  1. May 5, 2023 at 11:27 AM
    the red
    the red the threat is real
    New Brunswick, Canada
    Thanks guys. I wasn't sure as I had no reference point.
    I measured my truck from centre of wheel to fender on all four corners and...well...interesting results.
    :monocle:
    I'm on pretty flat ground, but my driveway is still crushed stone with a slight incline. But just shy of a half inch difference left to right both front and rear with opposing sides being higher? I'll try measuring it on the four post lift when I can.
  2. May 5, 2023 at 12:23 PM
    JediMedic86
    JediMedic86 New Member
    Cole
    2021 Cavalry Blue Tundra SR5
    Rough Country rear bumper, AJT interior products, TufSkinz interior products, BakFlip bed cover, BedRug full bed liner, Rough Country 2” strut leveling kit with rear N3 shocks.
    Nice! What brand is that bumper? I could fit 35x12.5 with that bumper.
  3. May 5, 2023 at 1:59 PM
    nhw544
    nhw544 Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    IMG_1917.jpg Gave her a bath and painted the tow hooks red. Love the way they pop against the black now.
    Nbab23, GAknight, Sean492 and 9 others like this.
  4. May 5, 2023 at 2:03 PM
    +15 grip
  5. May 5, 2023 at 2:08 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Doesn't look too bad for the miles. The half inch difference side to side is pretty typical of tundras. You would definitely notice a slight lift from new stock suspension for sure but your not that far off.
    the red[QUOTED] likes this.
  6. May 5, 2023 at 2:50 PM
    the red
    Good to know. There are nearly 300k km's on this truck and it looked like the original shocks on the rear. So far I've only done 5100s on the rear. Planning on doing 6112s on the front later this year. Just might need them to mount the new rubber. We'll find out in a few weeks. Planning on absolute minimum lift with 285/75R18s.
    MadMaxCanon[QUOTED] and KNABORES like this.
  7. May 5, 2023 at 3:28 PM
    Did you mount your fridge slide using rivnuts or just standard bolts and nuts? The issue that I am trying to figure out before I order the slide is the mounting location....I have 2 swingcases installed. I don't know if mounting it in the center of the bed towards the front would work or not as far as sliding it back. I could set the fridge in the bed and see how far back I would have to go for the swing cases to clear. Also from what I cat tell, the fridge sits just below the bed cap when its on the slide?
    rdiddy5 likes this.
  8. May 5, 2023 at 7:20 PM
    SAGE63
    San Diego County
    I used the bolts that came with the Slide from ICECO. yes about 1" below the retrax bed cover
    WVI likes this.
  9. May 5, 2023 at 7:26 PM
    Florida AF
    Logan
    North Florida
    installed:
    1) carabc
    2) interior chrome delete
    3) LED dome map
    4) Driver grab handle
    5) new antenna gasket thing
    rdiddy5, nhw544, WVI and 2 others like this.
  10. May 5, 2023 at 7:26 PM
    Thanks. I'll do some measurements and pics tomorrow on where it would sit with the swing cases. I'll have the Badland ORJ mount going in soon as well.
  11. May 5, 2023 at 7:31 PM
    Florida AF
    Logan
    North Florida
    I will be curious on what you find out. My swing cases open and hit eachother, so I cannot fix anything in the bed, or at least I havent found a way.
    Tundra234[QUOTED] likes this.
  12. May 5, 2023 at 8:16 PM
    fuzzamungus
    fuzzamungus New Member
    18 Tundra Limited
    You may want to check out Roadactive suspension, you can dial them in and get it level and give your leafs a boost.
  13. May 5, 2023 at 10:26 PM
    Jcmf52
    Jcmf52 New Member
    Rob
    2018-1794 S/C
    Shorty antenna Trifold hard top tonneau cover Center console safe Center console tray Rhino liner TRD air filter TRD rear sway bar TRD front sway bar Center console wireless charger kit Remote start Black 4x4 emblem swap
    You can but not necessary.
    Cant steal the adjustable part when locked to the hitch. They could steal pins I guess.
    Used it to drive Troop trailer to campground tonight and glad I had it. Ended up having to flip the hitch to a rise position on the trailer. My other trailer is usually in a drop 2” setup.
    Was real easy to switch setup and adjust as needed. Highly recommend!
    the red and Mike59 like this.
  14. May 6, 2023 at 2:33 AM
    the red
    Roadmaster? Yes, it's on my list. Should help out a lot too, especially when I get a trailer at some point.
  15. May 6, 2023 at 2:54 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    GAknight, Jaypown, rdiddy5 and 6 others like this.
  16. May 6, 2023 at 5:07 PM
    SPOirish28
    SPOirish28 New Member
    Ontario, Canada
    2014 SSM SR5 DC
    Satin black roof, 18” KO2’s, satin black powder coated steel rims, tri fold tonneau cover. Led lights interior, exterior. Trd pro grill. 13” ryonnair antenna. OEM LED headlights.
    foggy morning this week
  17. May 6, 2023 at 5:43 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Took her out for some speed runs to test the Badland jack mount. Thing didn’t budge! Got some pretty shots at the same time.
  18. May 6, 2023 at 5:50 PM
    Whole EnchiTUNDRA
    Whole EnchiTUNDRA New Member
    2015 SR5 Crew Max
    Cleaned up some wiring and put plastic wiring loom over it. Installed waterproof connections on light bar and fogs then put in a light bar switch that fits the dash. Had to put new edging on a fender flare. The original disappeared in a mesquite thicket. Had enough to cover all four but that’s have to job, as in “Don’t do until you have to”
  19. May 6, 2023 at 6:05 PM
    My mount will be here Wednesday. I started putting the jack together. That thing is a beast.
    BlueRibbon4x4[QUOTED] likes this.
  20. May 6, 2023 at 6:07 PM
    BlueRibbon4x4
    Geno
    Awesome. I’ve used it twice already. Lifting the truck is no longer a chore. Worth every penny. Don’t forget to bleed it!
    GAknight and RobertD like this.
  21. May 6, 2023 at 6:12 PM
    Will do. Yeah using the Craftman with steel wheels, noisy as hell, and having to add blocks just for the height was rediculous. Now I'll actually be able to have a usable jack in the truck. I got mine for $240 out the door.
  22. May 6, 2023 at 6:17 PM
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    C4 Overland bumper, BD SAE fogs, Leitner Designs Rack, Rago Bed Channel Stiffiners, Warn Xeon 12S Plarinum, Bedslide, Front Runner Roof Rack, roof rack solar panels, RCI Full under carriage aluminum studs, RCI rear diff skid, Rago dash plate, Rago accessory panels, OEM LED headlights with wiring harness.
    You prefer it over a hilift?
  23. May 6, 2023 at 6:19 PM
    BlueRibbon4x4
    Geno
    Agreed. 25% killer coupon!
  24. May 6, 2023 at 6:22 PM
    Yep. Coworker gave it to me. With mounting that and a fridge slide, I'm thinking about doing it with rivnuts. Easy removal for bed cleaning or if I need the hauling space. I was just looking at the kits on Amazon.
  25. May 6, 2023 at 6:25 PM
    BlueRibbon4x4
    Geno
    GAknight, Henry1jg, the red and 3 others like this.
  26. May 6, 2023 at 6:28 PM
    Nice. Any specific kit that you would recommend?
  27. May 6, 2023 at 6:32 PM
    BlueRibbon4x4
    Geno
    I bought this, as I never had a Rivnut kit. This is super easy to use, small enough to use in the engine bay and the fender wells. I’ve never had a problem with it. Comes with a bunch of rivnuts too, don’t forget to order the SS bolts too.
    REXBETI 14" Rivet Nut Tool
    Well that link is broken..
    bulldog93 and RobertD like this.
  28. May 6, 2023 at 6:46 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Joined the Dirty Sevens club.
    Wallygator, Nbab23, Jaypown and 18 others like this.
  29. May 6, 2023 at 6:48 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM
    Tomorrow is 2 years since I got the truck, also marks the end of Toyota Care so I had the 20k service done. Rolled in the shop with 14,936 miles
    also had them install the metal oil filter housing.
  30. May 6, 2023 at 6:49 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Better use crossnuts.
