  1. Oct 2, 2023 at 11:53 AM
    Wishbone Runner
    Wishbone Runner Toyota Connoisseur
    2019 Platinum
    OK, cool. Having run both as well, I don't think you are going to get away from the rebound behavior of a bump until you get to a hydro bump, just the nature of a rubber/foam bump, which you seem to have a good grasp on. Interested in your feedback, I blow up duro and supers every couple years on my 4runner, these are a cheaper alternative. Really I need a secondary shock . . .
    Vizsla[QUOTED] likes this.
  2. Oct 2, 2023 at 12:50 PM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    Ha ha, changed the oil for the 1st time on my recently purchased 2021 TRD Pro and I had ordered the MotiveX kit to deal with the oil filter cartridge mess, but I underestimated the force of the oil that would come out of the pan when I pulled the plug. I was using a super shallow drain pan so it just bounced off the bottom of the pan and drenched the right tire, wheel, hub and then the oil wicked back along the pan and dropped another 1/2 quart all over the floor when it came out the other side of the skid plate. What a mess!!! LOL Especially since my garage floor is bare wood planks.
    I've now ordered the fumoto drain plug, but I'll be using a bucket and something to block the oil from wicking back on the pan. I might even try the shop-vac trick to swap to the Fumoto before I drain the pan on the next oil change.
    I had the same plug on my STI and loved it, as that car was a gusher, too!
    Voda48 and bulldog93 like this.
  3. Oct 2, 2023 at 12:54 PM
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    You're right about a bucket - a 5 gallon bucket works better than a standard drain pan. And the MotivX kit is well worth the $$.
  4. Oct 2, 2023 at 1:17 PM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    Love Fumoto drain valve, it does drain slower so I do that first thing, slide the hose over the hose nipple and no mess...Did you also get the funnel that screws in to the oil fill tube?? I got that after I spilled about 1/2 qt of oil under the intake from the oil overflow from between the funnel and the fill tube.
    Smelled burning oil for weeks
  5. Oct 2, 2023 at 1:55 PM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    Yes, that is included in the MotivX kit. Definitely worth the money!
  6. Oct 2, 2023 at 2:50 PM
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    2018 Crewmax 1794 4x4
    Drove to Southern California and back this weekend. 73-78mph, got 15mpg. Saw gas in Palm Springs area for $6.27 YIKES. Love me some Arizona gas for $4.05. Such a comfortable truck. Most likely taking it next weekend back there again vs the Highlander.
  7. Oct 2, 2023 at 3:58 PM
    Cthulhu
    Looks good! Am I assuming correctly since yours is a 1794 that you lost RCTA and BSM when you installed that RC bumper? If so, is there now the orange triangle of doom on your dash, or can you simply turn off RCTA and BSM and you won’t get the triangle? I want an offroad bumper, but if that orange triangle pops up on my dash, it’ll drive my OCD nuts! :(
  8. Oct 2, 2023 at 5:20 PM
    Azblue
    The Dirty T ( ^_^)_且
    You have a wood garage floor? :confused:
    bulldog93 and Tripleconpanna like this.
  9. Oct 2, 2023 at 5:22 PM
    rockR67
    rockR67 New Member
    Northern Louisiana
    2018 Cement SR5 (sold)
    a few other things standing in ... for now.
    Agreed - this looks really good!
  10. Oct 2, 2023 at 6:23 PM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    Yeah yeah. I live in mountains on a hillside and previous owners built a large detached garage, 100% wood construction. Garage is ground level at entrance and about 30ft off the ground towards the rear. Entire floor is 2x6's and no moisture barrier anywhere. I don't actually park any cars in there cause I question the stability even though it was seriously overbuilt. Also, instead of one big ass garage door, it's two very narrow rollup doors that I can barely squeeze a truck through. So it's a big shop and has motorcycles, mountain bikes, and lots of tools.
    Wallygator likes this.
  11. Oct 2, 2023 at 6:44 PM
    Azblue
    That is one of the oddest things I've heard of. I agree, I don't think I'd park a few tons of vehicles in that either.
    Makes me think of some of the sketchy shit you see in Jerome AZ:
  12. Oct 2, 2023 at 7:26 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    In the 2018+ Instrument cluster settings, you can simply turn off BSM and RCTA. But if the CANBUS system doesn’t even see the radar units, it will automatically disable it.
    The parking sonar runs through it’s own ECU and dedicated switch. So long as you don’t accidentally turn on the switch, you’ll never see the errors show up if you remove the sensors. Or simply unplug the switch and put something else in the blank so you can’t accidentally turn it on.
  13. Oct 2, 2023 at 10:42 PM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    Yep lots of non permitted building happens up in the mountains. The area I live in was originally all vacation cabins for the rich folks of San Francisco in the 30's. Developed into a home community in the 40's. Very eclectic mix of homes as some did not survive the 1989 Loma Prieta Earthquake. Everything from original 700 sq ft homes to 6000 sq ft new homes from tear downs or rebuilds after the quake. Our house was built in 42.
    But I get to come home every day and live in the redwood forest and only 10 minutes from town. It's how I can afford to own a home in one of the most expensive places to live in the country. I also get to have an acre of land and an outdoor deck bigger than the foot print of the house. We love it here.
  14. Oct 3, 2023 at 8:58 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Beautiful day out, snapped some pictures while getting some work done around the property.
  15. Oct 3, 2023 at 11:40 AM
    Cthulhu
    Thank you so much Casey!!
    RainMan_PNW[QUOTED] likes this.
  16. Oct 3, 2023 at 12:10 PM
    Quicksand_Tundra
    Quicksand_Tundra New Member
    Jon
    2019 Quicksand Tundra CM 4x4
    -Color keyed grill & bumper -Diode Dynamic SAE LED Foglights -Headlight Revolution LED Light upgrade -SCS SR8 18x9 with 295/70/18 Toyo Open Country AT3 -Go Rhino Dominator D6 Steps -TRD OEM Intake & Dual exhaust -Bilstein 6112 front and 5160 in rear -JL Audio C2 6.5" speakers upgrade powered by JL Audio RD 400/4 amp -Pair of AudioFrog GS25 speakers front dash -10” Kicker Hideaway subwoofer under driver seat -All doors covered with Soundskins deadening mat (inside/outside) -Front window tinted at 35% -Paint protection film full front -30” Rigid Industries SAE light bar -Body Mount Chop -Diode Dynamics SS2 (red) setup for brake light & turn signal -Katzskin Custom leather upgrade (Black/Bamboo) -Amber led running lights (Hood bulge) -AJT Design: Black vent rings, steering wheel trim, shift gate trim, emblem overlay -AJT Design: Quicksand door handle cover -Carbon fiber wrap (silver part on door panel) -Air Design tailgate applique (Line-X in smooth gloss finish) -Air Design tailgate spoiler (Line-X in smooth gloss finish) -Smittybilt beaver step (Line-X) -Valhalla Cat Shield (Line-X) -Coachbuilder Shackles kit +2 -Coachbuilder Strut/Coilover shim (0.5" for driver side) -Sumosprings (rear bumpstop) -Meso Custom Led front and rear cab lights -Teton shop shift knob -TRD Seat belt shoulder pad -Husky floor liner front/back -LED courtesy door/step light -LED bed light kit w/ outside switch
    Decided to add some screen protection to the instrument cluster, radio screen, and shift trim. Fairly easy, give a few days for it to dry off, and it’ll clear up.
    I did end up with 2 small air bubbles to the far left, but you can’t really tell unless you shine a flashlight at it.
    Besides, I’m not gonna look at it while driving. I don’t like scratches on my cluster, and with this screen protector it keeps it looking new. You can clean and dust off the cluster and it won’t scratch the film.
    Due to the black shift trim, I was only able to apply the film covering the letter indicators. It would require taking out the outer trim to apply the film and I didn’t want to do that. It was a headache taking out the whole column in the first place.
  17. Oct 3, 2023 at 8:10 PM
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    Painted factory wheels. Huge change, low cost, and easy to do! Let's see if it is durable.:fingerscrossed:
  18. Oct 3, 2023 at 10:27 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Continued the process of relocating everything off of the bed rack onto somewhere else on the truck. Here are the chase lights. Luckily had an unoccupied run of 16awg going from under the hood up to the cab rack. Not the cleanest wiring but it’ll do56CC8ED0-1CEA-455C-982A-D74BFB47399E.jpgCAF3E923-A30D-43F6-9586-127BA237AF72.jpgF938ED8D-80BE-4197-81C2-2BD0414A1E7F.jpgAA7ACB68-16F6-4C25-85DA-9DCB5495004C.jpg
  19. Oct 4, 2023 at 12:03 PM
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    Morimoto Third Brake Light w/ Flash Module
    Halo 11
    Open to any tips or configuration suggestions with this headunit as I learn it if anyone has any.
    OFFROAM Phone Mount
    Purchased the Teton Design 3 Shift Knob months ago (trucks been in storage for 3 years while I was overseas working), installed it the other day and it got real hot with the truck being in the sun, anyone else have this issue?
  20. Oct 4, 2023 at 12:49 PM
    Skaufma0
    Skaufma0 Just a little stitious.
    Rock Hill, SC
    2018 MBM Limited CM
    IIRC that knob is anodized aluminum...which will obviously get hot in the sun. But it should dissipate the heat fairly quickly, too.
    Major[QUOTED] likes this.
  21. Oct 4, 2023 at 12:58 PM
    Reddawg1100
    Reddawg1100 New Member
    FL
    21 SR5 Midnight Black DC, AKA: Bat Truck
    Custom rims, front leveling spacers
    I like the contrast between the white paint and black wheels. What did you paint them with?
    Jego[QUOTED] likes this.
  22. Oct 4, 2023 at 6:29 PM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    Yeah, never been a fan of solid metal shift knobs for this reason. I'd suggest using a windshield shade
    bulldog93 likes this.
  23. Oct 4, 2023 at 7:30 PM
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    4 black matte Plasti Dip sprays, one per wheel.
    Reddawg1100[QUOTED] likes this.
  24. Oct 4, 2023 at 8:24 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Dave you have a link for these I’m curious and may try it.
  25. Oct 4, 2023 at 8:39 PM
    Vizsla
    Vizsla 2 = 2.5
  26. Oct 4, 2023 at 8:43 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
  27. Oct 4, 2023 at 9:33 PM
    Quicksand_Tundra
    Jon
    Just stoked to find a cap that almost matches my truck. Great color combination.
  28. Oct 5, 2023 at 4:56 AM
    Tundar the Barbarian
    Tundar the Barbarian New Member
    2020 MGM TRD OffRoad
    Speakers, amp, subs, floorboard lights...and the little step thing under the bumper
    PXL_20231005_113600132.jpg PXL_20231005_115256316.jpg Replaced the corroding battery hold-down. I'll clean the rest of under the hood to be just as swanky, this weekend...
  29. Oct 5, 2023 at 6:38 AM
    coTony
    Tony
    Montrose, CO
    Had to visit Chris and the boys at Bob Moses
  30. Oct 5, 2023 at 8:20 AM
    luxury4play
    luxury4play New Member
    Hey guys, switch back to a tundra and the oem USB port didn’t seem to charge my phone nearly as fast as my raptor would. So I went on a mission to figure out what I can do to change that.
    well I found a solution. Type C ports from a toyota sienna, had to modify the notches on the port to make it fit, but it fit and works like a charm.
