  1. Jun 13, 2023 at 12:05 PM
    catus
    catus New Member
    Centennial, CO
    '19 MGM DC Limited, stock for now
    Added tie down rings to the bed rails. Three on the sides, and two behind the cab. Now I can get rid of those clunky Toyota ones.
    rdiddy5, WVI, Tundra-XP and 10 others like this.
  2. Jun 13, 2023 at 2:41 PM
    the red
    the red the threat is real
    New Brunswick, Canada
    Finally no more exhaust leak! And the bill was less than anticipated.
    :yes:
    On another note, something didn't feel right. After trying to figure it out I eventually smelled brakes. I checked the rear wheels and they were hot. I had them adjust the parking brake as I'd adjusted it at every point and it still wasn't holding. Apparently he had to get it so tight it was actually slightly engaged. :notsure:
    After the alignment I'm now getting a slight rub at full right lock on my skid plate. Time to trim.
    As for the vibration, they're unsure. They thought maybe the tires, but it was there before the tires. I'm pretty sensitive to it and it may be nothing of concern. However, I'm going to check my carrier bearing. Could be a slight imbalance in the driveshaft too, but that's likely harder to diagnose. Could be a lot of things.
    WVI likes this.
  3. Jun 13, 2023 at 5:57 PM
    ChrisLopez
    ChrisLopez New Member
    Christian
    Chicago,Illinois
    2018 Tundra SR5 TRD off road Crew max
    Finally pulled the trigger on one of these. I couldn’t see myself pay over $200 for what it is. Found it for for $70 and couldn’t be happier. Box feels solid, bracket is different from the swing case but all the bolt holes land on flat area of bed. For what I’ll use it for I’m happy with it. Only down side is you loose that tie down hook. I cut the bracket to be able to fit around the hook but the case doesn’t it clear it when closed. Oh well. Also I have drop in liner and had to do some trimming to make fit. Hopefully linex soon. Got quoted $650 out the door here local in chicago.
    https://www.ebay.com/itm/2560165604...ssdVIeBTHi&var=&widget_ver=artemis&media=COPY
    WVI, Moreblacktss, Tundra-XP and 6 others like this.
  4. Jun 13, 2023 at 6:40 PM
    drpheta
    drpheta New Member
    Super White 2014 TRD Off-Road DC
    Took off the TRD decals, cause the edges had trapped dirt.
  5. Jun 13, 2023 at 6:58 PM
    2-4-5 trioxin
    2-4-5 trioxin New Member
    2020 Tundra Limited
    Put on the Rci engine skid plate. Way better coverage than the stock one.
    WVI, Tundrastruck91, the red and 2 others like this.
  6. Jun 13, 2023 at 7:01 PM
    dofu
    dofu New Member
    Dave
    San Jose, CA
    2015 White Tundra Crewmax SR5
    I finally switched out my halogen headlights with these new OE TRD style Bi-LED head lights (black). Blacked out my badges and got A/T tires. Any suggestions on my next upgrade? I’m thinking about deleting my chrome next.IMG_2906.jpg
  7. Jun 13, 2023 at 7:08 PM
    ohiowa
    ohiowa Have you tried turning it off and back on again?
    Ohio
    2021 SR5 CM Cavalry Blue
    Finally ordered a mount from Bulletpoint Designs for my Furrion RV monitor. Using a Tackform vent mount for it.
    I'm just not committed to the number of devices I'd need to justify a Rago mount. Might someday be handy if I could mount my Talkabout T605 for road trips. Maybe.
    WVI and bulldog93 like this.
  8. Jun 13, 2023 at 7:18 PM
    dofu
    dofu New Member
    Dave
    San Jose, CA
    So smart! Always good to be prepared for the unexpected.
  9. Jun 13, 2023 at 7:20 PM
    dofu
    dofu New Member
    Dave
    San Jose, CA
    where did you find these? Do you have the part #s? I hate the clunky stock ones!
    WVI, TreeCat and catus[QUOTED] like this.
  10. Jun 13, 2023 at 7:33 PM
    drpheta
    drpheta New Member
    Damn. I wish I had known this before buying a set online. Might have been able to save some coin, depending on your asking price.
  11. Jun 13, 2023 at 8:21 PM
    catus
    catus New Member
    Centennial, CO
  12. Jun 13, 2023 at 8:33 PM
    TRD_Ghost
    TRD_Ghost New Member
    17 Superwhite TRD Pro
    I see you have the black steering wheel buttons. Mine are grey and control volume, not phone though. I need that black control button.
  13. Jun 13, 2023 at 11:35 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Looks good ! Now get some led fog lights :)
    dofu[QUOTED] likes this.
  14. Jun 14, 2023 at 4:00 AM
    Picked up a chip on the way to work that cracked on both sides. :mad: I'll have to go to Safelite to make sure they will change it even though insurance pays for it.
  15. Jun 14, 2023 at 6:31 AM
    LabRat
    LabRat New Member
    Houston TX
    '14 Tunda
    All
    Nice looking headlights! I'd continue on the chrome delete path if thats what your aiming for.
  16. Jun 14, 2023 at 8:00 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    You could fix it while it’s still small
  17. Jun 14, 2023 at 8:21 AM
    They won't fix that in FL. Its 3/4 long and in the line of site. Fl insurance is a 0 deductible.
    bulldog93 likes this.
  18. Jun 14, 2023 at 8:54 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Florida state insurance or specific to your insurance company?
  19. Jun 14, 2023 at 9:14 AM
    I believe my insurance said it falls under FL state law. I would have to look.
    Jaypown[QUOTED] likes this.
  20. Jun 14, 2023 at 9:52 AM
    Tundar the Barbarian
    Tundar the Barbarian New Member
    2020 MGM TRD OffRoad
    Speakers, amp, subs, floorboard lights...and the little step thing under the bumper
    Rock cracked mine (starburst) this morning, insurance asked if bigger than a quarter? It is, they said they'll replace it, zero deductible. If smaller than a quarter, they said they could fix, it'd still be visible, but wouldn't spread.
    So, I'm good on replace...still, grrrr.
  21. Jun 14, 2023 at 10:08 AM
    Yeah I hear ya. I was mad as hell. I don't see how they would fix mine. I did the live chat with Safelite. He said if it's in my line of site even though it's smaller than 6 inches that they would replace it.
  22. Jun 14, 2023 at 10:12 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I have a small chip smaller than a dime in mine. Middle of the windshield. It hasnt spread in 2 years so I haven't messed with it. I know Safelite will come in and just fill it and seal it if I make a claim.
    I'm not sure if Ohio has any law about it. I always just knew that cracks were illegal to have. But a crack can be a vague statement.
  23. Jun 14, 2023 at 10:43 AM
    It sucks either way. Mine cracked from both sides of the chip.
  24. Jun 14, 2023 at 11:59 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Yeah that sucks.
  25. Jun 14, 2023 at 12:08 PM
    Getting replaced on Saturday
    WVI likes this.
  26. Jun 14, 2023 at 1:57 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Nice!
  27. Jun 14, 2023 at 2:43 PM
    TreeCat
    TreeCat New Member
    2017 White Limited 4x4
    Got it registered and title swapped. It's official for the streets now.
  28. Jun 14, 2023 at 4:11 PM
    the red
    Just part of driving. Still frustrating though. My last vehicle got a crack and I was happy to replace it because the pitting was crazy bad anyways, far worse for safety than any crack.
  29. Jun 14, 2023 at 4:51 PM
    16MagSR5
    16MagSR5 New Member
    Buffalo
    2016 Magnetic SR5, leveled and capped
    Boost tow Mirrors, TRD rear sway, Rough Country Duals, Bilstein 5100's, diff breather mod, more that I'm forgetting...
    Bought these back in May. Tundra rims don't come up for sale often here. I was as patient as could be. More prep than I initially anticipated.
    After prep and paint underway
    Wetsanded the flats. Didn't have the patience to do the whole thing.
    Final product. Tires getting swapped and mounted tomorrow
  30. Jun 14, 2023 at 4:52 PM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    2017 SR5 5.7 4x4 quicksand dbl cab
    Looks good, I plan on doing the same to mine. Spray can?
    PomDad likes this.
