  1. Sep 21, 2023 at 1:20 PM
    Moe2o4
    Moe2o4 New Member
    Corey
    2020 Tundra SR5 Extended Cab TRD Offroad Package 8ft. Bed
    Bilsten 6112's with 2.5" Front Lift w/Bilstein 5160 Rear Shocks
    Voltage Booster Pro Test for all you guys who run AGM batteries out there. I'm running a Northstar 27F X2 Power! Saw someone post about this Voltage Booster Pro and thought I'd give it a try. I have been running the GM fuse for about a year now and every now and again my voltage will drop down between 13.8-13.9, that's the lowest I've see it go. One thing I do like about this Voltage Booster Pro is that it is still fused with the 5 amp fuse unlike the GM fuse so something does go wrong that fuse will pop!
    GM Fuse cold start: 14.41v
    Voltage Pro cold start low setting: 14.53v
    Voltage Pro cold start high setting: 15.00v
  2. Sep 21, 2023 at 2:04 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    probably a few guys in there that are looking to get rid of a stock non-JBL head unit (assuming his truck isn't JBL). If he goes to a 2020/2021 unit, with a little work and some adapter harnesses he would get CarPlay/Android Auto out of the mix.
    Tripleconpanna and bulldog93 like this.
  3. Sep 21, 2023 at 2:15 PM
    daveeasa
    David
    So there's no swapping thread on that? I didn't get a close enough look to see if he was JBL or not JBL. I did grab a photo though.
  4. Sep 21, 2023 at 2:18 PM
    bobbilly
    bobbilly New Member
    Looks like this model: https://phoenixautomotiveinc.com/collections/tundra
    This thread should have info how to install which would give you an idea of what will be needed to uninstall/switch to a different. You might be able to watch the for sale threads with all the head unit's being installed.
    https://www.tundras.com/threads/android-headunit.16037/
  5. Sep 21, 2023 at 2:18 PM
    You can put a 20/21 radio in his. You just need the harness from Autoharness. It is pricey though. If his is JBL, I believe he would have a JBL emblem on his door panels near the speakers.
    bulldog93 and daveeasa[QUOTED] like this.
  6. Sep 21, 2023 at 2:36 PM
    daveeasa
    David
    Thanks @bobbilly @RainMan_PNW and @Tundra234 for the info, super helpful, much appreciated. I figured someone could steer me in the right direction.
    I think I need to buy myself a 2.5 gen someday :)
    I assume this is the harness you're talking about, for an etune 3.0 in an vehicle that came with 2.0?
    RainMan_PNW and bulldog93 like this.
  7. Sep 21, 2023 at 3:24 PM
    SwitchThrottle
    SwitchThrottle Living in Idiocracy
    2021 Barcelona CrewMax
    Finally got around to the rear window switch relocation. Blanks will be seat heater switches eventually.
    SEM Black trim ultra matches well, but is soft so be careful if you go that route. Took 3 tries to get a finish I was happy with, then I went and dinged it.
    :censored:
    I'm gonna try to touch it up. I really don't want to wet sand it again.
  8. Sep 21, 2023 at 4:21 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    @Meso customs steering wheel control kit arrived today :D
    :welder::sawzall::thumbsup:
    Henry1jg, TundraTed, nhw544 and 8 others like this.
  9. Sep 21, 2023 at 5:00 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I missed the initial post about thus, but what exactly does this let you do?
  10. Sep 21, 2023 at 5:04 PM
    coTony
    Tony
    Montrose, CO
    Keeping an eye on the spare back there…
  11. Sep 21, 2023 at 5:05 PM
    coTony
    Tony
    Montrose, CO
    Look at the switch buttons labels then check out yours on your Tundra :cheers:
  12. Sep 21, 2023 at 5:25 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    How did you do that?
  13. Sep 21, 2023 at 5:27 PM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
  14. Sep 21, 2023 at 5:28 PM
    coTony
    Tony
    Montrose, CO
    Jeff is Da Man!!
  15. Sep 21, 2023 at 6:50 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
  16. Sep 21, 2023 at 7:18 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    Mine is arriving tomorrow! Still can’t understand why some engineer designed the factory switch that way. Glad to finally get it corrected!
  17. Sep 21, 2023 at 7:48 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Yikes
    He’s gonna need AC controls too.
    That gets complicated.
    bulldog93 likes this.
  18. Sep 21, 2023 at 7:49 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Yes
    That’s the harness
  19. Sep 21, 2023 at 7:49 PM
    Good catch on the AC controls :thumbsup:
  20. Sep 21, 2023 at 7:50 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Wait
    What?
  21. Sep 21, 2023 at 7:56 PM
  22. Sep 21, 2023 at 7:58 PM
    RobertD
    Robert
    DFW, Texas
    Casey's about to spend $50
    coTony, Tripleconpanna and bulldog93 like this.
  23. Sep 21, 2023 at 8:01 PM
    Yep...I think so. I think $50 is an awesome deal for that.
    coTony, bulldog93 and RobertD[QUOTED] like this.
  24. Sep 21, 2023 at 8:04 PM
    RobertD
    Robert
    DFW, Texas
    He probably already has all the other stuff.
  25. Sep 21, 2023 at 8:04 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Not yet
    I need to read the thread
    And I need to get a matching 5th wheel
  26. Sep 21, 2023 at 8:09 PM
    bulldog93
    Jeff
    Yeah, me too. All over this mod!
    Tundra234 and Tripleconpanna like this.
  27. Sep 21, 2023 at 8:15 PM
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
  28. Sep 21, 2023 at 8:57 PM
    Tripleconpanna
    The OE configuration (to me) was all jacked up; it wasn't natural. Up should mean volume up and down should mean volume down. I don't know how many times in my '21 Pro and my '19 4Runner I pushed up thinking 'volume' up; but instead would jump to the next track, etc. on my playlist :frusty:... in contrast, when I wanted to skip to the next track, I'd push right button and it would bump volume up by a click :smash:
    I know probably shouldn't be a huge deal, but it's been a huge peeve of mine :thumbsup:
  29. Sep 21, 2023 at 9:18 PM
    TrashcanBand
    TrashcanBand New Member
    CenTex
    Tundra
    This was in Leander on 29. Very, very serviceable breakfast tacos in the station too.
    RobertD likes this.
  30. Sep 21, 2023 at 10:04 PM
    daveeasa
    David
    This is where a swap with someone who actually wants this thing feels like the most reasonable path forward. Because buying an aftermarket head unit, maybe a maestro, and some OEM controls and some sort of dash kit or oem parts, yeah, seems like a good way to spend a few thousand dollars.
    Anyway, super helpful to know this isn't an OEM setup, I am too new to 2.5 gen to really know.
    RainMan_PNW[QUOTED] likes this.
