  1. Jan 12, 2023 at 12:01 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Did that with my entire collection years ago
  2. Jan 12, 2023 at 12:30 PM
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    Can you expand on this please? What paper plate? Are you referring to just the front skid plate or all 3 including the cat protectors? Are you thinking there was a drastic MPG loss when you put these shields on?
    HulkSmurf14 likes this.
  3. Jan 12, 2023 at 12:40 PM
    centex
    centex New Member
    Paper plate is a descriptor of the stock skid plate because it’s so thin.
  4. Jan 12, 2023 at 1:00 PM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    With my Valhalla plates I’am getting between 14 and 16 mpg. Running 285/70/18 tires. I don’t think the plates hurt your gas.
    tundrasportinMA and MedCityMoto like this.
  5. Jan 12, 2023 at 1:02 PM
    AGTundra
    AGTundra New Member
    Miguel
    North Carolina
    21 CM TRD Off-road
    Def like the OG TRD knob …but wanted to try something different
  6. Jan 12, 2023 at 1:02 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    You'd think having some plates to streamline airflow would be better aerodynamics, but I'm no wind scientist ‍♂️
    RusPro21[QUOTED] likes this.
  7. Jan 12, 2023 at 1:08 PM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    Adding the cat plates should help the aero flow, but not significantly. Similar to adding a tonneau cover will help with aero, but not significantly either. All the little adds add up tho.
    RusPro21 likes this.
  8. Jan 12, 2023 at 1:09 PM
    RobertD
    Robert
    DFW, Texas
    What's the OG TRD knob?
    AGTundra[QUOTED] likes this.
  9. Jan 12, 2023 at 1:13 PM
    They don't. It's not unsprung weight like tires.
  10. Jan 12, 2023 at 1:14 PM
    Nice....now get rid of that piano black glare. :D
  11. Jan 12, 2023 at 1:37 PM
    AGTundra
    AGTundra New Member
    Miguel
    North Carolina
    21 CM TRD Off-road
    Just poking fun at the traditional trd knob
  12. Jan 12, 2023 at 1:39 PM
    AGTundra
    AGTundra New Member
    Miguel
    North Carolina
    21 CM TRD Off-road
    Had a feeling you would say that :thumbsup:
    Def gonna do something bout it when I can get some time to tear it back down
    Tundra234[QUOTED] likes this.
  13. Jan 12, 2023 at 1:52 PM
    Catmann1972
    Catmann1972 New Member
    Greg
    Rhode Island
    2020 TRD Sport
    I almost went this route and installed the same radio. But I didn't like how it recessed into the dash. I installed a Stinger head unit instead, a floating head unit with a mounting bracket that hides everything around the unit. I still have the Kenwood sitting on my workbench still in the box never opened.
  14. Jan 12, 2023 at 2:07 PM
    RusPro21
    Don
    Pa.
    What headunit do you have you did not install? I don’t like about some of the reviews with the larger floating headunit rebooting and other issues. I have to say my JBL headunit with my aftermarket system and DSR1 works great.
  15. Jan 12, 2023 at 2:11 PM
    Cue_32
    Cue_32 New Member
    Don
    TRD Off Road
    Thought I’d be ok with running steelies for the winter months. Didn’t like it so I got TRD Replika rims for the winter.
    I gotta stop looking at some of the trucks on this site, I can’t stop wanting more mods lol
    Oh and got under-body rust proofing done too.
  16. Jan 12, 2023 at 2:18 PM
    Haha...want the link to the build threads? :D
    mgm16trdpro likes this.
  17. Jan 12, 2023 at 2:51 PM
    Cue_32
    Cue_32 New Member
    Don
    TRD Off Road
    NOoOoOoOoOooooO!!!! Yes, please
  18. Jan 12, 2023 at 2:55 PM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    Haven't done much with mine lately but I did finally get a chance and had a break in the weather to get an inside clean and outside wash in.
  19. Jan 12, 2023 at 3:16 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    The difference I'm trying to figure out is with the cooling fan as the main suspect. Earlier this year while still on the stock skid I was experimenting with how much airflow needs to pass through the upper grill before temps rise and trigger the cooling fan clutch on the freeway. It doesn't take much increase before the fan kicks up, maybe 5 degrees, and the first sign is the engine running cool. I have 4 small 3d printed panels that was about the limit as long as it was under 95° outside. It was getting great mileage with them.
    The valhalla cat plates certainly didn't hurt and they're staying on, but as soon as the engine skid went on the highway mileage went down a lot. I couldn't even get 14 when before I was doing 19+. After more trial and error last month I was catching the cooling fan spinning up in freezing cold air on the freeway with a coolant temp of 190F. All blocks removed helped somewhat but it still did it a few times last trip. You can tell when in cruise the instant mileage reading drops a good 5 mpg for a bit and the coolant/trans temps fall a few degrees a few seconds after. Sometimes if the road noise is quiet you can hear it too.
    The stock skid stays high and tight until it mates up to a foam strip so it blocks off the lower portion of the area in front of the radiator. As the valhalla skid profile drops well in front of the radiator, the low pressure you normally get down there might be drawing airflow downward before the rad and cutting down airflow thru it. A lot of times when a car has a wind dam down there it's not just for aero; the low pressure zone behind it helps force air thru the radiator.
    Anyways it's just a test for a while but so far I haven't heard the fan again.
    MatthewPTguy and bobbilly like this.
  20. Jan 12, 2023 at 3:30 PM
    greg8765
    greg8765 New Member
    Grant
    Utah
    2021 Cement Tundra
    Wow! How long did that take to pull apart like that?
    the red[QUOTED] likes this.
  21. Jan 12, 2023 at 3:36 PM
    It's not too bad pulling it apart. Some plastic pry tools and some youtube. @2020Platinum has some on his channel. :thumbsup:
    cartage1, 2020Platinum and the red like this.
  22. Jan 12, 2023 at 3:39 PM
    GWill
    GWill gods gift to the internet
    Willis
    Don’t know what you’re talking about
    2020 MGM TRD Pro
    Slapped on my TURD badge
  23. Jan 12, 2023 at 4:34 PM
    Beach Toy
    Beach Toy New Member
    David
    SE NC
    2017 White SR5 4x4
    Lomax cover, TRD PRO headlight conversion...so far anyway
    6DDC029E-9A94-4A24-81CB-3E30626A1062.jpg Sprayed mine with matte clear. Piano gloss gone and chrome is closer to the other matte silver.
  24. Jan 12, 2023 at 4:45 PM
    the red
    the red the threat is real
    New Brunswick, Canada
    I wasn't really paying attention to how long, and have been doing various things at once. Between completely removing the dash/centre console and disassembling individual components I'd say 8 hours. That's really taking my time though. Patience is key.
    French Avocado and Beach Toy like this.
  25. Jan 12, 2023 at 4:47 PM
    the red
    Nice! Doing mine in satin clear shortly. It's all peeling. What did you do for prep?
    French Avocado likes this.
  26. Jan 12, 2023 at 4:50 PM
    AGTundra
    AGTundra New Member
    Miguel
    North Carolina
    21 CM TRD Off-road
    Looks good
    Waterline Brewing sticker on there?!
    Def a cool spot!
    Beach Toy[QUOTED] likes this.
  27. Jan 12, 2023 at 5:22 PM
    Beach Toy
    David
    SE NC
    2017 White SR5 4x4
    Nice catch! One of our favs! We also like Catawba Brewing.
  28. Jan 12, 2023 at 5:24 PM
    Beach Toy
    David
    SE NC
    2017 White SR5 4x4
    Cleaned it really good and then wiped down with alcohol prep pad. Shot two coats and let it dry outside when it was 80 or so.
  29. Jan 12, 2023 at 5:34 PM
    AGTundra
    AGTundra New Member
    Miguel
    North Carolina
    21 CM TRD Off-road
    You got to try Wilmington Brewing Co as well….tropical lighting is a fan favorite here!
  30. Jan 12, 2023 at 5:54 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Installed some color matched bumper caps with new SS3 Sports
    5999B662-14BA-4F67-AF47-115FCCBFB7B1.jpg 3F6526FF-2C84-46E0-AAE6-39A95ED6B31E.jpg
