  1. May 16, 2023 at 12:15 PM
    Factory brakes at 70k miles with occasional heavy towing.
    rdiddy5, coldcanuk, WFD473 and 8 others like this.
  2. May 16, 2023 at 12:20 PM
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    I found this in my wife's tire couple weeks ago. We had to replace to replace the tire.
    Blowdart, WVI, Mater and 4 others like this.
  3. May 16, 2023 at 12:24 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Well hello there huge metal rod penetration
    bulldog93, RobertD, Cthulhu and 3 others like this.
  4. May 16, 2023 at 2:48 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Huge rod penetration - hear that a lot
    AggiePhil and bulldog93 like this.
  5. May 16, 2023 at 3:35 PM
    FirstTruck
    FirstTruck New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
    IMG_5014.jpg IMG_5146.jpg Front brake work? ✅
    Nightshade1970, rdiddy5, WVI and 15 others like this.
  6. May 16, 2023 at 3:43 PM
    Screws suck....
  7. May 16, 2023 at 3:46 PM
    :101010:
    FirstTruck[QUOTED] likes this.
  8. May 16, 2023 at 4:59 PM
    SK_MACHINE
    SK_MACHINE New Member
    Wompy
    CA
    2021 DC TRD 4WD
    Scratches on paint, coffee stain on seat, nail in tire, dog saliva on rear windows
    Took my '21 DC to Bajarex Motorsports in Orange CA to install my:
    6112/5160 Billies
    JBA uca's
    Wheelers Bumpstops
    Proform Fab shackles
  9. May 16, 2023 at 5:10 PM
    kaymonster
    kaymonster Member
    San Diego
    2018 Platinum
    Thanks, I'm very happy. Bought the paint from automotivetouchup.com. Also used their SprayMax 2K Urethane Clearcoat, that stuff is legit. I first hit it with plastic adhesion promoter, then 4 coats paint and 3 coats clear coat.
    bulldog93 and welshmike like this.
  10. May 16, 2023 at 6:34 PM
    Azblue
    The Dirty T ( ^_^)_且
  11. May 16, 2023 at 6:58 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    CERT training tonight...
    rdiddy5, WVI, Rgross2112 and 4 others like this.
  12. May 16, 2023 at 7:30 PM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    Put on the TRD shifter, the boot is still in transit, but I’ll post a pic when it arrives.
    occruiser, WVI, Henry1jg and 3 others like this.
  13. May 16, 2023 at 7:31 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Thought I was going crazy seeing 220 degrees there!
  14. May 16, 2023 at 9:01 PM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    OHwendTrd, WVI, Rgross2112 and 5 others like this.
  15. May 16, 2023 at 9:06 PM
    Bgriff1974
    Bgriff1974 New Member
    2021 Black Tundra TSS
    Looking to find best ones
    Just curious which gen is 2021? Thanks in advance
  16. May 16, 2023 at 9:10 PM
    French Avocado
    Utah / Wyo
    2.5 gen
    bulldog93 likes this.
  17. May 17, 2023 at 3:45 AM
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    What is the difference between that and the pedal commander?
  18. May 17, 2023 at 4:09 AM
    The PM has reverse gear sensing (unless you are running it in "No OBD" mode like I am), and it also has ActiveSafety which returns to stock pedal in the event of a failure. The Pedal Commander will leave you with a dead pedal if it fails.
    Ginsterkev, Blowdart, WVI and 4 others like this.
  19. May 17, 2023 at 5:27 AM
    The Banks pedal monster also has a dedicated 12v power source. Something the Other guys don’t. Biggest fail point is the PC relying on the 5v power source available at the factory pedal connection.
    Blowdart, Bergy24, bulldog93 and 3 others like this.
  20. May 17, 2023 at 6:21 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    You’ve come to the right place. Welcome, friend.
    cartage1 and OHwendTrd like this.
  21. May 17, 2023 at 6:35 AM
    TundraRV
    TundraRV New Member
    2021 SR5 SX Double Cab
    Warm weather here, plan on starting to use the truck again for some fun adventures after it sat all winter.
    Doing everything in my power not to modify it. Just rolled 8,500miles on it in 3 years of ownership.
    Terndrerrr, Mike59 and RobertD like this.
  22. May 17, 2023 at 6:42 AM
    French Avocado
    Utah / Wyo
    No mods???? Why have a truck?
    Beesta and wiltech like this.
  23. May 17, 2023 at 7:32 AM
    Bergy24
    Bergy24 New Member
    Was it easy to install? Noticeable difference from stock?
  24. May 17, 2023 at 7:53 AM
    Yes it is 2 connectors at the pedal and one at the OBD port. I have had the Pedal Commander since 2018 and switched to the Banks. They are definitely more noticeable over stock.
    the red likes this.
  25. May 17, 2023 at 8:09 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Hesitant to switch to anything that is plugged into the OBD port as my radio is using it for monitoring through the screen. I enjoy that feature.
  26. May 17, 2023 at 8:20 AM
    You can run the PM and your radio using the splitter. You just run the PM in "NO OBD" mode. I run the PM and my ScanGauge 3 off of the OBD port. Now on my truck, my monitoring on the Pioneer doesn't use the OBD. It goes through the black data cable that came with the Maestro. Yours may be different since it's a 2016.
    rdiddy5, bulldog93 and the red like this.
  27. May 17, 2023 at 9:03 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Definitely different since it's a 2016 haha.
  28. May 17, 2023 at 9:24 AM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    Added some decals from Drew’s decals to my front and rear husky floor mats. Really nice quality.
    AggiePhil, Beesta, nhw544 and 15 others like this.
  29. May 17, 2023 at 9:44 AM
    Demented Canine
    Demented Canine Hiding in the Baffles
    Extreme Southeast Georgia
    2020 MGM SR5 DC
    Gave him a Bath and some light Detailing...
  30. May 17, 2023 at 9:53 AM
    justcuz
    justcuz 2.5 Gen Member
    Sanded, washed and degreased the running boards. Going to respray them later when they dry. IMG_2124.jpg
    bulldog93, WFD473, WVI and 5 others like this.
