  1. Oct 26, 2022 at 8:27 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    I had over an inch with my 35” yokos
    HulkSmurf14 likes this.
  2. Oct 26, 2022 at 2:10 PM
    greg8765
    greg8765 New Member
    Grant
    Utah
    2021 Cement Tundra
    YEAH BUDDY!!!
  3. Oct 26, 2022 at 3:31 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I got my front window tint replaced today.
    Finally got rid of the crappy dealer tint.
    The driver's side looks great.
    The passenger side is full of watery bubbles and looks like specks of dirt between the glass and the film..
    Obviously, 2 different people did each side.
    They both looked ok when I picked it up.
    Do these bubbles fade out after a few days?
  4. Oct 26, 2022 at 3:32 PM
    If they are tiny air bubbles they will disappear after a day or 2. Just park it in the sun...that will help too.
  5. Oct 26, 2022 at 6:56 PM
    Rc23
    Rc23 New Member
    Ross
    Chesapeake
    '16 Super White CrewMax
    Picked this up for a killer deal. $45 on offer up. So stoked to finally have a real feeling steering wheel.
  6. Oct 26, 2022 at 7:11 PM
    throughitalldude
    throughitalldude New Member
    Jeff
    Southern California
    2017 Platinum
    3/1 Lift |TSS 20" Wheels | 35 Cooper AT3 XLT | Flowmaster 40 Series Exhaust
    Posed for a cool photo today
    406Michael, equin, TundraTed and 17 others like this.
  7. Oct 26, 2022 at 8:02 PM
    AGTundra
    AGTundra New Member
    Miguel
    North Carolina
    21 CM TRD Off-road
    If you actually see specks or feel them with your fingernail …more than likely contamination …Removal and re-tints def require a lot of extra cleaning
    Like @Tundra234 said …sun & a few days but if those areas don’t clear up …maybe ask for a redo on that glass
    1lowlife[QUOTED] likes this.
  8. Oct 26, 2022 at 11:14 PM
    Rangergillikin
    Rangergillikin New Member
    Alabama
    2021 magnetic grey TRD Pro Crew Max.
    TracRac bed rack, Retrax bedcover, Anytime forward facing camera, Rago dash mounting plate, changed all lights to LED with 1200lumen reverse light, added LED above tag reverse light, rear bumper step, Go Rhino step sides, CCM Cat Security Shield, tool mounts on bed rails, added tie down pad eye on bed rails.
    Mine had water bubbles for almost two weeks. They all went away and my tint turned out great. I had mine tinted on a really cold week. I even call the guy after the first week and he told me they would go away and to be patient. He was right. Hopefully yours will go away too.
    1lowlife[QUOTED] and bulldog93 like this.
  9. Oct 27, 2022 at 6:21 AM
    5.7TRDProm
    5.7TRDProm What's bothering you?
    Dara
    2018 Cement Tundra SR5
    All stock-ish. Powdercoated blue suspension.
    Looks like a revised kit with the S2 being mounted from the inside instead of outside?
  10. Oct 27, 2022 at 6:22 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Yep, that's correct!
    RainMan_PNW likes this.
  11. Oct 27, 2022 at 6:25 AM
    5.7TRDProm
    Dara
    Im guessing there was some complaints of water seepage between the housing and S2 when mounted outside. I ended up using weatherstripping between the housing and lights... so far so good for the past 2 years.
  12. Oct 27, 2022 at 6:36 AM
    PixelPusher
    PixelPusher New Member
    New Hampshire
    2020 Tundra Limited, Super White
    I changed the oil, replaced the plastic filter housing out with the aluminum version and installed a Fumoto valve. Really liked the MotivX wrench and filter drain set up. Oil changes will be REALLY clean now.
    Also, I attempted to rotate the tires, but learned that the lug nuts had swelled. Stupid two piece lug nuts are crap! I am waiting to hear back from the Dealer to see if they will replace them. I only have 25000 miles on this thing. This should not be a thing I should be dealing with.
    Even IF Toyota does replaces them, I can't say that I trust them not to do the same thing in a couple years. I just don't feel like spending money on aftermarket lug nuts right now. I couldn't believe it when the Service advisor told me how much the OEM lug nuts cost.
    List price on these things are $16.18ea. Sparks has them at 11.68 before the discount (still way too much IMHO).
  13. Oct 27, 2022 at 6:45 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Interesting, first I've heard of leaking. How's the seal on the for the bracket itself? The gasket looks good but I'll probably add some rtv inside just in case.
  14. Oct 27, 2022 at 7:23 AM
    5.7TRDProm
    Dara
    The gasket on the evilmfg housing itself is fine I didn't do anything to that, but its the section between the housing and the S2. There's very very very small gaps between it that a thin piece of paper and slide inbetween if you look at them carefully enough, then again this is me referring to the older/first version where the S2 mounts from the outside, not inside like yours. I saved myself the time and hassle with a little insurance anyways and applied weatherstripping between the S2 and the evilmfg housing.
    reywcms[QUOTED] likes this.
  15. Oct 27, 2022 at 7:28 AM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    wow first time hearing of problem with lugs ?!
    ...anyone have a link for lugs far superior to oem ?
    PixelPusher[QUOTED] likes this.
  16. Oct 27, 2022 at 7:59 AM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    2019 Super White 1794 Edition Tundra CrewMax 4x4
    3/2" Readylift, TRD Dual Exhaust, TRD Sway Bar, Line-X Bedliner, ArmorFlex Tonneau, ESP 3 bin storage, Amp Power-Steps, Driver Side Grab Handle, Ronin Antenna, Window Tint, ClearBra. Coming Soon: 20" Method MR305NV. BF Goodrich KO2 275/60/20
    Very cool photo, do you mind sharing the offset of those wheels? They appear to be the Method 305 but I can't quite tell the color either.
  17. Oct 27, 2022 at 8:37 AM
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    Thank you, yes they are Method 305 I believe they are +25mm offset.
  18. Oct 27, 2022 at 8:39 AM
    PixelPusher
    New Hampshire
    This was news to me as well. I had heard about troubles with 2 piece lugs, but not in regards to Toyota. Apparently, this has been a KNOWN issue for years. Toyota officially doesn't replace them under warranty, but my dealership is trying to get a "good will" replacement approved. I still haven't heard back from them on if it has gone through or not.
    From the limited searching I've done, I have heard that Gorilla makes a good solid replacement. Here is a link to one I found. FWIW... I have know idea if this is a good vendor or not. I can also find Dorman, but I have seen MANY complaints that they turn to rust within 6 months.
    Any input from others would be great. I'd like to avoid the spline version lug nuts. I like to keep my tools standard.
  19. Oct 27, 2022 at 8:42 AM
    Cthulhu
    I bought these for my wife's Sequoia, no rust or swelling after two years:
    https://www.amazon.com/gp/product/B08X9ZWWTR?ie=UTF8&th=1
  20. Oct 27, 2022 at 8:48 AM
    seydou
    seydou Distinguished Member
    Got my topper.
  21. Oct 27, 2022 at 9:47 AM
    PixelPusher
    New Hampshire
    A bunch of the reviews on that show rusting. I'm up north and I'm very concerned about that here. I'm guessing you don't have to deal with a large amount of road salt in SC.
    That said, I try to avoid buying from Amazon if I can.
  22. Oct 27, 2022 at 9:49 AM
    Cthulhu
    Makes total sense. No road salt down here for sure, they use sand when we get snow once in a blue moon. Shut down the schools with only 1/16” accumulation!! Wish they did that when I was going to school in the Poconos!! :rofl:
  23. Oct 27, 2022 at 9:54 AM
    That's because the state knows that people don't know how to drive in it. Don't forget that bread and milk become non-existent lol.
    PomDad likes this.
  24. Oct 27, 2022 at 9:55 AM
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
    I did the same service this past weekend and ended up fouling the threads on one of my lug nuts after removing it. Luckily, I had some security lug nuts that I could use to get back on the road. My local stealership wanted $33 A PIECE for replacements. The Sparks price was more tolerable until they wanted $16 to ship a single lug nut. I ended up getting one from a dealer on Amazon (or at least i hope it is) for $18 with shipping....
  25. Oct 27, 2022 at 10:06 AM
    PixelPusher
    New Hampshire
    We call that the "French toast crowd" at the grocery store. When you see everyone out buying Bread milk and eggs. There is probably a storm coming.
  26. Oct 27, 2022 at 10:07 AM
    Lol. Those Carolina people know it as paranoia.
  27. Oct 27, 2022 at 10:11 AM
    PixelPusher
    New Hampshire
    Sparks has good prices on stuff. But shipping is a bitch. Your lucky, I just went to their site and it says it wants to charge me $26.69 to ship ONE lug nut.
    $29.23 if I wanted to buy 16.
    That's a big no from me.
    WILLINH and jonclark96[QUOTED] like this.
  28. Oct 27, 2022 at 10:14 AM
    Taco-Spike
    Two Trucks
    Damn, I want French toast now :pout:
  29. Oct 27, 2022 at 10:29 AM
    RegGex
    RegGex I noticed you copied my beard
    Oregon
    2021 TRD Pro CM
    You make it and we all come over? :fistbump:
  30. Oct 27, 2022 at 10:45 AM
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    2018 Crewmax 1794 4x4
    we're almost twins! same wheel/tire combo, and truck color!
