  1. Jul 26, 2022 at 3:57 AM
    TBS
    TBS New Member
    2021 SR5 CrewMax 4x4 Barcelona Red
    E50 extinguisher, Valhalla Plates, ESP Storage, Chrome Delete, Pwr Tailgate Lock,
    They are nice. You will enjoy them.
    I have them as well and run the red's up front and the white in the back. I found the whites up front are a bit too bright but with the whites in the back it gives me enough light to do what I want and if I need more light for something I just switch to white.
    1lowlife[QUOTED] and Taco-Spike like this.
  2. Jul 26, 2022 at 6:23 AM
    Taco-Spike
    Two Trucks
    I like the white personally, but my wife thinks it's too bright so I run the red for her. I like the red too but if I'm by myself i'd run white more often.
    For years in my Tacoma before there was a dual color option I would change out the white and red maps and dome for her, camping or vacation trip needs. Not having to do that is so much better, but I became a pro at it in my Tacoma doing it a few dozen times and could probably get in done in a minute or so.
    1lowlife[QUOTED] likes this.
  3. Jul 26, 2022 at 6:58 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I love mine, came on the truck when I got it used. Works great, does what I need it to and waterproof~ Looks nice on your truck.
    batman900[QUOTED] likes this.
  4. Jul 26, 2022 at 8:40 AM
    Sean492
    Sean492 New Member
    Winston Salem, NC
    2018 MGM Tundra Sport
    I've had a couple of mods sitting around since the spring so in the past week I have made the time to add the under seat storage and the bed step. Both mods were quick thanks to videos I have watched through links from the forum and YouTube searches. I am really slow installing, just trying to be sure I follow steps correctly. Since there are already many pics of these two mods I'm not posting any unless someone has a question.
    The under seat storage is simply about taking your time with cutting the template and the floor carpet. Painters tape held the template in place well and a silver sharpie worked perfect to mark the cut lines. The cut foam is a mess but an easy clean up. Start to finish was maybe 40 minutes and that includes cutting the cardboard template and vacuuming up foam afterwards.
    The bed step I purchased is the OEM model (with no directions included) however I believe it is the same as the AMP Research step. Seems to be a well made quality item. After watching several videos I chose not to disassemble the bumper to install the new bumper bracket included with the step. Instead I used the well advertised Tundras.com shortcut of simply cutting the "triangle section" out of the existing bracket. Cutting sanding and treating the bracket took just a few minutes and the actual install took only a few minutes more. The longest part of this mod was finding one of the screws for anchoring the actual step to the arm, I had dropped it in the grass next to the driveway! Maybe 30 minutes total to complete this mod, not including the yard search! I did back the truck onto my Rhino Ramps so it was much easier to actually sit up under the truck the hold the step while putting the bolts in.
    Next I want to swap out all cabin lights as well as the reverse and bumper lights for LED bulbs. I have a Sport model so the headlights and fog lights are good. Any suggestions on a kit, or brand of lights that are good quality / reasonable cost? I will search this but just thought I would ask while posting.
  5. Jul 26, 2022 at 8:51 AM
    I have a set of Vleds high power reverse lights that are about 5 months old that I'll sell. I have the Hottails setup now so no need for them.
  6. Jul 26, 2022 at 8:59 AM
    Wahayes
    Wahayes Older I get the wiser I realize my dad was
    Will
    2017 tundra limited
    325/60r20 falken at3w, 2.25 dobinsons ,20x9 +20 fuel torque wheels, leer xr100, bmc
    Rocky road outfitters in Utah. I wanted to support local, they're about an hour from me
    French Avocado likes this.
  7. Jul 26, 2022 at 11:13 AM
    d_kinneyjr
    d_kinneyjr New Member
    Dave
    Southern NH
    2018 Crew Max SR5
    Tundra Tuesday's
    Started off today with adding some color to the door sills, courtesy if TVD Decals
    Before:
    After:
    Then I added the Blacked Out Toyota Emblem Cover from Amazon
    Before:
    After:
    Then I did the Shifter Boot modification, tired of all the crumbs getting into the shifter area.
    Before:
    After:
    Lastly I while I had the center console dismantled, I switched over the passenger cigarette lighter to a double charger.
    PROGRESS!!!!
  8. Jul 26, 2022 at 11:48 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Replaced oil in Sequoia, at 3000 miles (bought it "new" with 2700 miles). Oil filter cap drained with quite a bit of water suspension. That reminds the oil has to be changed 2-3 times a year, even if miles are low, because of water condensation.
    Drained transmission in Tundra, 4 quarts came out. Found out the full Toyota ATF box laying in garage in far corner was T-IV, not WS. Got WS 2 days later, drained 2 qts more before replacing the fluid. The old fluid had some soot-like particles from burnt clutches, means I need a winch for snow recovery :) Added some Lubegard Red, too.
  9. Jul 26, 2022 at 1:21 PM
    greg8765
    greg8765 New Member
    Grant
    Utah
    2021 Cement Tundra
    lucky! what brand?
  10. Jul 26, 2022 at 2:20 PM
    frichco228
    Yep, have seen that before. This was my truck running that same tire and size
  11. Jul 26, 2022 at 2:29 PM
    frichco228
    Keep an eye on them. Ill guess that one will eventually need to be remounted in another position and hopefully balance with less weight. Or, it could stay balanced and fine until its time to rebalance and rotate. Stacking weights can also make them easier to pop off, but you will know quickly if you lose any. Hope the coopers work out for you, many love them. I ended up returning them, got a bad batch for sure. Two had weights like that, another got a sidewall crack at about 5k miles.
  12. Jul 26, 2022 at 6:30 PM
    Beer Man
    Beer Man @cement.tundra
    2021 SR5 XP CrewMax Cement
    The vinyl cover doesn’t need to be anywhere near perfect.
    Just take that shifter area apart, lay vinyl overtop of the glossy part & put it back together. Look back at what I did to mine about a year ago. The only difference will be how the Meso shift gate trim is attached, I think it’s a little more involved than AJT. With the AJT it snaps overtop & helps hold down the vinyl.
    Then you can just cut new lettering & stick it ontop of the matte black vinyl you put overtop already.
    BlueRibbon4x4 likes this.
  13. Jul 26, 2022 at 6:54 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    You’re also missing a chunk of rim there
  14. Jul 26, 2022 at 7:02 PM
    Taco-Spike
    Two Trucks
    Knob is a Tacoma pro knob. They are everywhere
    you can mod them to add switches for light bars and add lights to it
  15. Jul 26, 2022 at 7:04 PM
    21ProWeb
    21ProWeb New Member
    Mason, Ohio
    2021 MGM Toyota Tundra TRD Pro
    Please provide link to shifter boot and shifter knob.
    TIA
  16. Jul 26, 2022 at 7:05 PM
    I was trying to create a cut file for those that wanted to choose on overlay versus a spray. I did the matte clear on mine.
    Pillslinger and French Avocado like this.
  17. Jul 26, 2022 at 7:21 PM
    BuzzardsGottaEat
    BuzzardsGottaEat New Member
    '16 Tundra DCLB
    Round Tires
    Same thing I do every day.
    BD047168-97B8-4E42-9121-0BF8F806191E.jpg FE507517-1C2A-46A5-BEB6-438C045F96D1.jpg
    Put 100s of dollars into it.
  18. Jul 26, 2022 at 7:23 PM
    RobertD
    Robert
    DFW, Texas
    :devil:
    We see what you did there lol
  19. Jul 26, 2022 at 7:31 PM
    BuzzardsGottaEat
    '16 Tundra DCLB
    Round Tires
    who me?
  20. Jul 26, 2022 at 8:52 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Received my Valhalla shields today and threw them on before a trip to Boise on Wednesday...this is a practice run before I head to CA to visit some long gone family members...install is easy, clean and took maybe 30 min... I'm happy
  21. Jul 26, 2022 at 9:11 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Seriously? I pretty much only use the red. Only time I’ve used the white was trying to find something I dropped under the seat.
    Either way, they were a great addition for me.
  22. Jul 26, 2022 at 9:13 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    After reading your and other responses I may have to reconsider.
    I've had little experience even seeing them on at night..:eek2:
    Tripleconpanna likes this.
  23. Jul 26, 2022 at 9:14 PM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    Red preserves night vision.
  24. Jul 26, 2022 at 9:17 PM
    RainMan_PNW
    Casey
    Clark County, WA
    No worries. I went about a week on white before switching to red and mostly leave it red now
    1lowlife[QUOTED] and HulkSmurf14 like this.
  25. Jul 27, 2022 at 2:34 AM
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    Which emblem overlay did you get from Amazon? Can you please provide a link?
    Thanks
  26. Jul 27, 2022 at 4:12 AM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    I dig the flag in the cup holder. Looks like a coaster maybe? Where did you get it?
  27. Jul 27, 2022 at 6:20 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Tundra's led headlights are tough on eyes at night. I was thinking about what to do with them, but then I wrapped the headlights with Lamin-X polyurethane film purely for protection on trails, and the disturbing blue hue is gone.
    HulkSmurf14 likes this.
  28. Jul 27, 2022 at 6:26 AM
    frichco228
    yep, purchased used, original purchaser clearly hit a curb just right. No issue with it, is true, balances fine, no leak.
  29. Jul 27, 2022 at 6:26 AM
    Beer Man
    I get what you’re trying to do. I’m saying you don’t need to spray anything or have a perfect outlined cut. You cover up the edges with the other parts of the shifter area. Here’s mine that’s held up awesome for over a year. You can see all I did was lay it down, fold over the edges (not anywhere near perfect) & cut out an area for the shifter. Once you make that 1 cut you just fold it out of the way & click the AJT trim right over top. You don’t see any imperfections.
    Like I said, doing it this way you lose access to the stock lettering but I just made my own after the fact & stuck them back ontop of my vinyl.
    So, if you’re trying to sell this with your other things you’re making, all you need to sell is a big enough square of vinyl (color of their choice) & the letters to stick back overtop (font & color of their choice).
  30. Jul 27, 2022 at 6:41 AM
    king.cong.1119
    king.cong.1119 New Member
    went offroading in the mountains and towed a broken down GX without power up a very steep and long incline.
    Wallygator, bulldog93, rebmo and 20 others like this.
