got the Dorman 610-471 wheel studs as well. Pretty excited for these! Will post pics once they’re mounted.
    Got a helluva deal on the wheels. Buy 1 get 3 free thanks to a Discount Tire price error on eBay!IMG_5230.jpg 72608021236__ED4D9270-C229-4A60-AD51-F0B01F3F535C.jpg
    Wallygator, Nbab23, rdiddy5 and 11 others like this.
  29. Jan 5, 2024 at 3:21 PM
    TacomaTRD4x402
    Southern California
    20" OEM wheels are getting powder coated right now so running around on these 18" rollers for now but I'm actually liking the look of these wheels but are definitely gonna see a good powder coat when my 20" tires are due for a change.
    Also, JUST received a package.. any guesses what it could be?
  30. Jan 5, 2024 at 3:22 PM
    Cat shield?
