  1. Nov 20, 2022 at 9:34 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Yes. Parking assist. It has its own ECU and speaks directly to the instrument cluster.
    BSM/RCTA communicates over CANBUS as well as dedicated signals back to several different components including the ECU.
    BSM/RCTA has been fairly straight forward to add. Parking assist has been a pain
    bulldog93 and texasrho83[QUOTED] like this.
  2. Nov 20, 2022 at 9:46 AM
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    May I have the model numbers of the Kenwoods?
  3. Nov 20, 2022 at 9:50 AM
    GCanuck
    Gary
    BC,Canada
    Louder because the amp now only drives the L + R. The centre speaker had a mono combination of L+R. I think.
    batman900[QUOTED] likes this.
  4. Nov 20, 2022 at 9:54 AM
    GCanuck
    Gary
    BC,Canada
    I always wondered if BSM was just a programming thing. of course with the indicator lights needed.
  5. Nov 20, 2022 at 10:07 AM
    Red406Tundra
    Red406Tundra New Member
    Billings, MT
    2019 Barcelona Red SR5
    Installed a Rago Fabrication dash mount.
  6. Nov 20, 2022 at 10:12 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Oh I like that a lot. Added to my list. Thanks
    Edit: just watched the install video. Thinking out loud, instead of removing all the stuff to have access to drill the holes, I thought about bonding the bottom bracket to the dash. I work in aerospace and have access to some heavy duty stuff.
  7. Nov 20, 2022 at 10:31 AM
    biebs96
    PA
    Even so, lots of guys pull them, put the dash mat back in upon selling the truck and resell the entire setup on here.
  8. Nov 20, 2022 at 11:07 AM
    STravis
    STravis SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    I've got one of the older rago plates sitting in the shop if you are interested. I'd let it go pretty cheap.
    bulldog93 likes this.
  9. Nov 20, 2022 at 11:25 AM
    RainMan_PNW
    Casey
    Clark County, WA
    It’s not so much a programming thing - you need the BSM radar units that are mounted in the bumper (one on each side), the indicator lights, and a buzzer for the RCTA. If all those components are installed and wired up correctly, then the system will “just work” (aside from calibration and alignment of the radar units). You go into the instrument cluster settings and turn it on.
    Parking assist, so far, requires the sensors, the switch, a dedicated ECU, and the correct part number instrument cluster.
  10. Nov 20, 2022 at 12:16 PM
    GCanuck
    Gary
    BC,Canada
    I'm in Canada and have a 2020 TRD Sport DC. I have parking sensors and the RCTA already. I believe that the BSM came with the TRD Sport Premium package. So oem mirrors with BSM indicators.
    I thought the BSM used the parking sensors for BSM? So I figure I only need the mirrors and maybe a software update?
  11. Nov 20, 2022 at 12:27 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    You could do that. I did the Rago mount with the ics reinforcement plate.
    CaptRussia253[QUOTED] likes this.
  12. Nov 20, 2022 at 12:29 PM
    :101010:
    Tripleconpanna likes this.
  13. Nov 20, 2022 at 12:33 PM
    catus
    catus New Member
    Centennial, CO
    '19 MGM DC Limited, stock for now
    Installed my Talon cat shields. The steps will need to wait till another day...
  14. Nov 20, 2022 at 2:40 PM
    rocsteady
    rocsteady New Member
    Dave
    New Jersey
    2021 Super White SR7 Double Cab SX
    Hard to get to the side speakers that you replaced?
  15. Nov 20, 2022 at 3:18 PM
    Taco-Spike
    Two Trucks
    Not the OP
    Not hard. Pop off the covers and swap with a 10mm
    EF548016-AF1E-4720-BD9B-90AC4B3C4D25.jpg 7855690C-7472-480C-90ED-3DBCA5477C84.jpg
  16. Nov 20, 2022 at 3:27 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Pulled the old to make ready for the new.
    My old bumper is gonna be traveling at a faster clip on my buddy's SC'ed 2018.
  17. Nov 20, 2022 at 3:36 PM
    Red406Tundra
    Billings, MT
    Install was a breeze. Bonding it to the dash would work too. It all depends on how heavy of stuff you want to mount. I did reinforce it with fender washers.
  18. Nov 20, 2022 at 4:16 PM
    RainMan_PNW
    Casey
    Clark County, WA
    RCTA (rear cross traffic alert) AND BSM use dedicated radar units that are tucked inside the outboard corners of the resin rear bumpers. It changes the pattern and distance of the radar that it sends out based on whether you are in drive (BSM) or reverse (RCTA). If it detects something coming across while the truck is in reverse, it lights up the indicators in the mirrors and sounds a warning buzzer located in the C-pillar on the driver's side. If it senses something alongside while in drive it lights up the appropriate mirror. If you turn on your blinker to the side it is lit up on in BSM, it will flash that BSM light, but will not make a sound.
    Parking Assist is using the four (in the rear) or two (in the front) visible round sensors to detect objects at very close range and then display that approximate distance (and sound an alert) in the instrument cluster display.
    The two systems are entirely separate. Parking assist is available with both resin and chrome bumpers because the sensors are exposed and only work at very short range. BSM/RCTA is only available with resin bumpers because the radar will not work correctly through the steel/chrome bumper shell.
  19. Nov 20, 2022 at 5:49 PM
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    I’m considering adding this to my truck. Saw your write up. I’ll probably do it with the tow mirrors as well. Just need to buy the parts and find the time! Seems pretty easy aside from wiring it all up!
    RainMan_PNW[QUOTED] likes this.
  20. Nov 20, 2022 at 5:58 PM
    BarcelonanTundra
    BarcelonanTundra New Member
    2020 Barcelona Red Tundra DC Limited TRD OR
    Today I just got back from a winter camping trip in the mountains of WV. Nothing refreshes you like tent camping in 15* weather lol! First trip with my Tundra and it handled the snowy mountain roads just fine.
  21. Nov 20, 2022 at 7:59 PM
    Now we don't have matching bumpers any more lol.
  22. Nov 20, 2022 at 8:04 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Easily rectified. Contact @STravis and getcha one! :p
  23. Nov 20, 2022 at 8:05 PM
    reywcms likes this.
  24. Nov 20, 2022 at 8:06 PM
    Looking at wheels and tires for the 4R. Tire prices are insane.
  25. Nov 20, 2022 at 8:06 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yeah they are which is why I'm still riding on 35s
  26. Nov 20, 2022 at 8:14 PM
    Looking at these. These with 275/70/17 all terrains like the Toyo AT3 is about $2800 for the package with TPMS sensors from CustomOffsets. Might price the Falkens too. Not sure what offset I would need to be flush with the wheel wells.
  27. Nov 20, 2022 at 8:20 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    What's on there now?
  28. Nov 20, 2022 at 8:23 PM
    The stock silver wheel. It will get a 3 inch lift eventually.
  29. Nov 20, 2022 at 8:26 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    What's that offset
  30. Nov 21, 2022 at 5:47 AM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    I just got the Mickey Thompson Baja Boss ATs for my 4R. I like them so far. They did really well in the snow we had last week. I also really liked my Falkens, got a little over 55k out of them. They were a great all around tire on the 4R.
    reywcms and bulldog93 like this.
