  1. Jan 8, 2023 at 7:28 PM
    SAGE63
    San Diego County
    Yeah ran power to my accessory fused powerblock next to the battery via the hole by the driver taillight through the bedside over the wheelwell over the frame into the driver side engine compartment.
  2. Jan 8, 2023 at 7:39 PM
    SwitchThrottle
    SwitchThrottle Living in Idiocracy
    2021 Barcelona CrewMax
    My "hotwire" is on a fused power block near the battery for now. The wire is inside wire loom in the driverside frame rail front to back. The power block is also temporary until I can figure out a more permanent solution I like.
    I know a lot of folks are attaching to the fuse panel lid, but it just doesn't sit well with me, so for now things are "secured".
    SAGE63 likes this.
  3. Jan 8, 2023 at 9:27 PM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    glad the boss likes em man, thanks for the support!!
  4. Jan 9, 2023 at 2:36 AM
    I ran mine to the license plate light and I have a switch that fits the factory hole in the bed. I have to turn my parking lights on for power so I know that they will never get left on.
    Henry1jg, SAGE63 and WAtundra4x4 like this.
  5. Jan 9, 2023 at 7:04 AM
    Gainer
    Gainer New Member
    Columbus, OH
    2018 SR w/8' Bed
    Leveling kit, TRD wheels, remote start, Hellwig helper springs, TRD Rear sway bar. TRD Rear shocks, Dirty Deed 10" exhaust, S&B Cold Air intake
    Any idea where the leaves are getting in from? I have had the same problem and want to get it fixed. I'm sure that area would rust out sooner than the rest of the truck.
  6. Jan 9, 2023 at 7:24 AM
    GWill
    GWill gods gift to the internet
    Willis
    Don’t know what you’re talking about
    2020 MGM TRD Pro
    Im not sure, I havent looked into it yet. But I could see it becoming a problem with that much organic build up. Im assuming they fall in between the hood and windshield, I do see leaves in the back right corner of the engine bay when I pop my hood. I plan on checking it out this weekend.
  7. Jan 9, 2023 at 8:28 AM
    redrum448
    redrum448 New Member
    Ive said this a dozen times but I guess it gets lost in the fray but if you put a pad of some sort on the arm rest charger it will work
  8. Jan 9, 2023 at 8:42 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Stick a shop vac nozzle in there to suck out the rest of the leaves. If they are wet or get wet, they will promote rust in the door.
    TampaRD Pro, WILLINH and bulldog93 like this.
  9. Jan 9, 2023 at 10:20 AM
    GWill
    Willis
    2020 MGM TRD Pro
    What i couldnt get to was around the right edge, going into the cab. I wont be able to get a shop vac over there. Im thinking I need figure out how to get compressed air behind the organics or a power washer to blow the rest out. I agree rust could become a problem.
  10. Jan 9, 2023 at 11:02 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Rotated the tires today. While off, washed and waxed both sides of the wheels. Also, while I had the wheels off, I cleaned where I usually can’t get too very well. Good ole tooth brush and simple green do wonders! Calipers look nearly new! I wired brushed around the hubs on all four wheels too. The first picture was before I did that.
    Followed up with under coating with a small paint brush. The welds that were starting to show shiny metal under the factory coating. To prevent any sort of rusting, I hit them with Rust-Oleum under coating. Figured while I had the stuff and brush out, I hit all the welds on the rear end. This stuff really matches the factory coating well!
  11. Jan 9, 2023 at 11:05 AM
    Rustedfenders
    Rustedfenders If it ain't broke, don't fix it.
    Wally
    Rosedale Md.
    2016 Blazing Blue Pearl TRD Tundra Crew Max
    Aries 4" Bull Bar, 3-2 Level Lift Havoc Stainless hoop steps.
  12. Jan 9, 2023 at 11:07 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Healed some finest New England rust in frame's welds. Rust cancer was there from factory, hidden by a layer of paint.
    Also rotated tires and made sure tire fuses are still in place (they stop spinning once the fuse is gone, right?)
  13. Jan 9, 2023 at 11:15 AM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Nice ! ...was waiting for discounts but alas none for X-Mas or New Years
  14. Jan 9, 2023 at 11:21 AM
    Rustedfenders
    Wally
    Rosedale Md.
    255.00 Amazon
  15. Jan 9, 2023 at 11:54 AM
    Tundrastruck91
  16. Jan 9, 2023 at 12:06 PM
    SwitchThrottle
    FedEx just delivered my Saturday delivery!
  17. Jan 9, 2023 at 12:18 PM
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    The install on those says to use new U bolts I think. Did you bother with that?
    French Avocado likes this.
  18. Jan 9, 2023 at 12:40 PM
    dherring256
    dherring256 New(ish) Member
    2018 MGM SR5
    Fuzzy Dice
    Got the form projectors mounted up today. Thanks @memario1214
  19. Jan 9, 2023 at 1:00 PM
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    38 degrees out? Good enough for a bath!
  20. Jan 9, 2023 at 1:03 PM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Looking awesome Mike!!
    cartage1 and FISHN43[QUOTED] like this.
  21. Jan 9, 2023 at 1:04 PM
    FISHN43
    FISHN43 New Member
    Ohio
    Thanks Don!
    RusPro21[QUOTED] likes this.
  22. Jan 9, 2023 at 1:04 PM
    RegGex
    RegGex I noticed you copied my beard
    Oregon
    2021 TRD Pro CM
    Cross posting here in case it gets buried (the search bar will fox that :thumbsup:)
    Figured I’d post this here for folks who have or are looking for a Diamondback HD cover and would like some type of rack for (fun) purposes.
    The UpTop Overland Diamondback Truss Bed Rack is a great option as you won’t have to do ANY DRILLING for the rack on your cover, they utilize the existing cleats on the HD as their mount points. It also has a Dynamic load rating of 300lbs and Static load rating of 1100lbs. I couldn’t find that info on their page so I just got that from emails with them. That’s a big plus for me as I just didn’t really like the thought of having to drill into the cover for the existing rack or crossbar applications (front runner, Yakima, etc..) and also having a great load rating for RTTs since that’s why I’m interested. Also just to be clear this is only for the HD version, not SE as well as assuming you had Diamondback preinstall your cleats for you at manufacturing, otherwise you’ll have to get the rack and then put your cleats on since their mount points are based on where Diamondback installs them.
    I also have no affiliation with UpTop, just was doing a ton of research for my setup I’m looking for and just didn’t want to drill into the cover or also sacrifice potential leak points for having rack adapters go under the factory DB seals
    With that all being said, today the order will go in :D
    1794TX, Henry1jg and Patch999 like this.
  23. Jan 9, 2023 at 2:01 PM
    Cthulhu
    Oh trust me I’ve read just about every post there is “in the fray” on this issue including your “dozen”…no dice, indicator goes to red within a few secs of laying down, even using padding, removing the case, etc. Worked fine with my iPhone XS Max, and still works with my wife’s iPhone SE with a case, so it’s not the charger.
  24. Jan 9, 2023 at 2:14 PM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Installed my Boost Auto Parts tow mirrors. Santa was very generous this year.E7C45D82-E31D-40D6-A9B4-773D7D68B3DC.jpg
  25. Jan 9, 2023 at 3:10 PM
    NewImprovedRon
    Ron
    NW Arkansas
    How about opening the hood and using a blower to push the leaves down to the opening?
    2mchfun and cartage1 like this.
  26. Jan 9, 2023 at 4:04 PM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    Be careful here. Spend too much time and you’ll have new suspension…. And tires…. And wheels… and seats….and stereo…. And bed cover….. and next thing you know you’ve spent $10k.
  27. Jan 9, 2023 at 4:32 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Oh man, those are nice! I've been eyeing those on Amazon too, but was unsure. Wiring was pretty straight forward?
  28. Jan 9, 2023 at 4:33 PM
    GWill
    Willis
    2020 MGM TRD Pro
    Yeah that’s what I’m thinking with the compressed air. We shall see this weekend
  29. Jan 9, 2023 at 4:35 PM
    RobertD
    Robert
    DFW, Texas
    :thumbsup:
    Rgross2112[QUOTED] likes this.
  30. Jan 9, 2023 at 4:37 PM
    Rabidllamas
    Rabidllamas New Member
    Phil
    WA
    2019 Cement Crewmax TRD OffRoad
    My build- https://www.tundras.com/threads/rabbidllamas-old-man-build.80802/
    At the risk of being shamed, and humiliated , I did not. But they can be changed easily and I need to just get new ones.
