  1. Apr 4, 2023 at 12:42 PM
    Blkdmax
    Blkdmax New Member
    Tennessee
    2021 Cement CrewMax 4x4
    Do you have a case? I’m curious if it would work with the case on. My phone wouldn’t last one day without a case.
    RainMan_PNW likes this.
  2. Apr 4, 2023 at 1:04 PM
    Voda48
    Voda48 New Member
    Wisconsin
    2016 Platinum
    Yes, I have a case. It is a pretty simple Spigen case off Amazon. I used to have a really heavy duty case on my Pixel 6 pro but it was obnoxiously large. I doubt that would have fit in the charging tray but it didn't really fit in a front pocket either.
    Blkdmax[QUOTED] likes this.
  3. Apr 4, 2023 at 1:06 PM
    Rangers
    Rangers New Member
    Joe
    Oklahoma
    2017 Bad Barcelona TRD Pro
    TRD sway bar
    Right at $570
  4. Apr 4, 2023 at 1:07 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    The resonator will eventually rotate on you, especially if you do any kind of off-roading.
    AggiePhil likes this.
  5. Apr 4, 2023 at 1:11 PM
    centex
    centex New Member
    That's what welders are for.
    thedoodab1des, WVI and matictundra like this.
  6. Apr 4, 2023 at 1:27 PM
    S13ka24de
    S13ka24de New Member
    What does this do? Thx
  7. Apr 4, 2023 at 1:42 PM
    Funky_Chef
    Funky_Chef New Member
    Andrew
    2019 limited
    Whered you order the grill
  8. Apr 4, 2023 at 4:12 PM
    SPOirish28
    SPOirish28 New Member
    Ontario, Canada
    2014 SSM SR5 DC
    Satin black roof, 18” KO2’s, satin black powder coated steel rims, tri fold tonneau cover. Led lights interior, exterior. Trd pro grill. 13” ryonnair antenna. OEM LED headlights.
    Yeah I’ll be sure to check it every now and then, part of me wanted to use nylock nuts on the clamps too but for now I’m trusting what it came with..
  9. Apr 4, 2023 at 4:13 PM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    That looks so much better!
  10. Apr 4, 2023 at 5:08 PM
    fuzzamungus
    fuzzamungus New Member
    18 Tundra Limited
    It can be used instead of air bags. It helps if you are sagging in the rear. Check out the reviews I love mine!
    Velocity72 and KingsAustin like this.
  11. Apr 4, 2023 at 5:09 PM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    Installed some VLED footwell lights front and rear in aqua blue from hotshot off-road. Real happy with how they turned out, pretty easy install and they even match the climate and radio knobs.
  12. Apr 4, 2023 at 5:14 PM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    love it! usually it is a before and after pic. You have the during and after! What a shine. What is your go to wax? I am almost out of my supply (Griott's garage polishes and wax) and want to try a new wax.
  13. Apr 4, 2023 at 5:22 PM
    Sleeper16plat
    Near Vancouver
    wow! that is quite a rig. the spare tire rack is very cool!
    STravis[QUOTED] likes this.
  14. Apr 4, 2023 at 5:23 PM
    Taco-Spike
    Two Trucks
    Powered up
    930E3D0E-7940-4589-B902-DB9B58957DF3.jpg 8CCF904E-0047-4547-87DC-BE037532D2DF.jpg
    Edit: from stock harness had to add 8tf extension to driver side and added 12ft to passenger side. Way more than what I had to do to the Tacoma.
  15. Apr 4, 2023 at 5:32 PM
    biebs96
    PA
    For wax I used this…
    (I do not use this every time)
    And followed it up with Duracoat No Rinse waterless car wash.
    I use this stuff often. If the vehicle is clean and gets hit with rain or general commuting grime, this stuff rocks!
    I can bring the truck to a “just washed” look in 15 minutes, including the wheels. Which is great if you are pressed on time on the weekends like most people with children are.
    Here is a photo of the truck “washed” with the no rinse waterless wash.
  16. Apr 4, 2023 at 6:45 PM
    engineer
    engineer Drive it 4ever
    Seattle, WA
    '21 Limited Double Cab
    Installed mine today. I got the HD kit and used the thin white disk to gage the spring tension. I went for a short drive (unloaded) and noticed a big handling improvement. The truck felt more planted. Also added one inch of lift to the rear.
    "RAS helps with squat, but doesn't stop there. Instead of resisting weight at the frame and having to make readjustments like an air bag helpers, RAS® springs engage with the existing leaf spring in a progressive manner. This tension coil spring provides a perfect blend of load handling, road handling and unloaded ride quality without readjustment or hassle."
    Here's a link to the thread.
  17. Apr 4, 2023 at 6:54 PM
    biebs96
    PA
    these provide any lift when unloaded? If they give an inch I think I’ll swap out my rear lift for these.
    KingsAustin, fuzzamungus and RobertD like this.
  18. Apr 4, 2023 at 7:59 PM
    nhw544
    nhw544 Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    Put the wheels and tires from my previous Tundra on and gave her a bath.E44363C6-4118-4C50-B1D6-5F2D5E1A6D56.jpg Installed a stubby antennae.
    Also installed the Cat Security cat plates that cover the front and rear cats.
  19. Apr 4, 2023 at 8:01 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Is it too soon to suggest one of these?
    https://a.co/d/eRBlYUj
  20. Apr 4, 2023 at 8:03 PM
    nhw544
    nhw544 Food fight!
    RVA
    Hahahahaha that might be next!
    TRDFerguson[QUOTED] likes this.
  21. Apr 4, 2023 at 8:06 PM
    fuzzamungus
    18 Tundra Limited
    Yes it will. The springs are adjustable, I raised mine about 1-1/4". One of my favorite mods.
    Velocity72 and biebs96[QUOTED] like this.
  22. Apr 4, 2023 at 8:46 PM
    Tundra-XP
    Tundra-XP New Member
    Will
    2020 Toyota Tundra XP MGM CM TRD Off Road
    Hey I like that Cat Security. Are there any holes to drill. I haven't decided which one to go with. I was wanting one that has an access door to check the transmission or transfer case levels without having to remove the whole shield.
  23. Apr 4, 2023 at 9:58 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    If you want to use the TRD skidplate, I would suggest you go with Talons. I don't dislike my plates from GetCatSecurity but I'd buy Talons now, as they don't require modification to fit the TRD skidplate I added myself later.
  24. Apr 5, 2023 at 9:57 AM
    nhw544
    nhw544 Food fight!
    RVA
    Yes you have to drill out some existing holes in order to fit the rivet nut for the security bolts. It’s a very simple install. Took me about an hour. It would be even easier if you have access to a lift.
  25. Apr 5, 2023 at 10:30 AM
    MedCityMoto
    You CAN actually install without the security bolts, it's not a requirement, but it sure as hell does make the removal/installations later easier.
    NewImprovedRon likes this.
  26. Apr 5, 2023 at 11:39 AM
    GandalftheGrey
    GandalftheGrey New Member
    2014 Tundra Platinum CM
    Got it from my local toyota parts dealer. They price matched sparks parts for me too!
    Tundrastruck91 likes this.
  27. Apr 5, 2023 at 3:41 PM
    2-4-5 trioxin
    2-4-5 trioxin New Member
    2020 Tundra Limited
    I moved the rear diff breather up behind the drivers tail light.
    I’ll be doing the seat jackets mod to the drivers seat tomorrow if the weather stays dry.
  28. Apr 5, 2023 at 4:15 PM
    the red
    the red the threat is real
    New Brunswick, Canada
    Well, you guys have done it. Roadmaster Active Suspension is now on my wish list.
  29. Apr 5, 2023 at 5:26 PM
    TaquitoBandito
    Joel (AKA Bif)
    I installed my @RainMan_PNW modified MagSafe Wireless Schoshe Charger. While I was at it, I taped my Ottocast Wireless Airplay https://www.amazon.com/dp/B09Q65SX4..._1_8&amp=&crid=2ZVPW5T39BNJS&sprefix=ottocast to the underside of the console. Everything works perfectly and looks great. Thanks again, Casey!
  30. Apr 5, 2023 at 9:37 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    :fistbump::hattip:
