  1. Apr 27, 2023 at 12:23 PM
    JediMedic86
    JediMedic86 New Member
    Cole
    2022 black 4Runner SR5
    Previous Tundra owner turned 4Runner owner.
    What’s the offset on these?
    the red[QUOTED] likes this.
  2. Apr 27, 2023 at 12:26 PM
    SwitchThrottle
    SwitchThrottle Living in Idiocracy
    2021 Barcelona CrewMax
    Tony_h, mgm16trdpro, PomDad and 2 others like this.
  3. Apr 27, 2023 at 12:26 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Kinda look like some blacked out Alcoas
  4. Apr 27, 2023 at 12:31 PM
    Retired Blue
    Retired Blue New Member
    Steven
    Round Rock, TX
    2020 Super White Platinum
    Ahhhh, I see, the cutout for the latch mechanism. That's a tight fit for my ham-hocks. Headed for the bedroom now to retrieve our tub of Crisco. o_O
    My, what long arms you must have. :rofl:
    the red and texasrho83[QUOTED] like this.
  5. Apr 27, 2023 at 12:33 PM
    the red
    the red the threat is real
    New Brunswick, Canada
    For sure!
    +40
    JediMedic86[QUOTED] likes this.
  6. Apr 27, 2023 at 1:01 PM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    No rain today. 60 and sunny. No wind. Perfect working on stuff weather.
    Seat heaters were here when I got home.
    I really wanted to play with my truck, but I have to cut the stupid grass.
  7. Apr 27, 2023 at 3:09 PM
    GatorBodine
    GatorBodine New Member
    I think I want those wheels for my AG Tundra. I'm still working on de-chroming.
    Terndrerrr[QUOTED] likes this.
  8. Apr 27, 2023 at 3:18 PM
    GatorBodine
    How do I get one of those boots for the shifter!?
  9. Apr 27, 2023 at 3:47 PM
    Retired Blue
    Steven
    Round Rock, TX
  10. Apr 27, 2023 at 4:13 PM
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    Do you have a build thread somewhere? Are those 12s? Seats going back in/any modification needed? The headliner setup is wild. What made you go with SKAR over other brand subs? Is that a T12V sub enclosure? Sorry for the overload of questions. TIA.
  11. Apr 27, 2023 at 4:14 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Before and after. Hood bulge was looking a little tired. Sanded down the bedliner and sprayed with Rustoleum Professional Black and matte clear.
    GAknight, Beckusmc, Cthulhu and 12 others like this.
  12. Apr 27, 2023 at 4:36 PM
    SwitchThrottle
    Why no color match?
    RobertD likes this.
  13. Apr 27, 2023 at 4:37 PM
    BlueRibbon4x4
    Geno
    Everything else is color matched! I like the black front end.
    GAknight, chugs, Old.Ski.Bum and 14 others like this.
  14. Apr 27, 2023 at 8:04 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    You get any rattles?
  15. Apr 28, 2023 at 5:30 AM
    dkahs05
    dkahs05 New Member
    2020 Tundra TRD PRO
    What head unit is this?
  16. Apr 28, 2023 at 7:07 AM
    ohiowa
    ohiowa Have you tried turning it off and back on again?
    Ohio
    2021 SR5 CM Cavalry Blue
    Installed and EQ'd for like three hours:
    Sony XAV-9500ES
    Kicker 43CWR84
    Kicker 46CXA800.1
    SuperCrew Sound enclosure
    Factory speakers/tweeters/center channel
    Yep, technically the amp is way overkill for the sub, but I wanted upgradeability. While I like the "little" 8" sub, I didn't want to assume I'd always like it and never wanted something bigger/more powerful.
    Sounds terrific.
    bulldog93 likes this.
  17. Apr 28, 2023 at 9:12 AM
    nikatnite79
    nikatnite79 New Member
    David
    2016 Tundra Limited
    None
  18. Apr 28, 2023 at 11:19 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Looks good... Hey, did you run 'red' or 'dark red' for the stitching color on your boot??
  19. Apr 28, 2023 at 11:34 AM
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
  20. Apr 28, 2023 at 11:35 AM
    Retired Blue
    Steven
    Round Rock, TX
    Thank you! Good question! My email order confirmation says "Red." Still, I just went and looked again here... https://www.redlinegoods.com/clrchart.php (thread colors are near the bottom of the page). I'm pretty sure, I ordered 'red.'
  21. Apr 28, 2023 at 11:41 AM
    Retired Blue
    Steven
    Round Rock, TX
    Unscrew the shift knob. Turn the boot inside-out. Slip it over the knob from the bottom, and position where you want it. I used a 6" zip tie, pulled really tight abound the inside of the boot and the bottom of the knob. Turn the boot back outside-out. If it's not where you want it on the knob, cut the zip tie off and try again.
  22. Apr 28, 2023 at 11:59 AM
    Bergy24
    Bergy24 New Member
    Do you think this would work if I have a Teton Workshop shift knob?
  23. Apr 28, 2023 at 12:13 PM
    Retired Blue
    Steven
    Round Rock, TX
    Yes. The zip tie will likely need to be tied around the shift knob about where the bottom screw is on the knob. I think Amazon also has boot adapters, that you can attach to the shaft before screwing the knob back on, but factory Toyota knobs are too long for such. If you've a shorter Teton, such an adapter could work for you. If you've a longer Teton, plan on securing the boot around the knob where that bottom screw is.
    bulldog93 and Bergy24[QUOTED] like this.
  24. Apr 28, 2023 at 12:28 PM
    Retired Blue
    Steven
    Round Rock, TX
  25. Apr 28, 2023 at 12:31 PM
    Bergy24
    Bergy24 New Member
  26. Apr 28, 2023 at 2:23 PM
    Tripleconpanna
    :hattip:
    Retired Blue[QUOTED] likes this.
  27. Apr 28, 2023 at 5:14 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Was raining but got some shots. Also a old to new comparison as also removed the stamped inserts for a cleaner look.
  28. Apr 28, 2023 at 5:23 PM
    Beaudog
    Beaudog New Member
    Scott
    2020 Tundra Platinum
  29. Apr 28, 2023 at 5:46 PM
    Tundrastruck91
    ditto
  30. Apr 29, 2023 at 9:36 AM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    Mike59 likes this.
