  1. Oct 27, 2022 at 10:49 AM
    Taco-Spike
    Two Trucks
    Come and get it
  2. Oct 27, 2022 at 4:43 PM
    Wallygator
    I put some aluminum takeoffs on my truck as it came with the stock steelies. So I needed new lugs. The Steelie lugs are different from the aluminum lugs.
    I have the Gorilla black lugs on my truck and had to order them through discount tire. I could not order them directly from Gorilla. I can't rember which lug it was but I believe it's listed on their website. If you can't find it I will try and locate it. Hope this helps.
    Tundrastruck91 likes this.
  3. Oct 27, 2022 at 7:44 PM
    RegGex
    RegGex I noticed you copied my beard
    Oregon
    2021 TRD Pro CM
    Taco-Spike[QUOTED] likes this.
  4. Oct 27, 2022 at 8:43 PM
    AZBoatHauler
    So.Arizona
    Rear brake pads. Got all their life and then some. :eek:
  5. Oct 28, 2022 at 6:09 AM
    PixelPusher
    PixelPusher New Member
    New Hampshire
    2020 Tundra Limited, Super White
    Thanks for the heads up for discount tire.
    Luckily, I just got the call from the dealer. I'll be heading in this afternoon for replacements. I'll keep an eye out for a deal on solid replacements now that I've got fresh ones.
    Wallygator[QUOTED] likes this.
  6. Oct 28, 2022 at 6:31 AM
    king.cong.1119
    king.cong.1119 New Member
    installed the hood solar couple weeks ago, never have a dead battery again.
  7. Oct 28, 2022 at 6:56 AM
    Kung
    KG, VA
    I'll second Gorilla nuts. (Heh.) My previous truck ('13 F150) had THE WORST lug nuts. Trust me...as bad as you may think Tundra lug nuts are, the F150's were far worse.
    I spent like $130 on a replacement set of Gorilla lug nuts and they were awesome.
    el_conquistador and Wallygator like this.
  8. Oct 28, 2022 at 8:37 AM
    rocsteady
    rocsteady New Member
    Dave
    New Jersey
    2021 Super White SR7 Double Cab SX
    Finally installed the front camera with the FRAC (front rear anytime camera harness offered here by @TundraTex) harness and a Black Label light bar I'd bought from Custom Offsets years ago and never installed.
    AL9nZEWsqCNZlsa5HOtSD031JBFE4wmG62zeY4yw_b434f3db1d70313ac59bcec43a7551e42b784f69.jpg
    AL9nZEXiRWQQOIvbm4arBIPA-VSO8LL-cup3WtJi_e926570ca6d67ccf2b187d3bb88bda628c29af37.jpg
    AL9nZEU8pnNHgRqoAfGscPzlFihTWFTLb8JmGQRz_8cbedc0d585de958b72eaed6d8b161a6ff4779a2.jpg
    AL9nZEVOWxJQAf9_U6MzpnqkHpuKIxet0CYEjDOC_0f2c60dcb93f0d6f4d6cd1f735cdbc648a991dbf.jpg
  9. Oct 28, 2022 at 8:40 AM
    rocsteady
    Dave
    New Jersey
    What does this button do? Forgot to look in the manual after I found it while installing switch for new light bar. Located on dash below and to the right of the steering wheel, under the bezel plate where tailer brake bias and tow/haul switches located. Never noticed it was there before then. To set preferred "normal" tire pressures?
    EpaRMreEHKFBFnzJk4Anv9XCrQNxI56ZI7j7V6X7_1ae626658379d545290be2e84380c9db106ae71d.jpg
  10. Oct 28, 2022 at 8:46 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    TPMS reset
    Blowdart, bulldog93 and Taco-Spike like this.
  11. Oct 28, 2022 at 9:37 AM
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    2018 Crewmax 1794 4x4
    Removed the extra washer I installed on the TRD RSB that wasn't required, endlinks look more vertical now. Then dropped it off at dealer for an oil change and tire rotation.
  12. Oct 28, 2022 at 10:21 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I'm really curious on how a button would set a preferred normal tire pressure?
  13. Oct 28, 2022 at 10:26 AM
    That button is a royal PITA.
    Wallygator likes this.
  14. Oct 28, 2022 at 10:29 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I'm assuming you didnt mean to quote mine? I knew what it did lol
  15. Oct 28, 2022 at 10:39 AM
    That button is used for registration of new sensors, and also for the system to relearn wheel positions after a tire rotation. However, it is a royal PITA.....mine still isn't working.
  16. Oct 28, 2022 at 10:40 AM
    I edited the post and moved it lol.
    Jaypown[QUOTED] likes this.
  17. Oct 28, 2022 at 10:47 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Haha all good! :thumbsup:
  18. Oct 28, 2022 at 11:06 AM
    AZBoatHauler
    So.Arizona
    When you press it - it sets the parameters for the TPMS lights based on the current tire pressure. If your pressure raises or drops a certain level from the set point, it triggers the light on the dash.
  19. Oct 28, 2022 at 11:41 AM
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    I am assuming that you still have to have the correct tmps frequencies for your year?
  20. Oct 28, 2022 at 11:47 AM
    Yes. Mine was fine until I rotated my tires.
  21. Oct 28, 2022 at 11:49 AM
    Wallygator
    Yeah I gave up. Hasn't worked for 2 years now. I have since embraced the tpms warning light, it makes me warm inside to see it constantly glowing in my face.
    Blowdart and AGTundra like this.
  22. Oct 28, 2022 at 11:50 AM
    Taco-Spike
    Two Trucks
    Are you waiting till you rotate back to see if it works?
  23. Oct 28, 2022 at 11:58 AM
    I might mess with it this weekend. The TS508 was no help either.
  24. Oct 28, 2022 at 12:44 PM
    rocsteady
    Dave
    New Jersey
    Thanks All. I figured it was something like that after seeing the picto-symbol on it.
  25. Oct 28, 2022 at 3:09 PM
    Added a little color to the swing cases.
  26. Oct 28, 2022 at 3:50 PM
    Wrongside
    Wrongside New Member
    AB
    2016 Tundra
    Got the DD Elite fogs installed. Also put some new headlight bulbs in. Silverstar Ultra. Hopefully they’re a little better than the originals and will get me thru until the ‘19 Pro LEDs/iHacker mod are feasible. ($1200+ CDN seems ridiculous.)
    Is weird I’m excited for it to get dark? Haha.
    GAknight, AGTundra, bulldog93 and 3 others like this.
  27. Oct 28, 2022 at 6:50 PM
    citrusmaster
    citrusmaster New Member
    Tielar
    2015 Tundra RCLB
    Today I got new (to me) Icon Compression 17 inch wheels for 600$ as well as BFG KO2 285/70/17 tires with 200 miles on them off of a 2022 Jeep Rubicon for 300$. Paid 80$ for mount/balance and probably 20 in gas running around getting it all. Sold my old TSS wheels/tires for 850 (Tires were still fairly new) so only 150$ out of pocket.
    Next up is painting my grill white and installing a ranch hand front bumper
    Steve66, Yota303, Wrongside and 17 others like this.
  28. Oct 28, 2022 at 6:59 PM
    BuzzardsGottaEat
    BuzzardsGottaEat New Member
    '16 Tundra DCLB
    Round Tires
    I’ve yet to see a RCLB in person :drool:
  29. Oct 28, 2022 at 7:07 PM
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    Hidden winch and Barricade bumper.
    Next TRD Pro grill.
    Steve66, Toyotoholic, rebmo and 17 others like this.
  30. Oct 28, 2022 at 7:25 PM
    Vuducrumax
    Vuducrumax New Member
    Had some fun with the best button in the truck.
