  1. Apr 28, 2022 at 10:27 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    They are. I was in a group of friends in the 90’s and we would pick up mid-60’s bugs that had been pretty abused for a couple hundred and tear them down and put them back together. Still fun. Not as cheap any more… but nothing is.
    nhw544 likes this.
  2. Apr 28, 2022 at 10:33 AM
    d_kinneyjr
    d_kinneyjr New Member
    Dave
    Southern NH
    2018 Crew Max SR5
    @panicman i see you have the 2018, so do I an d i was looking at doing this. Where did you get your parts from, and what did you do, if anything with the TSS sensor? Thanks
  3. Apr 28, 2022 at 10:45 AM
    The emblem and TSS sensor get swapped over to the new grill.
  4. Apr 28, 2022 at 11:19 AM
    panicman
    Eric
    That was true- but no longer.
    I got my parts through Sparks. Like Tundra234, I thought I could remove my sensor cover and install it on the new grill. Not so.
    In late 2020, they changed the sensor cover mount, and it is quite different. It fastens with spring clips and a screw now. Prior to the change, it fastened with retention washers that are pressed onto the cover’s plastic posts. The design change is an improvement, but requires you to purchase the new cover, which adds about $200 to the cost.
    Sparks now only sells the newer grill assembly.
    I had some back and forth emails trying to plead my case, and a very patient Sparks worker set me straight, explained, and sent pictures.
    The actual sensor still mates right up with no modification, and works perfectly. (I used radar cruise this morning in heavy traffic and everything was great.)
    I followed Robmotive’s YouTube video and the swap out was a breeze. No broken clips, no difficulty. Great opportunity to clean the filth and grime out of the grill area, too.
    Tundrastruck91 likes this.
  5. Apr 28, 2022 at 11:45 AM
    d_kinneyjr
    Dave
    Southern NH
    2018 Crew Max SR5
    @panicman thanks, how long for the parts to come in from order?
  6. Apr 28, 2022 at 11:46 AM
    TundraPJ
    TundraPJ New Member
    JP
    DFW, Texas
    '19 SR5 TRD Off-Road
    Fox TRD Pro Shocks BFG KO2’s Dirty Deeds 14” BAMF n-fab nerf bars
    Same here, white lights.
  7. Apr 28, 2022 at 11:48 AM
    d_kinneyjr
    Dave
    Southern NH
    2018 Crew Max SR5
    @panicman Are the parts listed below the same that you purchased, beside the color?
  8. Apr 28, 2022 at 11:57 AM
    I forgot about that. Mine is a 2020 so mine moved over with no issues. Now to get the new part number grill, some of the 18 and 19's require the emblem. Sparks can verify what you need by your VIN.
  9. Apr 28, 2022 at 12:00 PM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Replaced the original worn out leather on the ol' Rock Warrior Tomahawk shifter. Went way smoother than I was expecting.
  10. Apr 28, 2022 at 12:10 PM
    RobertD
    Robert
    DFW, Texas
    Looks good! I had issues with mine and couldn't get it to lay as flat as you but its still phenomenal and I love it!
    WFD473[QUOTED] likes this.
  11. Apr 28, 2022 at 1:24 PM
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Thanks!! Yeah, I fully expected it to curl up as I was pushing it down, but I used spray adhesive first and it held together well!!
    RobertD[QUOTED] likes this.
  12. Apr 28, 2022 at 1:34 PM
    RobertD
    Robert
    DFW, Texas
    Did you glue the sides down? I only glued it on the top.
  13. Apr 28, 2022 at 1:53 PM
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    I cut two relief cuts on each side so it wouldn't bunch up when folded down and then glued it down. Worked out pretty well.
  14. Apr 28, 2022 at 3:19 PM
    someguyinhtx
    someguyinhtx 2018 Lifted 4x4 CM
    Lifted 2018 Black 4x4 SR5 Crewmax
    6" Pro comp lift
    Blacked out chrome bumper and grill parts via color matched (almost perfect) 3M gloss black film.
    BD494CFC-CB25-43FD-9BB4-7DB641671B36.jpg A4F0958E-EC81-44A3-A001-36E0E03079E9.jpg
  15. Apr 28, 2022 at 3:28 PM
    Clay J
    Clay J Yota Fan
    Clay
    DFW, TX
    2021 CM 4x4 TSS
    Eibach Stage 1, Pro LED headlights, RCI engine skid plate, Retrax MX tonneau, Ranch Hand front bumper.
    Cleaned the corrosion off both battery terminals. Bought the truck brand new in December 2020. Crazy how bad they were. I’m guessing low quality terminals and/or factory battery? Photo is post service.
  16. Apr 28, 2022 at 3:31 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    Which ones did you get?
  17. Apr 28, 2022 at 3:52 PM
    AZEric
    AZEric New Member
    Eric
    2010 Rock Warrior
    Bilstein 6112’s & 5160’s
    Check the distilled water level in the battery. Might be overfilled. I believe that could cause it.
  18. Apr 28, 2022 at 4:29 PM
    Those bumper caps look really good for a film.
  19. Apr 28, 2022 at 6:29 PM
    espdtrd
    espdtrd New Member
    21 TRD PRO Lunar Rock
    TRD PRO Inserts, bedliner, led interior lights, console lock, console charger, TRD Black Shifter, Ceramic Tint, 275/70/18 Nitto Ridge Grapplers
    Removed factory installed steps and installed RB20’s today! Look great and will hopefully protect from people that don’t care about hitting your truck. Wanted sliders but use my 4runner for trails so couldn’t justify the cost for my truck. Overall happy!
  20. Apr 28, 2022 at 7:21 PM
    someguyinhtx
    6" Pro comp lift
    Thanks. They did the chrome grill trim too.
  21. Apr 28, 2022 at 8:09 PM
    panicman
    Eric
    Came FedEx in 6 days for the bulge, 7 days for the grill and sensor cover. Very happy with it!
    d_kinneyjr[QUOTED] likes this.
  22. Apr 28, 2022 at 8:10 PM
    panicman
    Eric
    Packing slip:
  23. Apr 29, 2022 at 8:44 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Paid it off today!!! :headbang: I own this beast free and clear.
  24. Apr 29, 2022 at 8:56 AM
    Taco-Spike
    Two Trucks
    :cheers:
  25. Apr 29, 2022 at 9:21 AM
    AZEric
    AZEric New Member
    Eric
    2010 Rock Warrior
    OHHHH that's awesome! Congrats!
  26. Apr 29, 2022 at 9:28 AM
    AZTundra
    Paul
    Phoenix, AZ
    Congrats! I'm counting down the payments left on mine. Only 15 more to go.
  27. Apr 29, 2022 at 9:38 AM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    Haha I'm doing the same, but also trying not to think about it..... I think I have 16 or so.
    Taco-Spike and AZTundra[QUOTED] like this.
  28. Apr 29, 2022 at 9:45 AM
    Taco-Spike
    Two Trucks
    I've barley started my payments... I've only made 2 so far.... I won't go down that road just yet
    raspy87 and WFD473 like this.
  29. Apr 29, 2022 at 9:49 AM
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
    6 inch Pro Comp lift. OME rear springs with Coach Builder +3 shackles. Coach Builder tie rod ends. ICON 2.5 front and rear shocks with remote res. ICON Hyd bump stops. 35" Nitto Trail Grapplers on 18" fuel rims. Kenwood DNX 892 head unit with JL audio and RF amp pushing 2 Image Dynamics idq10 subs. SABM, S POD switches for 42" in bumper and 32" behind grille LED light bars. Full interior and exterior LED conversion. LED flush mount back up lights in rear bumper. Valentine one radar detector. V Leds under dash and seats foot well lighting. TRD pro head lights and grille. Full AJT dash kit
    Upgrade your terminals to these and you will never look back.
  30. Apr 29, 2022 at 10:05 AM
    rocsteady
    rocsteady New Member
    Dave
    New Jersey
    2021 Super White SR7 Double Cab SX
    Congrats! I don't even know what it feels like to pay off a vehicle. I'm imagining that it feels pretty damn good. Looks terrific by the way. Army green? Who would have thunk it?
