  1. Jul 2, 2023 at 12:02 PM
    TheMagicMan5280
    TheMagicMan5280 Member
    20’ Cement
    Got the new suspension in. Super smooth now.
  2. Jul 2, 2023 at 12:29 PM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    2019 Super White 1794 Edition Tundra CrewMax 4x4
    3/2" Readylift, TRD Dual Exhaust, TRD Sway Bar, Line-X Bedliner, ArmorFlex Tonneau, ESP 3 bin storage, Amp Power-Steps, Driver Side Grab Handle, Ronin Antenna, Window Tint, ClearBra. Coming Soon: 20" Method MR305NV. BF Goodrich KO2 275/60/20
    Thanks for checking and the info. That sucks! Sounds like I'll be calling one of those mobile wheel repair guys.
  3. Jul 2, 2023 at 12:50 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    I don't think it's that bad ... gives your truck a little character !
  4. Jul 2, 2023 at 1:00 PM
    biebs96
    PA
    looks great!
    Are those bumpershellz on the front? If so I’d recommend them for the rear as well.
    I was in the situation as you, color matched rear, chrome front caps. I went with all for corners.
    Really like how the all black bumpers look, maybe you will as well.
    RobertD and Ceezurin[QUOTED] like this.
  5. Jul 2, 2023 at 1:13 PM
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    2018 Crewmax 1794 4x4
    Yes they do. the as1 ? I asked to go past that, but not past the dots on the glass. This is TOO much and they'll be replacing it.
  6. Jul 2, 2023 at 3:25 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Dig the bronze badges to match the wheels! :thumbsup:
    Ceezurin[QUOTED] and bulldog93 like this.
  7. Jul 2, 2023 at 4:01 PM
    Eborseti22
    Eborseti22 New Member
    Evan
    2020 Toyota Tundra TRD Offroad
    Black exhaust tip. Just the tip….
  8. Jul 2, 2023 at 7:26 PM
    BlueRibbon4x4
    Geno
    Never gets old. :rofl:
    Eborseti22[QUOTED] likes this.
  9. Jul 2, 2023 at 7:32 PM
    BlueRibbon4x4
    Geno
    I needed a bbq brace for the bed. I wanted it to be removable, not overly complicated, and strong enough for off-road trips. I put it on the side with the jack mount to further offset the weight of the gas tank. Just a chunk of plywood and some strategically placed braces, a couple button head screws into rivet nuts in the bed, and a ratchet strap and we’re in business.
    (For the OCD guys, the brace for the propane is not centered on purpose to allow room for the regulator on the rear of the bbq)
  10. Jul 2, 2023 at 8:19 PM
    Slag_Dynamics
    Slag_Dynamics Cut. Weld. Repeat.
    Arizona
    Gone
    Bummer man. I’d be upset as well, but I’m sure if you fill those gouges in with some matte black paint you'll forget about it soon.
    Or… could be a solid excuse for a full size spare..:monocle:
    Henry1jg likes this.
  11. Jul 2, 2023 at 9:25 PM
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    Reached a milestone sort of today. Truck is 3 years old this week. 25000 KM. Low because I'm retired and I was sick in there as well.
  12. Jul 2, 2023 at 9:31 PM
    GCanuck
    Gary
    BC,Canada
    Some of them use different frequencies.
  13. Jul 2, 2023 at 9:37 PM
    GCanuck
    Gary
    BC,Canada
    Got the same setup for peace of mind!
  14. Jul 3, 2023 at 3:54 AM
    DiamondW
    DiamondW Stockblocker
    Kent
    CenTex
    ‘17 CM
    Thanks, I did.
  15. Jul 3, 2023 at 7:26 AM
    stevesgraytundra
    stevesgraytundra New Member
    Stephen
    2021 MGM SR5 CM 4x4
    First oil change with High Performance Lubricants Premium Plus PCMO 5w-30. Tundra tick is greatly reduced (similar to Valvoline EP 5w-30). PAO and ester base with a massive dose of moly. Sounds good to me!
    bulldog93 and Mike59 like this.
  16. Jul 3, 2023 at 7:49 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Put on some AVS window visors last week. Need to redo the FP because it's catching on the corner as I roll up the window.
    Just ordered the remote tailgate lock. I'm ready for the convenience of locking the tailgate.
    Vr0ck and bulldog93 like this.
  17. Jul 3, 2023 at 11:29 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Better go back and read those BST rules :evil:
    bulldog93 and RobertD like this.
  18. Jul 3, 2023 at 11:38 AM
    coTony
    Tony
    Montrose, CO
    Got me last week for same thing, even after I read it... DUH
  19. Jul 3, 2023 at 1:19 PM
    Cthulhu
    Couple of minor projects. Got tired of nighshading my 3rd brake light lens every few months, too lazy to pull down the headliner and replace the whole housing, and skeered something might leak putting it all back together. So, I bought a replacement gasket since the old one was getting flat from removing the lens every so often, and bought just the smoked lens from klearz. Yeah it’s just as or more expensive than a whole LED housing, but with my VLEDs in there, looks pretty good day and night, bright.
    Wanted the top crossmember “easy” bar from RCI (you get it with the cat shields, Talon’s also sells them separately) to stay in place when I need to remove the engine and trans skids for service. I didn’t want anything permanent like a tack weld or drilling a hole for a bolt/nut combo, so, since I imagine it gets hot up in there with everything bolted up, I used some heat tape. I also wanted a little extra security, so, I bought four stainless security bolts, all M8x100mm, and two stainless M8 locknuts: the front two bolts screw right up into the “easy” bar nut clip RCI provides, and the rear two bolts screw into the two M8 locknuts. Tad bit more peace of mind.
  20. Jul 3, 2023 at 1:54 PM
    Nothing like projects on your birthday lol. Mine is next week.....yee haa! Going backwards in age is fun lol.
  21. Jul 3, 2023 at 8:42 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Done with the bed liner. Now to cut the truck up.
    Rc23, Henry1jg, mgm16trdpro and 10 others like this.
  22. Jul 3, 2023 at 8:57 PM
    roughfisher
    roughfisher Aggressive hockey is back in town!
    JP
    Northern Minnesota
    2021 MBM CM SR5 TRD OR 4x4
    genius! I'll have to take my engine skid plate off while I do some work underneath but was planning on keeping my tranny/cat guard on. This will help the engine skid plate reinstall go alot easier without having to drop the whole tranny plate and start from scratch.
    Cthulhu[QUOTED] likes this.
  23. Jul 3, 2023 at 10:21 PM
    Ragnarkov
    Ragnarkov New Member
    Stephen
    2021 Silver Sky Metalic Platinum Tundra
    Nothing.... yet.
    Installed some timbrens to help with hauling water on a weekly basis...
  24. Jul 4, 2023 at 6:08 AM
    Tundra Dude 45
    Tundra Dude 45 New Member
    Eric
    2019 SR 4.6L DC 4X4
    8” BAMuffler, TRD airflow accelerator, front window tint/windshield sun stripe, debadged tailgate 4x4 emblem, trimmed mud flaps, antenna removed stainless screw added, TRD rear sway bar, AFE high flow air filter.
    New rear shocks! Rides great! I put new 6112 assemblies in the front a few months ago.
  25. Jul 4, 2023 at 7:58 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Let’s get to the get down! Can’t wait to see it.
    CaptRussia253[QUOTED] likes this.
  26. Jul 4, 2023 at 8:56 AM
    Slag_Dynamics
    Arizona
    Gone
    Love the look of those bumpers.
    Maybe on my next truck!
  27. Jul 4, 2023 at 9:07 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Heat shrink those clamps. Cleans the look up and protects the resi
  28. Jul 4, 2023 at 9:10 AM
    Jcmf52
    Jcmf52 New Member
    Rob
    2018-1794 S/C
    Shorty antenna Trifold hard top tonneau cover Center console safe Center console tray Rhino liner TRD air filter TRD rear sway bar TRD front sway bar Center console wireless charger kit Remote start Black 4x4 emblem swap
    Finally able to format and program my Rough Country speedometer calibrator and installed this morning. Nice to have speedometer accurate again
  29. Jul 4, 2023 at 9:12 AM
    coTony
    Tony
    Montrose, CO
    Thanks for the reminder, I need to adjust mine while I have things apart
    Jcmf52[QUOTED] likes this.
  30. Jul 4, 2023 at 9:13 AM
    Slag_Dynamics
    Arizona
    Gone
    How far off were your trucks?
    Tundrastruck91 likes this.
