  1. Feb 2, 2023 at 7:06 PM
    breynolds
    breynolds New Member
    Future Tundra owner
    Thanks for all the info!
  2. Feb 2, 2023 at 7:39 PM
    vilord
    vilord New Member
    Jesse
    2019 TRD
    I'll be tearing into my dash once I get a dual zone hvac housing to swap in... stopping by the parts yard tomorrow to try to convince them to pull one out of a limited they've got in the back, if I buy all the leather seats out of it.
    Any tips / gotchas come to mind on the dash disassembly?
    Beach Toy and the red[QUOTED] like this.
  3. Feb 2, 2023 at 10:23 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Load her up with 20 bags of 90lb quikrete.
    Terndrerrr, Odin43, bulldog93 and 6 others like this.
  4. Feb 2, 2023 at 10:25 PM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    I did a forward camera install. Lots of dash assembly for that process. You might want to look at some of the posts there for the dash disassembly.https://www.tundras.com/threads/2014-2021-front-rear-anytime-camera-mod-frac-harness.13633/unread
  5. Feb 2, 2023 at 11:54 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Pulled the rear shocks and cleaned them up then some polish. Heat shrunk the clamps and threw some new stickers on. Decided I’ll get all the shocks cerakoted at some point. Since the raw aluminum does take a beating.
  6. Feb 3, 2023 at 5:45 AM
    the red
    the red the threat is real
    New Brunswick, Canada
    Well, I wish I was able to document it. Patience, take pictures as you go for reference, put fasteners in bags and label them or tape them to the part they secure (or back in the holes when it's an option). Fortunately the wiring can't be plugged into the wrong places as they're all different (for the most part). You'll have to go a step further than me and remove the dash subframe. Have a plastic trim removal tool and trim fastener removal tool handy. Grab some spare clips as you'll inevitably break some. I never found a video to show the whole dash removal, but there's one by a member here on removing the trim from the face of the dash. Hopefully you have a heated garage with plenty of space for the parts. Avoid doing it in the cold, as the plastic will be more brittle.
    It's quite an undertaking to swap to dual climate control. You've got to really want it. I hope you're not disappointed with the end result as even with dual climate control it's still a small space where it will equalize fairly quickly. Also, I'd consider getting a new unit instead, or compare the cost anyways. To do all that labour, then have something go bad and have to go through it again would be painful.
    Beach Toy and GI Joe's Surplus like this.
  7. Feb 3, 2023 at 6:55 AM
    the red
    Removed painter's tape from painting the chrome on my shift knob...and whhhaaaa?!?!? o_O
    Is all the black "leather" on the 1794s faux or bonded leather? It seems all the brown leather is full grain. :confused:
    Jcmf52 and 1794TX like this.
  8. Feb 3, 2023 at 7:07 AM
    Taco-Spike
    Two Trucks
    That's not good
    the red[QUOTED] likes this.
  9. Feb 3, 2023 at 7:08 AM
    radon222
    radon222 '21 CrewMax / '18 4Runner
    Ed
    NW Arkansas
    2021 CrewMax TRD OffRoad
    Stock for now
    Thank you for showing me exactly what my truck will look like! :D
    Did you do the recommended UCA's or stay with OEM?
  10. Feb 3, 2023 at 9:41 AM
    vilord
    vilord New Member
    Jesse
    2019 TRD
    It is more that the previous owner smoked in my truck and while I could rip out and replace the seats and seat belts, pull out and wash the carpets in a big clothes washer, and possibly replace the headliner, all of those are honestly not that bad at all, but the hvac box seems to perpetually be an old-cigarette-smell-pump, even with a new cabin air filter. pulling the box and vents and doing the parts-washer trick like you did for the vents is probably my best bet, and once i get there i might as well add dual zone to the hvac box :)
  11. Feb 3, 2023 at 9:48 AM
    DFW_SoldTacoBoughtTundra
    DFW_SoldTacoBoughtTundra New Member
    DFW
    2021 Limited 4x4
    6112s, Icon add-a-leaf pack, Icon 17s
    You might want to consider renting an ozone generator and run that in there for a bit. I had a truck that I really wanted but it smelled like an ashtray and knew that the Ministry of Finance wouldn't bless it smelling that way. A detail shop ran that ozone generator in there for 12 hours or so and the odor was gone.
    DBamaC, Henry1jg, mr0351 and 3 others like this.
  12. Feb 3, 2023 at 9:54 AM
    vilord
    vilord New Member
    Jesse
    2019 TRD
    I've got an ozone generator, and ran it in there with the truck running and the heat on for about 4 hours (helloooo idle fuel consumption...) and yes it helped a huge amount, but even just a week later, the heat smells again...
    I'll run it again before my florida trip though. maybe i'll hook up a charger and run it overnight in the garage
    the red likes this.
  13. Feb 3, 2023 at 9:58 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    leave the truck off. then run the Ozone machine overnight.
  14. Feb 3, 2023 at 9:59 AM
    vilord
    vilord New Member
    Jesse
    2019 TRD
    that won't do anything for the smoke smell in the vents, the truck closes all those up when it's off
  15. Feb 3, 2023 at 10:08 AM
    ThatGuyTheCooler
    ThatGuyTheCooler New Member
    I installed the cartrimhome auto up/down panel. Excellent upgrade so far!
    Taco-Spike likes this.
  16. Feb 3, 2023 at 10:14 AM
    Taco-Spike
    Two Trucks
    :worthless:
    mr0351, bulldog93 and cartage1 like this.
  17. Feb 3, 2023 at 11:42 AM
    the red
    What about cycling between the windshield, face, and floor vents, cycling hot and cold, and using recirculate?
  18. Feb 3, 2023 at 11:43 AM
    vilord
    vilord New Member
    Jesse
    2019 TRD
    That is probably best with the ozone generator running, just have to do that without breathing the ozone as it damages lungs :)
    1794TX likes this.
  19. Feb 3, 2023 at 12:31 PM
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    I agree! I'm from the Vancouver area. The warmer climate and prolific drugs have led to tent cities hidden all around and an entire community besieged! They don't hold any of them accountable as they are thought to be victims of their chosen addiction. Many hardened criminals from across the country hide amongst them. Maybe if you shoot someone between the eyes with witnesses you could be kept in jail for a bit.
    Tundrastruck91, 1UP and RainMan_PNW like this.
  20. Feb 3, 2023 at 12:51 PM
    DFW
    2021 Limited 4x4
    Not a bad idea to run it for a longer period of time. Also, look into renting a "commercial" unit to use. After my experience with de-odorizing the truck we had a camper that was repo'd and the deadbeat left the fridge and freezer full of food in the Texas summer heat. After having all the maggots and decomp goop out I ran an ozone generator for a couple days and it helped a lot. If I recall correctly I rented the commercial unit for something like $28 a day.
    vilord[QUOTED] likes this.
  21. Feb 3, 2023 at 12:54 PM
    Cue_32
    Cue_32 New Member
    Don
    TRD Off Road
    Drove from Sauga to Kitchener for a Kijiji deal. Great deal from a good dude
  22. Feb 3, 2023 at 1:04 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Darn, I recall z racing in Sauga had them for $600 for a set back in late 2020, I kick myself for not getting a set then.
  23. Feb 3, 2023 at 1:39 PM
    Blueox08
    Blueox08 Building it better stronger but slower
    Sam
    Southern Oregon coast
    2019 Tundra sr5 double cab 8ft
    Ironman 4x4 3.5” full suspension lift Ironman 4x4 8ft awning with attached tent room Elk leg bone shifter Arb canopy with kargo master rack 10ft rooftop cedar deck with lighting Rough country grated step boards Tuffy Center console safe Keyline smart batter isolater with dual batteries to power inverter. 8ft wooden drawer slides with bed plat form for camping set up Ironman 4x4 13 gallon water tank. Bucket shower Side step lights and back up lights. More to come
    Where did you get the moly panel that sits by your right leg from?
  24. Feb 3, 2023 at 1:41 PM
    Taco-Spike
    Two Trucks
    Blueox08[QUOTED] likes this.
  25. Feb 3, 2023 at 1:44 PM
    Blueox08
    Sam
    Made a shifter knob from an elk leg bone. It had the perfect grip already built in.
  26. Feb 3, 2023 at 2:04 PM
    AZBoatHauler
    So.Arizona
    I’d tell people you had a hip replacement and the Doc was kind enough to save it for you.
  27. Feb 3, 2023 at 2:09 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    I just spit out my drink after reading this…lol :rofl::rofl:
    I just had my hip resurfaced, I would love to use that line (I guess that what makes it so funny for me).
  28. Feb 3, 2023 at 2:10 PM
    catus
    catus New Member
    Centennial, CO
    '19 MGM DC Limited, stock for now
    Yep, Victory. I love mine. I'll add the pax side for my wife this weekend.
  29. Feb 3, 2023 at 2:29 PM
  30. Feb 3, 2023 at 2:58 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    OK
    That wins the internet today.
