  1. Apr 23, 2022 at 4:39 AM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    Could you sketch up a quick wiring diagram?
    RainMan_PNW and Mike59 like this.
  2. Apr 23, 2022 at 5:59 AM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    I'm not sure how much of a difference being lower to the ground makes, but I'm sure there's some. My T4R sits almost as high as my Tundra and the light output is significantly better. But, that goes to your second point. I have an HID retrofit on the T4R. I didn't even think of the fact that the Pro LEDs aren't projectors. I think that probably made more of a difference in the Corolla than it being closer to the ground, but that's just my assumption. Projectors should have better output, or maybe usable light, right?
  3. Apr 23, 2022 at 6:29 AM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    Wish I could but all I can remember from that long ago was tapping into the existing reverse light and running a separate in cab switch. Honestly I was surprised to see my backup camera pop up when I engage them from the in cab switch, I figured it would work that way when in reverse but pushing the in cab switch was a nice surprise.
    DZ_[QUOTED] likes this.
  4. Apr 23, 2022 at 6:51 AM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    Interesting. Do you think you have both the reverse switch wire and in-cab switch running to a relay?
  5. Apr 23, 2022 at 7:13 AM
    mgm16trdpro
    Northern NJ
    Yes and if I remember correctly I tapped the bd lights somewhere on the rear passenger side.
  6. Apr 23, 2022 at 7:17 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Depending on where you tapped the reverse light, your switch may be sending power “backwards” through the reverse wire circuit, and that power is triggering the HU to think the truck is in reverse. The anytime camera Mod works similar (only that it is only powering the signal going to the HU and not the entire reverse circuit.
    when I have time to sit down and review the EWDs, I’ll be putting something together that give me Switch/reverse output for the lights but will keep it isolated from the HU side because I’ve already got the ABC /front camera setup
    DZ_ and mgm16trdpro[QUOTED] like this.
  7. Apr 23, 2022 at 7:18 AM
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    raspy87, welshmike and Army_of_One like this.
  8. Apr 23, 2022 at 7:33 AM
    mgm16trdpro
    Northern NJ
    If I had to guess I'd say you are exactly correct in how it's working for me. I turn wrenches and dig ditches, electrical is not really my thing. I knew someone on here would know how and why it's working like that. Like I said I was surprised when the camera came up with the push of the in cab switch.
    If you had to guess I'm not going to hurt anything having it wired that way? Long as it's not gonna hurt anything, I gotta say I love having it this way.
    RainMan_PNW[QUOTED] likes this.
  9. Apr 23, 2022 at 7:42 AM
    RainMan_PNW
    Casey
    Clark County, WA
    If it hasn’t so far, then it should be fine.
    Does your shifter display show “R” when the switch is on? The only thing I’d think might be adversely affected is the ECU thinking you just threw the shifter into reverse while still driving forward at a sited that you shouldn’t be switching to reverse in…but that would have been apparent right away if it was a problem.
    for other things it is important to understand the implications of tapping wires when introducing external current sources. That’s why reading and understanding the EWDs is so important before tapping a wire
    mgm16trdpro[QUOTED] likes this.
  10. Apr 23, 2022 at 8:46 AM
    I have my rear bumper lights on an on/off/auto and its one of my favorite mods so far. Its great for tailgaters. :D
    mgm16trdpro likes this.
  11. Apr 23, 2022 at 8:59 AM
    joey2018
    joey2018 New Member
    Used it as a truck. Put on the Klearz smoked 3rd Brake cover few days ago.
  12. Apr 23, 2022 at 9:58 AM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Finally decided to do the swap for an LED third brake light assembly… Was surprised at how easy it actually was after hearing so many horror stories…so much better than stock
    How To Install LED 3rd Brake Light Assembly, It's Very Simple To Do!...2020 Toyota Tundra Platinum
    https://youtu.be/MIFO-cEbf2Q
  13. Apr 23, 2022 at 10:23 AM
    mgm16trdpro
    Northern NJ
    Hi Casey tnx for info. So I do notice on the multi info 3.5" screen on dash that whether I'm in park or drive that the R for reverse does illuminate along with whatever I'm truly in. However if I'm in park the truck does not move, if I'm in drive the truck stays in drive at both low and high speeds. So only the R for reverse illuminates in conjuction with whatever I'm truly in P or D. I'd hate to find out at a good speed in drive the truck bangs into reverse, hasn't happened yet, and I hardly ever put the lights on from the in dash button moving forward. However like George said I have used it to back off someone tailgating. This hardly ever happens because I'm typically driving much faster than everyone else. Besides that I have used it to momentarily check my trailer when towing. If I remember correctly 1 time out of many uses, when I had them on for a longer period while in drive I think I remember a traction control light pop on once. When I turned the truck off it went away and hasn't come up since.
    So what's your thoughts now? From your posts you seem like an intelligent man.
  14. Apr 23, 2022 at 11:01 AM
    RainMan_PNW
    Casey
    Clark County, WA
    To be sure, I need to chase out the EWD.
    But the control for the transmission isn’t via that signal wire so you’re not risking the truck actually trying to shift based on that circuit being hot. The fact you are seeing the R light up in the dash doesn’t surprise me.
    I can sketch something up tonight that shows a diagram of what is happening. Right now, getting ready to head out
  15. Apr 23, 2022 at 11:10 AM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    Rewired my hood bulge light today. Before I had it wired into my daytime running light on the driver side. It came on when I started truck up. Went off when headlights come on. Which is what I wanted. Bulge light blinked with driver side turn signal, ok. Not with passenger side. Not ok. That bugged me to no end. Tried to add a wire to passenger side with poor results. Couldn’t find the right fuse in box for the daytime running lights. Sooo, I got a relay and wired it to a green switch. Not what I wanted, but it’ll work. 6C5F1030-C725-4D80-8050-56B556C9F147.jpgEAD2496B-7A8F-4D0A-B923-C0EBA354AC45.jpg
  16. Apr 23, 2022 at 11:22 AM
    mgm16trdpro
    Northern NJ
    No worries. Honestly don't even need to waste your time on a sketch for me. My only concern is that I don't F something up the way it is. Long as it's good I'm good. I like it the way it is and long as I don't risk screwing anything up I'm perfectly fine leaving it as is. That little R momentarily lighting on the dash along with whatever I'm truly in does not bother me in the least, hell it's another way besides the switch lighting up to remind me I have them on lol. Plus a free anytime back up camera is a win in my books.
    Can't say I really care about seeing a visual cue to my shifter position. By this time I'm strictly on a feel for position basis.
    DZ_ and RainMan_PNW[QUOTED] like this.
  17. Apr 23, 2022 at 12:09 PM
    rocsteady
    rocsteady New Member
    Dave
    New Jersey
    2021 Super White SR7 Double Cab SX
    Ended up not working today so decided to hit the very lower edge of the truck, behind the running boards, with some bedliner spray as it always looked unfinished there to me.
    oQvmpbP6TLEiX8rHiEzseOxNov8L5xUJdwA2EXNd_bdee2471c1535706be9d85546c1c61414ef58604.jpg
    Then hit the tow hooks with about 6 coats of red plastidip spray.
    gw9iHkonU3eTCViZLtHNXe2S5HOo08xSWbZWAyfy_76aaa2aa91cb37a3ee964ae34dbba47cd058e7ed.jpg
    And while I was in between coats on the tow hooks, I cleaned and taped and added some color to my engine cover. For now just a red "accent stripe" and white for the Toyota T. Doesn't look quite that electric red in person but it does pop for sure. Put a nice thumb print on the T when I went to put it back so resprayed and had to wait for that to go on later.
    W4QNNgPCAnNCsiPD4bERKPbx_i66QjGdpUy76VGk_bc7dc51db67eda5bc707d48409f768f13162550c.jpg
  18. Apr 23, 2022 at 12:49 PM
    ErikTRDTUNDRA
    ErikTRDTUNDRA New Member
    Erik
    2018 Tundra crewmax 1794
    Did you try the IGN fuse spot?
  19. Apr 23, 2022 at 2:13 PM
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    I finally got enough time to give her a bath.20220423_140833.jpg 20220423_140847.jpg
  20. Apr 23, 2022 at 4:09 PM
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    Anyone try the Bonobo TRD start button?
  21. Apr 23, 2022 at 4:23 PM
    2014 Black tundra
    2014 tundra sr5
    I thought about that. If I did that, when I turn my headlights on the bulge light would stay on. Toyota dealership told me amber would be ok above the headlights as long as the bulge light goes off when headlights come on. White light above headlights won’t pass inspection. I guess Off-road would be a different story. I guess the way I have it now, I can turn it on or off when I want.
  22. Apr 23, 2022 at 4:27 PM
    2014 Black tundra
    2014 tundra sr5
    The RC hood bulge light has amber & white lights. I did the amber to go with my day time running lights. Maybe someday I’ll wire the white light to a switch.
  23. Apr 23, 2022 at 4:51 PM
    SpyderRC
    SpyderRC New Member
    2021 Limited Nightshade
    Those are bad ass. Never heard of them till now. Already have a meso button but also interested if anyone has feedback on them. Doesn’t hurt to have a variety :D
  24. Apr 23, 2022 at 7:20 PM
    Pupperunner
    Pupperunner New Member
    LT 2021 Tundra TRD Pro
    C4 Fabrication armor Camburg long travel kit with King suspension Nitto 37x13.50 ADV fiberglass fenders & Bedsides Black Rhino Rapid Rotary forged wheels GFC Camper Baja Designs lighting Alpharex headlights and tail lights
    Way more noticeable. Night and day difference. The pro headlights were decent. But these are much brighter.
    romad86[QUOTED] likes this.
  25. Apr 23, 2022 at 9:19 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Interesting, I like this. Does it go on the outside, or do you have to open the housing up and put it inside? Is it noticeable up close? This combined with the hot tails option A would be perfect for me.
  26. Apr 24, 2022 at 3:44 AM
    biebs96
    PA
    sticks right on the outside. Took 30 seconds to do
    Yzed608[QUOTED] and Taco-Spike like this.
  27. Apr 24, 2022 at 8:59 AM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Damn, looks like it's sold out! I'd love to have that, the close up photos you can't even tell!
    biebs96[QUOTED] and AGSport like this.
  28. Apr 24, 2022 at 9:48 AM
    AGSport
    AGSport New Member
    PA
    21’ AG Sport
    Same here, who can hook us up?
    Yzed608[QUOTED] and Ó Brádaigh like this.
  29. Apr 24, 2022 at 11:13 AM
    1/68AR Ventre A Terra
    1/68AR Ventre A Terra New Member
    2019 Platinum
    Viking Heaven Cat Shields and SR5 Rims
    Just went to the mountains yesterday then promptly washed it. Just put deposit on 22 ORP Army Green 4runner so in the near future the 12 Single cab will be for sale. Ugh, I like that little truck. The 12 gets a shell Tuesday for a couple weeks camping but since the Runner fell in my lap, it might be hard to have 3 Toys for two adults. 70EA2E37-1629-462E-B869-597F182B2E04.jpg4035740C-77E6-4D86-9837-7BBD383FD178.jpg
  30. Apr 24, 2022 at 11:33 AM
    Taco-Spike
    Two Trucks
    I know the feeling. My stepmom will be looking to sell her 4Runner in a year or two so I might see if I can get it for my wife. I’d still keep my trucks though, at least plan to but who knows how I’ll feel then and our future kid(s) situation. And when if and what the next gen will offer
    Congrats on the 4Runner though!
    Wallygator, RegGex, AggiePhil and 2 others like this.
