  1. Oct 10, 2023 at 10:09 PM
    Boisefly
    Boisefly New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    Appreciate the info!!
  2. Oct 11, 2023 at 6:16 AM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    I removed the wireless charging tray on my truck because it was useless for my iPhone 14. I have a different setup for that now, so that is no longer tapped into the 12V rear console plug.
    I used the wire that came with the charging sockets but cut all the terminals off to adjust wire lengths. I took the two + cables and crimped them into a single male blade terminal and the two - wires and did the same. Those two male blade plugged into the OEM 12V plug and then crimped female blade terminals on the 4 wires and connected to the charging sockets.
  3. Oct 11, 2023 at 7:02 AM
    15SR5CM
    15SR5CM New Member
    Roseville, CA
    2015 SR5
    Bilstein 6112/5160 3/1 w/CB shackles Ironman front bumper, 18+SR5 Honeycomb grill
    sooo...does it fast charge? at least one socket?
  4. Oct 11, 2023 at 8:54 AM
    WCTXN
    WCTXN New Member
    2014 TRD boosted Platinum 4x4
    Custom Alcans built 500# over with 2 1/2” lift were installed along with Caltracs. I utilized the SOS flip kit for shackle adjustment.
    Toyotoholic, Jego, Tundra-XP and 9 others like this.
  5. Oct 11, 2023 at 8:54 AM
    TreeCat
    TreeCat New Member
    2017 White Limited 4x4
    Looks great. I'm currently trying to gather all the wires, harnesses and extra stuff to install mine; it's a little overwhelming. How do you like the dash cams? Debating the Alpine ones vs other brands, integration vs price etc.
  6. Oct 11, 2023 at 10:29 AM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    Untested at this point. My Apple Watch is sitting at 27% at the moment, so I'll throw is on there on my drive home later today
  7. Oct 11, 2023 at 11:46 AM
    15SR5CM
    15SR5CM New Member
    Roseville, CA
    2015 SR5
    haha thanks for testing it! it would be nice to have that capability in my truck
  8. Oct 11, 2023 at 12:15 PM
    Pri
    Pri New Member
    Pri
    2014 Tundra 4x4
    Stock for now
    New to the Tundra crew- 2014 4x4
  9. Oct 11, 2023 at 12:48 PM
    S13ka24de
    S13ka24de New Member
    Wow nice what size rim n tires? Thx
  10. Oct 11, 2023 at 1:08 PM
    bobbilly
    bobbilly New Member
    Anyone ever have issues with the SP-9100 from switchpros? Mine occasionally will flash 3 times, which all sites point to a short, but then eventually comes back on and works fine. No rhyme or reason that I can find as to why. Sometimes on startup it just works, other times nothing.
    I've pulled it out and tried wiggling it around to see if any wires are lose but no luck.
  11. Oct 11, 2023 at 1:17 PM
    SAGE63
    San Diego County
    Welcome...
  12. Oct 11, 2023 at 1:28 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  13. Oct 11, 2023 at 2:57 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I have two circuits that will do that if the truck is running. If the engine is not running then they work fine. I keep meaning to call SP, but I'm never available to call them during work hours and actually troubleshoot it with them.
  14. Oct 11, 2023 at 3:04 PM
    coTony
    Tony
    Montrose, CO
    A
    Anyway to bypass that circuit with a new wire just to see if the problem disappears? Should not take much to disconnect the circuit(s) and bypass with a new cable or temp wiring with the correct gauge wire of course
  15. Oct 11, 2023 at 3:16 PM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2025 sequoia MGM TRD PRO
    Stock horse
    Went from stock 3rd brake light to morimoto…those bolts are a PITA!
    Nbab23, Tundra-XP, bulldog93 and 10 others like this.
  16. Oct 11, 2023 at 3:24 PM
    RobertD
    Robert
    DFW, Texas
    Did you have a cover on your stock 3rd brake light?
    The morimoto looks nice :thumbsup:
    RainMan_PNW likes this.
  17. Oct 11, 2023 at 3:34 PM
    War_Wagon312
    Rich
    Stock horse
    Yes sir it was an aluminum plate that bolted on the front of the stock light. Ty!
    RobertD[QUOTED] likes this.
  18. Oct 11, 2023 at 5:49 PM
    AZTundra
    Paul
    Phoenix, AZ
    The dash cams seem alright. After having them a couple weeks they don't seem to be as good as some other options in my opinion, but I do like the fact that they integrate with the head unit. I chose to wire them up using the hardwire method which was relatively easy when installing everything at once.
    Here is the link to the mounting bracket I used for the rear camera: https://www.thedashcamstore.com/custom-folded-bracket-for-secondary-dashcam-lenses/
    The cameras do have some nice features such as their phone app, ability to record while the truck is off, lane assist detection, etc. I think it's really a toss up. If you want the integration you can't go wrong otherwise for the price of the Alipine cam you could probably find a better quality unit elsewhere. Overall I'm happy with what it does.
    I think @RainMan_PNW still has his Thinkware U1000 front/rear cameras for sale. https://www.tundras.com/threads/thinkware-u1000-4k-dash-cam-w-2k-rear-camera-275-shipped.131474/
    TreeCat[QUOTED] likes this.
  19. Oct 11, 2023 at 5:59 PM
    BeachTundra19
    BeachTundra19 New Member
    Zak
    2019 Tundra Platinum "Silver Sky Metallic"
    None Yet
    How did you place this dashcam mount. I to ordered this one for the rear window but am having a hard time getting it to stay.
  20. Oct 11, 2023 at 6:03 PM
    BeachTundra19
    Zak
    None Yet
    Is that just black paint for the rims? It almost looks like a gunmetal in the picture.
  21. Oct 11, 2023 at 6:04 PM
    AZTundra
    Paul
    Phoenix, AZ
    This is the only other picture I have at the moment that shows the orientation. If I recall correctly, I just lowered the rear window and pulled the seal down then wedged the bracket in place. I do recall bending the angle of it with my hands just a little to ensure it was straight. Pressed the seal back into place and then raised the window back up. It's in there pretty snug and will not go anywhere. There is a tiny dip in the seal where the bracket is placed, but it's barely noticeable and doesn't interfere with anything. If you'd like me to pull the seal down and snap some more pictures I can do that tomorrow.
  22. Oct 11, 2023 at 6:10 PM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    Apple Watch was at 7% when I left work. 30 min drive home and it was at 97%
    Henry1jg and bulldog93 like this.
  23. Oct 11, 2023 at 6:12 PM
    BeachTundra19
    Zak
    None Yet
    I am going to have to see if I can get mine in the seal like that. Mine is above the headliner but it falls and then moves around after driving.
    AZTundra[QUOTED] likes this.
  24. Oct 11, 2023 at 6:16 PM
    AZTundra
    Paul
    Phoenix, AZ
    Sounds like it may not be sitting in the channel correctly or maybe you just need to bend it a tad ensure a tighter fit. Did you go with the 1" or 2" bracket? Wondering if the 2" may have a little less stability as the weight of the camera is further away from the channel leading to some vibration and causing it to move around.
  25. Oct 11, 2023 at 6:28 PM
    BeachTundra19
    Zak
    None Yet
    Absolutely. Its not sitting in the channel at all. Which is an install error on my part but I wanted to get it ASAP after. My truck is in the shop right now due to being hit and I regret not having the dashcam sooner as it would have saved me a lot of headache and back and forth. Once I get it back I'm going to try and get it in the seal like you have. I believe its the 2inch version.
  26. Oct 11, 2023 at 7:04 PM
    bobbilly
    bobbilly New Member
    That seems really odd. I wonder if the unit is just going out. Haven't pulled the console out but nothing seems to "trigger" the shortage.
    Just clarifying, running a new circuit off the Switch pro or just a new switch all together?
  27. Oct 11, 2023 at 7:04 PM
    RainMan_PNW
    Casey
    Clark County, WA
  28. Oct 11, 2023 at 7:08 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Yeah, i did some testing when I first installed and then haven’t gotten back to it since it’s working fine on a different circuit
  29. Oct 11, 2023 at 7:15 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    y’all tinker with your max current per circuit setting?
  30. Oct 11, 2023 at 7:39 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    I’m so pumped to tryout my first set of baja designs lights!
